Fourtitude.com - FS: 2004 Audi RS6 - Toronto, Ontario, Canada
    1. Junior Member alexandru.andrus's Avatar
      Aug 12th, 2005
      87
      07-20-2018 04:28 PM #1
      2004 Audi RS6 Blk/Blk/Carbon Fiber
      Price: $21,000CAD ($17,000 USD)
      Body
      - perfect shape, never any accident, no dents, no rust
      - never winter driven
      - I had it undercoated regularly (www.rustcheck.com)
      - both mirrors are in perfect shape and have no stains (I got new ones last year at $400 each)
      Interior
      - no dents, cracks or rips, the interior is in very good shape and I have both OEM summer and winter mats
      - sound system is perfect and I also have the iPod/mini-jack connector
      - I have two remotes for the car
      - A/C climate control works perfect
      Tires/Wheels
      - The rims on now are OEM RS4 19in rims and I installed new Yokohama summer tires two months ago
      - I have the original 18in rims (with the car's VIN #) and they have new winter tires on them (never used)
      Engine
      - no problems at all, no check engine codes (I have a VAG-COM)
      - the car has a stage 1 chip
      - no oil leaks, boost leaks or vacuum leaks
      - in Aug 2017 I installed the following: iridium spark plugs, OEM coil packs, two OEM MAFs
      - I install new PCV valves every year to prevent oil leaks
      - I only use Royal Purple 5w40 with OEM oil filters every 7k-8k
      - I change all the filters (engine/cabin) twice a year
      - I changed the fuel filter at 160k
      - the last timing on the car was done at 150k, I already purchased the complete kit purchased for the next service
      - I installed new engine mounts last spring (http://www.apikol.com/index.php/prod...or-mounts.html) and I also purchased but didn't install yet (https://store.034motorsport.com/snub...-audi-rs6.html)
      - I also installed the Wagner turbo hose kit
      Note: I regret replacing the engine and transmission mounts, the old ones were ok I was trying to be preventative because of the mileage of the car, the new ones are good but I wasted money.
      Transmission
      - the transmission shifts perfectly and it has no codes and no leaks, I had it rebuilt over a year ago at http://www.torautotrans.com/ and I got an upgraded torque converter and upgraded internals (I have the invoice)
      - I installed just a few weeks ago (https://store.034motorsport.com/tran...s4-s6-rs6.html)
      Suspension
      - OEM except for https://www.hotchkis.net/product/200...rt-suspension/ which I installed one year ago
      - no leaks in the suspension, car had the DRC recall done in 2012
      - control arms are in good shape
      - last alignment was about one month ago when I installed new tires
      - there is 0 play in all four wheels, no loose bushings/tie-rods/ball joints
      Brakes
      Front - I just installed two months ago brand new rotors and pads (Zimmerman rotors, Stoptech Street pads) and I also bled the whole system, the brakes are perfect
      Rear - new rotors were installed one year ago, and I just installed new pads (StopTech Street) two weeks ago and of course also bled the rear lines
      See link below for pics:
    3. Member A.C.'s Avatar
      Sep 30th, 2001
      409
      2004 VW GLI, 1999 GLX
      07-20-2018 08:14 PM #2
      Beautiful ride. GLWS!
