Fourtitude.com - VR6 12v Turbo - Going for 550whp - Need Help.
    Results 1 to 6 of 6
    1. 04-16-2019 05:37 PM #1
      Here's my setup:
      Stock Bottom End ( Rods with ARP )
      SPA Head Gasket Spacer - 8.5 compression ratio - Copper o-ring
      Stock intake manifold
      ARP Head Bolts
      SPA Turbo Manifold T4
      Holset 66mm x 64mm Turbo AR .86 T4 Hot side - .70 Cold Side
      Fueltech FT500 semi-sequential - Custom Map
      1200cc Injectors Running E100
      Walbro 450
      I've made 430whp @ 1.7bar ( 24psi )
      Point is - I'm currently looking for +550whp - but not sure if i'll be able to get there with the stock manifold and head.
      Is it necessary to have camshafts, larger valves and ported head to achieve that number?
      I would like to hear from you guys.
      Thanks
    3. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      37,100
      15 Jetta 92 Corrado VR6
      04-16-2019 09:58 PM #2
      Power seems a little low for e85, we get that much on pump gas without issues. Likely needs timing adjusted, but will be low 30s psi for 550whp.
      -Paul
    4. 04-17-2019 10:56 AM #3
      Quote Originally Posted by need_a_VR6 View Post
      Here's how it's set:
      Crank Configuration:
      Any thoughts?
    6. 05-04-2019 09:02 AM #4
      Don’t mean to side bar but what engine management rate you going with?
    7. 05-04-2019 10:50 PM #5
      Quote Originally Posted by hotsk1llet98 View Post
      Fueltech FT500 EMS
    8. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      37,100
      05-07-2019 07:48 AM #6
      Timing if anything looks aggressive. You can loose power from too much even without knock.
      Also verify WITH A TIMING LIGHT that when timing is set to 0deg fixed that you see the tdc mark on the flywheel.
      -Paul
    Similar Threads
    1. vr6 12v turbo kit for sale
      By clifborder4fm in forum 2.8l 12v VR6 Engine Forum
      Last Post: 02-09-2009, 08:43 AM
    2. Best VR6 12v turbo kit????? experienced feedback needed!
      By GoDeepOrGoHome in forum 2.8l 12v VR6 Engine Forum
      Last Post: 08-07-2006, 12:30 PM
    3. VR6 Turbo, looking for camshafts need some help...
      By Vanela in forum Forced Induction
      Last Post: 06-01-2004, 06:02 PM
