Fourtitude.com - Touareg wont start
    Results 1 to 2 of 2
    1. n00b
      Oct 24th, 2018
      LONDON
      5
      VW TOUAREG 3.0 V6 TDI
      10-24-2018 05:52 PM #1
      I have an injector that makes noise, I decided to change it and I tried to see with the Chinese vcds the codes at the injectors. During this time the software was blocked and the Touareg did not start anymore. It does not show any error. I tend to think it's the kessy block. you have any idea what we did, because after that I reprogrammed all three keys and it does not start.
    3. n00b
      Oct 24th, 2018
      LONDON
      5
      01-15-2019 04:06 PM #2
      Hi everyone! Finally, I find the issue after so long time. It's was electrical fuel pump. Its first time when I have met this situation. Never happen before, fuel pump to stuck suddenly. I change the fuel pump and after that, I removed all the air from the injection system to increase the fuel pressure. A the end the car started. Thanks very much, everyone for your help! screwy:
