Fourtitude.com - No Start
    Results 1 to 6 of 6
    Thread: No Start
    1. 04-23-2019 09:04 AM #1
      I have a 97 1.8 big turbo eurodyne convetered to an 01 ecu pedals harness tb. Haven’t drove it much in recent years but looking to get it back on the road. Was running good last week other than the oil light came on so I ordered a pressure switch and installed. Started it and then a misfire on cylinder 3. Swapped coils to see if it followed and now it is a no start. Has the white top coils and upgraded coil harness. Fuel injectors are pulsing. Any help? Would rather text 910 386 3953
    3. Senior Member Vegeta Gti's Avatar
      Feb 12th, 2003
      konoha village, hawaii
      21,076
      1984 GLi 20v, '16 M3, '85 Golf, '17 R
      04-23-2019 11:37 AM #2
      You need vagcom
      Sent from my SM-N950U using Tapatalk
      :HOMEGROWN MOTORSPORTS:1:4.9 SuaSponte #13Dead Rabbits. Ungluck on IG. MKIforLife
      Quote Originally Posted by .Ant View Post
      What vegeta said.
    4. 04-23-2019 01:26 PM #3
      I have a snapon modis ultra
    6. Senior Member Vegeta Gti's Avatar
      Feb 12th, 2003
      21,076
      04-24-2019 09:25 AM #4
      Still can't do what a vcds can do. But cool. Good luck
      What vegeta said.
    7. 04-24-2019 11:57 AM #5
      so there are no tests for the coils with a dmm or a power probe?
    8. 04-25-2019 01:31 PM #6
      does anyone know what the pins should read on the coil pack connector? other than the valve cover ground where is the other ground 83 for the coils? the only codes in the ecu are for abs module.
    1. Spudering Cold Start & Strange Vibration at ShutDown!
      By DoneRight! in forum 1.8T Engine Forum
      Last Post: 10-11-2001, 09:32 AM
    2. Starting Problem
      By bialyorzel in forum 2.0 Liter Engine Forum
      Last Post: 10-02-2001, 08:25 PM
