Fourtitude.com - P2789 - Should I be worried?
    Results 1 to 3 of 3
    1. Member scorch07's Avatar
      May 17th, 2011
      191
      '10 Audi A3, '07 Jetta Wolfsburg Edition
      03-11-2019 09:56 PM #1
      So I recently picked up a 2010 A3, 2.0TSI with 80,000 miles on it. It's in fantastic shape and, from all indications, was religiously maintained at the dealer. LOVE the car! I knew being an earlier TSI model I may have a few issues that I was prepared for (timing chain tensioner, water pump, etc), but I finally got to do a full scan today and got something unexpected - fault P2789 on the transmission - Clutch Adaptive Learning at Limit.
      The car seems to be driving fine. The feel from takeoff is a bit different than what I'm used to, perhaps a bit more juddery but just felt like a clutch grabbing instead of a torque converter, so I have just chalked it up to being a different type of transmission. But I guess it could be related?
      I cleared the fault just to see if it comes back. Carfax says the transmission was serviced at 66k, but I don't know if it was done at all before that. Would it be worth trying to check the fluid level and/or just changing it? Even though it was done about 15k ago. Or am I likely looking at a clutch replacement and/or something worse?
      Not really sure what I'm looking at here since there are no real symptoms, but looking at the limited data on it looks like it could be a fairly serious problem...
      Any info or advice would be greatly appreciated!
    3. Member daniel.ramirez's Avatar
      Nov 23rd, 2001
      México
      578
      2009 A3, 2015 A1
      07-25-2019 03:30 AM #2
      did the code came back?
      2009 A3 S-line, RNS-E, Unitronic, and some more stuff... and now a 2015 A1, let the retrofits begin!
      Aug 15th, 2018
      Los Angeles, CA, USA
      163
      07-25-2019 05:28 AM #3
      You could always try a basic settings reset by VCDS/equivalent.
      http://wiki.ross-tech.com/wiki/index..._%28DSG/02E%29
    Similar Threads
    1. Should I be worried?
      By DagoGLI in forum 8v Engine Forum
      Last Post: 03-29-2002, 01:40 AM
    2. router log : should I be worried?
      By landrumdh in forum Computers
      Last Post: 01-24-2002, 07:18 PM
