Fourtitude.com - Secondary Air intake pressure sensor location PLEASE HELP 2.0T
    Results 1 to 5 of 5
    1. 04-18-2019 03:32 PM #1
      Can anyone post a picture of the location of the SAI Location? I cannot find videos anywhere for the 2.0T. I got the P2432, but I can only find videos for the 2.5, and its not the correct sensor. This one is flat, and doesn't have the two bolts holding it in. I apologize for coming across so ignorant, this is my first VW. 2009 VW Jetta Wolfsburg 75k miles 2.0T. Any pictures and help would be GREATLY appreciated.
      This is the part::
      https://www.carid.com/genuine/pressu...AaAnGZEALw_wcB
      Dec 1st, 2009
      3,337
      2017 Audi SQ5, 2017 Corvette Grand Sport 7MT, 2010 Audi S4 6MT. 2015 Audi Q3 Quattro
      04-19-2019 10:29 AM #2
      That pressure sensor is mounted to the SAI valve located on the end of the cylinder head, below the vacuum pump.
      The SAI valve is a black plastic cylinder, with fins molded into the body.
      https://www.ecstuning.com/b-pierburg...YaAtcQEALw_wcB
      The sensor clips onto the pipe section of the valve.
    4. 04-19-2019 04:10 PM #3
      I cant find this thing. I am new to VW, but I have no idea where it is. Do you have any pictures of it on the car?
      May 14th, 2016
      202
      2011 Audi A3 Quattro S-Line CCTA DSG
      04-19-2019 05:43 PM #4
      Don't know if this diagram will help at all but here you go.
      https://www.expressoemparts.com/oem-...nsor-06l906052
      This is a better site for parts too.
      HPA K04/Intake Manifold/tune, HPA DSG tune, PTP turbo blanket, APR Downpipe, Carbonio Intake, GFB's DV+, Red Top coils, BKR8EIX plugs, 034 Swaybar and rear subframe mounts, Audi R8 knock off wheels, RS3 Grille, Aspherical mirrors, StopTech slotted rotors and steal brake lines, US Mill Works license plate bracket, Clearmounts phone holder.
      Dec 1st, 2009
      3,337
      04-19-2019 10:22 PM #5
      Between the end of the cylinder head and the battery box.
    Similar Threads
    1. 2012 Jetta Secondary Air Injection Pressure Sensor
      By jmcgill in forum 2.5l Inline-5 Engine Forum
      Last Post: 12-16-2014, 06:58 PM
