Fourtitude.com - Rear bias Haldex "Hack"
    Results 1 to 7 of 7
    1. Junior Member
      Jan 19th, 2017
      Austria
      62
      Audi TTRS 8J Coupe, Audi RS4 B5, Audi A4 B8 Quattro, SOLD: Audi S4 B5
      06-03-2018 04:53 PM #1
      It’s simple: If you want some rear bias power delivery with a Haldex AWD, make sure that the rolling circumference of the rear wheels isn't smaller than on the front wheels!
      The problem is, in most cases I've seen, the recommended tire pressure has led to exactly that.
      You can have the most aggressive Haldex controller on the planet; smaller rears leads to front wheel bias.
      In order to get the most out of the Haldex, it is important to keep the tire rolling circumference between front and rear as equal as possible (within 0,5%).
      You can set the correct circumference via tire pressure (up to a certain point).
      If you want some rear bias, make sure you have 0.2-0.5% more circumference at the rears.
      Often this is neglected and simply put the manufacturer's recommended pressure in the tires.
      (That’s basically a safe way)
      But often tire tolerances, wear, axle loads, etc., cause big deviations.
      That may sound exaggerated now:
      You should always measure the circumference!
      The easiest way is to mark both tires with a soluble paint or something and move the car (straight) one tire rev.
      Then measure the distance between the marks.
      In any case the difference between front and rear should be in the range of +/- 0.5%.
      Anything beyond this range just increases the stress in the powertrain and may affect the ESC/ABS!
      At least that’s my experience, we already done this on some cars and it really improved the rear engagement...
      I'm not an expert but I try a (very simplified) explanation:
      Due to the smaller circumference of the rear wheels, the rear differential runs a bit faster than the cardan shaft. When the Haldex clutch engages now, the closing force of the clutch slows down the rear axle. The rear wheels are pulled by the front wheels. If the engine torque exceeds the closing force of the clutch, the distribution changes to a even more front wheel bias.
      However, if the circumference of the rears is slightly larger, the rear axle will now be accelerated by the closing force of the clutch. The rear wheels are pushing up to the point where the engines torque again exceeds the closing force of the clutch.
      When that will be, depends very much on the car and the Haldex controller.
      This results in a rear bias power delivery when accelerating.
      Just give it a try...
      2010, Audi TTRS, MT/500+ Hp, Hperformance (Germany) /Sinter clutch/Single mass flywheel/KW Clubsport 3-way/KW sway bars/Front upper strutbrace/Front H-brace/Powerflex bushings/Competition Haldex controller/Audi RS6 C7 Wave brakes/Recaro Pole Position/OZ Ultraleggera HLT 19"/Michelin Cup2/Wavetrac Rear LSD https://ibb.co/cpumSG
      Jan 8th, 2012
      the netherlands/europe
      338
      2.5 T corrado syncro 1997/4 motion 2018
      06-05-2018 11:11 AM #2
      Quote Originally Posted by ICETER View Post
      The easiest way is to mark both tires with a soluble paint or something and roll the car (straight) one tire rev.
      This is very interesting, and the explanation sounds reasonable i.m.o..
      Did you posted this thread also on the golf R forum?
      I think a lot of those guys will give your suggestion a try.
    4. Junior Member
      Jan 19th, 2017
      Austria
      62
      06-05-2018 03:53 PM #3
      Quote Originally Posted by stef 4x4 View Post
    6. Member Iku's Avatar
      Mar 11th, 2009
      Saskatchewan
      1,792
      MKIV VR Jetta on Accuair, MKIV R32 Turbo
      06-08-2018 02:18 PM #4
      I will be trying this on two different Haldex equipped vehicles soon. Interesting idea by rolling the car and comparing.
    7. Junior Member
      Jan 19th, 2017
      Austria
      62
      06-09-2018 11:06 AM #5
      Quote Originally Posted by Iku View Post
      Let us know your results!
      May 11th, 2019
      AK
      109
      2017 Alltrack S MT
      08-07-2019 11:01 PM #6
      +1. I will add as an AWD noob that I found out from first Discount Tire then crosschecked with my VW Mastertech that the combination of wear on OEM Falkens and original settings was enough to trigger a false low tire inflation alarm, easily fixed by resetting at "dash tv screen", and the resetting required again with new tires.
      So a small difference under that 5% limit (not enough to trigger the light)
      but enough to negatively affect best AWD performance seems entirely plausible and worth checking out.
      Waiting for the cognoscenti...
      With my thanks again for your shared wisdom!
    9. Member A3SBQ's Avatar
      Aug 26th, 2013
      Norway
      211
      Audi A3 2.0TSI quattro + DSG
      08-08-2019 01:08 AM #7
      Great info.
      Is this only possible with greater air pressure to the rear tire? Or can we use a staggered setup like the RS3 have from factory but we revers the setup to wider rears?
      Sent fra min SM-G955F via Tapatalk
