Hey guys! Back story is my 2015 A3 2.0T had an upgraded IS38 turbo. All was well till the day it grenaded for some reason. I decided to go back to my stock IS20 turbo and had it professionally installed by a shop who also checked out the engine to make sure it is ok. So now things get interesting. I’m running Eurodyne stage 2 91 octane and when I get on power my log shows the target boost is 2600 but it only reaches 1700. I toyed around with the wastegate actuator preload settings but that doesn’t fix the issue. I also have no engine codes. 1 out of 10 times of just stomping on the gas I can feel it’s reaching higher boost via the butt dyno, but when I try it again it is back to the same problem. Any ideas of what could be causing this? Thanks in advance
