Fourtitude.com - Battery Acid Damage
    Results 1 to 4 of 4
      May 22nd, 2015
      Indianapolis, IN
      137
      1983 Rabbit 2-Door Diesel LS 1.6L (JK) with AC - Sandstone Metallic (LE1Y)
      09-05-2018 01:34 PM #1
      Looks like a battery exploded under the hood sometime before I bought my 83 Rabbit about 2 years ago. I'm thinking baking soda and water isn't going to do much to clean/neutralize it after this amount of time?
      I'm looking for advice on 2 areas:
      1. Exterior fender. There are a few drip lines that are now white/chalky. I've cleaned the entire panel with soap and water but the drip lines are still there after it dries. What grit sand paper (or something else) should I use to try to get those drips to fade from the clear coat. This is assuming the acid has only damaged the clear coat.
      2. Engine bay. I can see parts of the paint look darker and rust is likely already there because the acid is beyond the surface/clear coat. I will likely strip the affected area, treat it and paint it. Until then, what steps should I do to keep it from getting worse? I've read where W-D40 or petroleum jelly will help stall the rust.
      Thanks.
      May 22nd, 2015
      Indianapolis, IN
      137
      09-06-2018 08:58 AM #2
      Pics for reference.
      Nov 3rd, 2017
      Versailles Missouri
      302
      1982 vw rabbit pickup 1.6 turbo charged diesel, 1997 vw jetta gls swapped in built 1.6 turbo diesel
      09-10-2018 11:40 AM #3
      Looks like coolant leak to me, not battery.
      Sent from my KYOCERA-E6790 using Tapatalk
      May 22nd, 2015
      Indianapolis, IN
      137
      02-21-2019 10:16 AM #4
      I didn't see your post back in September.
      Thanks.
