Fourtitude.com - oil capacity 2017 jetta 1.4t
    Results 1 to 8 of 8
    1. 01-02-2019 11:56 PM #1
      What is the oil capcity on a 2017 1.4t jetta,
    3. 01-02-2019 11:59 PM #2
      Quote Originally Posted by raaizin View Post
      4.5 qts with filter 4.2 qts without filter.
    4. 09-02-2019 05:19 PM #3
      The correct amount is 4.2 Qts With Filter per the owners manual.
      http://i67.tinypic.com/2vacmfq.jpg
      2017 VW Jetta SE
      1987 Chevy R10 Custom Deluxe
    6. 09-04-2019 02:54 PM #4
      Maybe if the dealer or quicklube hurrily put the drainplug back.
      With front of Jetta on ramps, I pulled my plug and filter, did other things for 1/2 hr, and it took 4.5 quarts to get to the full level as opposed to the 4.2qt textbook amount.
    7. 09-04-2019 07:25 PM #5
      Quote Originally Posted by Greasymechtech View Post
      Greasymechtech,
      I change my own oil.
      Like you, I had also put in 4.5 qts to get to the full mark after letting the oil drain for at least 15-20 minutes. However, after leaving it sit overnight, and randomly checking it again over the next few weeks I found it is now a little overfull. I guess it takes a good while for all the residual oil to drain down into the pan on this engine.. I just left it like it is, but next time, it will be exactly 4.2 qts.
      2017 VW Jetta SE
    8. 09-04-2019 09:03 PM #6
      Quote Originally Posted by Encinoman45 View Post
      Greasymechtech,
      What i usually do is fill the oil filter with oil to the top then again and let the oil sink in. Then I use whatever is left until there’s just a little less than one quart. Sits right before that wedge on the dipstick where full mark is. I use Mobil 1 0w-40 for the past 70k Miles with a Mobil 1 filter all changed every 5k miles.
    9. 09-04-2019 10:43 PM #7
      Greasymechtech,
      Dipstick is calibrated for a hot engine oil check, typical for someone that exercises the dipstick at the gas station after filling the vehicle up.
      With the engine at operating temperature, park the vehicle on a level surface to help prevent an incorrect oil level reading.
      Switch off the engine and wait a few minutes for the engine oil to flow back into the oil pan.
    10. 09-05-2019 09:23 PM #8
      Thanks for the additional info. It looks like my oil level is fine then.
      2017 VW Jetta SE
