Fourtitude.com - most OEM headlights suck per IIHS
    Page 1 of 4 1234 LastLast
    Results 1 to 25 of 100
    1. 12-07-2018 10:50 AM #1
      Saw this on the news before heading to work. Basically the Insurance Institute for Highway Safety does their test on OEM headlamps and gave their review. Our of a 100 vehicles tested, only 4 rated as good and 40 were considered poor. When the swapped over and test SUVS, 37 of mid sized SUVs were listed as poor to marginal. The concluded that most manufactures are more worried about the design than the actual performance. In the times when the lights did meet the test many were not aimed correctly off the assembly line. Some of the headlights that tested good are only available in high trim packages so basically you dont meet the safety standard unless you pay up as the consumer. I used to hate on the brodozers with all the LEDs, but they may be on the right track.
      https://www.cnet.com/roadshow/news/i...t-performance/
    3. Member Volkl's Avatar
      Oct 2nd, 2003
      Olympia,WA
      946
      Miata RF, JKU, Cabriolet
      12-07-2018 11:47 AM #2
    4. Senior Member VWVan's Avatar
      Feb 17th, 2000
      Langley, B.C.
      26,702
      2005 Jetta Wagon TDI manuel 1.5 Malone, 2014 Tiguan 4MO
      12-07-2018 12:14 PM #3
      They should of thought about this back in the 70's.
    5. Member kryptonik's Avatar
      Apr 26th, 2003
      Salt Lake City, UT
      3,787
      2015 4Runner TEP w/ KDSS
      12-07-2018 12:19 PM #4
      I drove behind a x4m40i or something along those lines a few weeks ago.
      By far the coolest, and nicest headlights I've ever seen. They actively moved with the cars on the road.
      In the photo below, that wall on the right was lit up like that till he had to pass a car. Moved over to the middle lane, and the light lowered and avoided the car. Then after the pass, came back up. Same thing with the driver side.
      Color, coverage, and the cool moving ****... it was something else. Just being behind it was nice. I can't imagine how nice it must be when you're driving.
    6. Member ice4life's Avatar
      Nov 5th, 2017
      CO
      5,407
      19 Arteon SEL-P
      12-07-2018 12:51 PM #5
      Quote Originally Posted by kryptonik View Post
      I wonder if that was just the adaptive beam distribution. This happens when the car hits a certain speed; the beam spans lower and out. It also does this when the rain sensor detects rain ie bad weather. It very well could have been that his speed was going over/under the threshold as you passed.
      Still cool whatever it is.
    7. Member Jimmy Russells's Avatar
      Feb 4th, 2007
      Vancouver
      16,286
      RS3, JKU
      12-07-2018 12:54 PM #6
      The DOT simply needs to get with the times. So many cars even with LED headlights have to run them at lower wattage especially the high beam, and they can't use dynamic lighting yet (like actual real Matrix LED) yet for the rest of the world this stuff has been around for years.
    8. Member TangoRed's Avatar
      Sep 7th, 2005
      Seattle, WA
      11,879
      12-07-2018 12:57 PM #7
      Quote Originally Posted by ice4life View Post
      There are some people that have enabled it via coding though.
      Quote Originally Posted by Doug Butabi View Post
      And on the tenth day of the two thousand fifteenth year, TCL finds out about rich people.
    9. Member kryptonik's Avatar
      Apr 26th, 2003
      Salt Lake City, UT
      3,787
      12-07-2018 12:57 PM #8
      Could have been. We were probably cruising around 70, based on my average speed on this drive (my commute home). I just read about the matrix lighting. First I'd heard of it. Definitely seemed to be behaving like that though.
    10. Member VdubXXIV's Avatar
      Feb 13th, 2008
      2,195
      1967 VW Beetle, 2003 VW Jetta, 2012 CC R-line, 2019 Volvo XC60 R
      12-07-2018 01:03 PM #9
      The headlights on my XC60 are unbelievable. Auto high beams detect when and were to shine the light. It will highlight road signs as I pass them and also move with the steering wheel. They constantly adjust to what it senses around me.
    11. Member Rav_VW's Avatar
      Apr 1st, 2005
      Philly Burbs
      1,694
      135i, A6_3.0, XC40
      12-07-2018 01:04 PM #10
      Maybe if they were aimed at the road and not at oncoming drivers they would work better.
      Seriously though, we peaked with Xenon. Even if modern LEDs appear brighter due to high brightness, you're resolving less usable visual information due to the terrible spectrum.
      Typical light sources. The human eye sees the most at 550nm, where that big dip in white LED is.
    12. Member ice4life's Avatar
      Nov 5th, 2017
      CO
      5,407
      19 Arteon SEL-P
      12-07-2018 01:06 PM #11
      Quote Originally Posted by TangoRed View Post
      Funny you say that- i noticed on the window sticker it usually says "decoding for anti-dazzle lights" i wonder if they are referring to matrix lighting and if it is that simple to code. I mean on the new A6/A7/A8/Q8/e-tron, you can order "matrix style" lights which "can likely be coded by your dealer at a later date." per the order guides. Makes me think a lot of cars are going to be ready for the hopefully updated DOT regs, and just flip the switch (pun intended) to be matrix light ready in the US.
    13. Member Jimmy Russells's Avatar
      Feb 4th, 2007
      Vancouver
      16,286
      RS3, JKU
      12-07-2018 01:10 PM #12
      Porsche is doing the same thing, apparently the approval is a few months away
    14. Member TangoRed's Avatar
      Sep 7th, 2005
      Seattle, WA
      11,879
      12-07-2018 01:11 PM #13
      There's a healthy amount of people enabling it the BMW forums. It seems a bit "involved" to do yourself but there's people out there that will do it for you remotely once you hook up the car to a certain program.
    15. Member ice4life's Avatar
      Nov 5th, 2017
      CO
      5,407
      19 Arteon SEL-P
      12-07-2018 01:14 PM #14
      Quote Originally Posted by Rav_VW View Post
      This is very cool- I think one of the things you touched on and missed at the same time is intensity. Most xenon headlights were "High Intensity Discharge" lamps. People often believed these two things were synonymous, however they are different. There were examples of HID halogen projector lamps with AFS (Lexus LX570, Lincoln MKX) and there are now today even examples of regular LED headlamps and HID LED headlamps.
      A good example is the new Chevy Silverado 1500- Most trims come with LED reflector garbage headlights. But only the high country gets the special HID LED headlights which have a more intense beam.
      Same thing with my new Jetta- The base model and many volume trims get the reflector led headlights. Only the SEL/SEL-p get projector HID LED headlights and they are noticeably different- I have tested both (loaner vs mine).
      Just food for thought- I am getting at the point that LED lights with HID or even Laser level tech are much better than any xenon lights. However, with so many garbage reflector LED lights flooding the market, its a no wonder there is so much misconception as to why everything is scoring so terribly.
      And for the auto manufcaturers- I would rather you offer a basic light on lower trims, and an optional/higher trim light that was actually good like on the Jetta. With the Atlas, they thought making LEDs standard across the board was a good decision, but it came at the cost of the quality of the lights being subpar across the board (all garbage reflector units).
    16. Member
      May 15th, 2001
      Ocean Grove, NJ
      2,301
      98 740iL, 18 i3 REX, 13 Mini Clubbie S
      12-07-2018 04:23 PM #15
      Both of our i3's had "Active LED" headlamps. But only the 2018 has the full LED setup and active portion functioning. Swivel, main beam dip, etc. done by alternating some of the light pattern. They are way cool - and probably a boat load to replace.
    17. 12-07-2018 04:26 PM #16
      Not to mention DOT laws requiring high beams and low beams to be separately controllable functions. That's mostly why we didn't get the Audi Matrix headlights.
    18. Member ice4life's Avatar
      Nov 5th, 2017
      CO
      5,407
      19 Arteon SEL-P
      12-07-2018 04:33 PM #17
      Quote Originally Posted by ForTheWin View Post
      I guess the VAG execs need to take out some D.C. lobbyists for some schnitzel and a boot.
    19. Member VWestlife's Avatar
      Sep 29th, 2004
      New Jersey
      9,447
      2018 VW Jetta SE 1.4T manual
      12-07-2018 05:09 PM #18
      Hopefully they'll test indicator lights next. If the IIHS ends up conclusively proving that red rear turn signals are less visible than amber, it might pressure the automakers into giving up the current fad of using red rear turn signals on more and more new vehicles:
      __________
    20. Member vwpiloto's Avatar
      Nov 26th, 2006
      Orange County, CA
      11,410
      1987 944 S, 2003 S2000, 2011 E90 M3, 2013 Mazda 3, 2014 4Runner Trail
      12-07-2018 05:27 PM #19
      Quote Originally Posted by VWestlife View Post
      Some of the newer LED taillights are so blindingly bright that sometimes I can't even tell that the signal is on. In those particular cases, the color differentiation is even more critical.
    21. Member mach250's Avatar
      Apr 8th, 2005
      Tampa
      871
      2019 BMW M550i
      12-07-2018 05:44 PM #20
      This is why I plan on coding my M550i's headlights once I receive it to turn this feature on.
      They need to hurry up on this, red turn signals do need to be replaced with amber because some vehicles just have terrible designs making it hard to differentiate.
      Previous cars: 2016 VW GTI PP - 2015 VW GTI - 2004 VW R32 - 2001 Subaru Legacy B4 STI - 1997 Nissan 180SX Type-X
      My Flickr
    22. 12-07-2018 05:48 PM #21
      Quote Originally Posted by mach250 View Post
      *cough cough* Any manufacturer that puts turn signals in the lower part of the bumper. *cough cough*
    23. 12-07-2018 06:17 PM #22
      A lot of big companies are trying to get this fixed:
      https://www.theglobeandmail.com/driv...communication/
      "Safety regulations haven’t caught up to technological development in North America, so we have not been witness to many of these new creations."
      "Volkswagen’s IQ.Light LED Matrix – an option found in its all-new Touareg, an SUV no longer available in North America – is already one of the safest in the market, using 256 LEDs to illuminate the road up to 500 metres ahead. Its intelligence, however, takes it to a new level with instant anti-glare technology."
      Lifetime Warranty & Support | Free Shipping within the US | LEDs Tested to work and look good in your car | Customer Service is our #1 Priority - We care what you install in your car!
    24. Member TREGinginCO's Avatar
      Jan 4th, 2004
      Parker, CO
      7,863
      '06 Campy White Touareg V6 & 2013 Ibis White Audi allroad
      12-07-2018 06:54 PM #23
      Our country's damn outdated DOT laws are the reason why our headlights and taillights suck.
      I'm glad I did this to my allroad
      https://www.youtube.com/watch?v=f7ANqtw1N54
    25. Member 2 doors's Avatar
      Jun 18th, 2003
      Baltimore, MD
      5,442
      '19 Accord EX Hybrid, '16 e-Golf SE, '04 Sequoia SR5, '00 GTI 1.8t
      12-07-2018 07:21 PM #24
      Quote Originally Posted by Mr Roo View Post
      Your last statement is false. All vehicles sold in the US have to meet the DOT and FMVSS safety standards. IIHS is not a safety or regulatory agency. They are an industry group who represent their constituents- the insurance companies. They can make up any damn test they want and set their own criteria. It doesn’t mean squat. Their only objective is to set guidelines to allow insurance companies reasons for charging some customers more money for their policies.
    26. Senior Member
      Mar 24th, 2001
      28,780
      12-07-2018 07:34 PM #25
      "Brodozer" headlamps may also be given poor ratings on by the IIHS for having too much glare.
