Fourtitude.com - Rebuilding the valve train, looking for tips.
    Results 1 to 9 of 9
    1. Member mk3illa's Avatar
      Oct 11th, 2007
      sofla
      218
      2011 vw golf s
      02-05-2019 10:30 AM #1
      So, lost a rocker on cylinder 2, intake side. Luckily, didnt drop a valve, caught it right as it happened. Started as a bad misfire, and upon inspection, noticed the rocker free floating under the cam.
      I guess I'm looking for some torque specs, and some advice on what to expect. I have a good understanding of head repairs, but it's my first time with this motor ('10 07K)
      Are there any recommendations for brands of valve train components? Going with super tech for the valves springs and retainers, IE for the guides and other parts. But, I'm trying to find a decent set of rockers and HLA's (hydraulic lash adjustors) and not sure if anyone here has any experience-driven recommendations for brands.
      The head hasn't shown bad signs of damage yet, but I'm going to check if it's still good once I have it on the work bench. Not sure if I will deck it, and still have to look into +1mm valves. IE has the oversized guides, but I'm not sure if the head has to be milled, or if the guides themselves are thinner to make up for the oversized valves. If the seats have to be milled at a shop, I'm not going for it. 20v and 5 chambers will not be a cheap bill.
      While I have it off, I'm most likely going to perform a stage 1 port and polish. This car will stay NA
      TLDR broke a rocker, need info on head specs, tolerances and parts.
      Sent from my LG-H871 using Tapatalk
      Dub #5: '11 BGP golf 5SP
    3. Junior Member nomnomcarrots's Avatar
      Aug 15th, 2018
      CT
      44
      2007 Rabbit 5MT
      03-28-2019 10:23 AM #2
      Any updates on this? Was interested in following along. I know Ferrea valves have always had good reviews but I can't speak from personal experience, just comments from other people.
      Cheers!
    4. Member mk3illa's Avatar
      Oct 11th, 2007
      sofla
      218
      2011 vw golf s
      03-28-2019 10:33 AM #3
      Upon further investigation, ended up being the valve spring that broke. Basically, going to repair it junkyard parts and send it. The motors are cheap enough to get a whole long block with low miles, most expensive I found was around $1k, and 400-700 on average.
      Oct 24th, 2014
      Minneapolis, MN
      750
      2012 VW Passat SE 2.5 5-speed
      03-28-2019 04:58 PM #4
      Why replace the engine? Just replace all the springs and be on your way. Or was there other damage?
    7. Member mk3illa's Avatar
      Oct 11th, 2007
      sofla
      218
      2011 vw golf s
      03-28-2019 05:22 PM #5
      Quote Originally Posted by karlsvw View Post
      You can buy a long block for the price of super tech springs. Low mileage for close to the amount for a set of valves.
      I don't know why that is, but it's how it is.
      The motor currently in the car has almost 120k, and had *decent* maintenance done, has over revved once (3-2), and has been oil starved/red dummy light a few times in its last few years. Totally my fault, neglected to maintain the car in a timely manner, and this was the result.
      Quick look at the valve train shows signs of low oil pressure/starvation. Aside from the broken spring, I saw other things, and just saw the price of parts soaring.
      Would rather take a chance with a 30k mi motor that was ran and inspected before it was pulled. They're around 400-600 for long blocks, and some even include accessories or harnesses. Although there weren't too many last I looked, there was a friggin crash test safety model...motor only had 300 miles on it, for around a grand.
      Oct 24th, 2014
      Minneapolis, MN
      750
      03-29-2019 08:16 PM #6
      Gotcha. That makes sense.
    9. Junior Member nomnomcarrots's Avatar
      Aug 15th, 2018
      CT
      44
      2007 Rabbit 5MT
      04-01-2019 11:19 AM #7
      Quote Originally Posted by mk3illa View Post
      Still planning on port + polish, or just swapping it in as it sits? Any preventative maintenance plans while it's out or just drive it until it dies? Glad to hear that it's easy to find a block with low miles. These engines are super reliable so you shouldn't have any issues, but definitely keep us updated on how it goes.
    10. Member mk3illa's Avatar
      Oct 11th, 2007
      sofla
      218
      2011 vw golf s
      04-01-2019 11:08 PM #8
      Quote Originally Posted by nomnomcarrots View Post
      Will do. Probably won't bother with a port and polish. As far as maintenance goes, I plan on being on top of it this time around. Kind of toying with the idea of a Proton kit from nitrous xpress. Curious what a set of drag radials and gutted interior would work with that
    11. Member mk3illa's Avatar
      Oct 11th, 2007
      sofla
      218
      2011 vw golf s
      08-14-2019 11:40 AM #9
      Resuscitating a dead thread here, but looking for tips/help.
      Is there a way to pull a camshaft without having to pull the gearbox? Or am I S.O.L.?
      I don't want to run the car with the broken valve spring, but I'm desperate to get it running so I can get rid of it. I unfortunately can no longer keep it, as life is happening.
      In case anyone is interested or curious, this will most likely end up on the classified section. Would like to at least get it running, but the motor will be on borrowed time.
      It's a 6speed swap (11 CC gearbox) with full bolt ons from IE and all the ecs and apr shifter goodies. Koni yellow adjustables with 1.8 neuspeed springs and enkei m52 18x8
      It sucks, didn't even hit 1k miles with all the new suspension and wheels and the 6 speed swap before the spring came out. But I gotta part ways with it.
      If anyone wants any further details, just shoot me a PM.
    1. Replies: 4
      Last Post: 10-10-2012, 10:58 PM
    2. Diesel head rebuild, what should I look for when the shop is done?
      By screwedRado in forum TDI and Diesel Forum
      Last Post: 12-14-2006, 08:52 PM
    3. looking for tips on diving on the track
      By luigi1181 in forum The Car Lounge
      Last Post: 05-28-2003, 07:08 AM
    4. looking for tips Kodak DC215 (using the Macro)
      By Mad-Dog-Tannen in forum Photography
      Last Post: 07-15-2002, 12:40 PM
