Fourtitude.com - Saving jacking points
    Results 1 to 4 of 4
      Nov 24th, 2015
      Massachusetts
      318
      99 Jetta
      04-23-2019 09:59 PM #1
      What do folks do when using a floor jack to save the pinch welds and sheet metal jack points from getting damaged. What are the best ideas out there?
      Thanks
    3. Member HelloMissLady's Avatar
      Mar 12th, 2014
      Los Angeles
      312
      02 GTI VR6, 04 DBP .:R32
      04-27-2019 04:01 AM #2
      Quote Originally Posted by nbpt100 View Post
      Thanks
      I've actually been thinking about buying those jacking pads from ECS. Might be worth it long term.
      Neuspeed CAI install on my VR6, you should check it out.
    4. Member Quadrifoglio's Avatar
      Dec 21st, 2004
      Cincinnati
      712
      2004 GLS 1.8t
      05-20-2019 01:16 PM #3
      These work brilliantly:
      https://smile.amazon.com/Potauto-Uni...ch+weld&sr=8-3
      You can also purchase hard rubber hockey pucks with a slot cut out of the middle.
      The jackpoint pads that ecs sells are only intended for a four point post lift in which case the load wait is spread EVENLY across all four points. Those jack points are not meant to be used by a floor jack.
      Stretch looks like an elephant crapping an oil drum.
    6. Member APURPLEKING's Avatar
      May 23rd, 2007
      Emmaus,PA
      3,128
      96' GLX
      03-17-2020 12:52 AM #4
      Been using a hockey puck with a grove cut in it for years. Works great
      Sent from my SM-G973U using Tapatalk
      Pm me for any and all glass questions and inquires, or any VAG-COM needs.
      "ITS A BAD TIME BOB!"
    Similar Threads
    1. Jacking Points!
      By TMR in forum 1.8T Engine Forum
      Last Post: 10-30-2001, 09:32 AM
