Fourtitude.com - We are putting a 3.6L VR6 into our 1985 Golf!
    Page 1 of 3 123 LastLast
    Results 1 to 25 of 59
    1. 04-10-2018 06:07 PM #1
      The car already has a obd2 AAA 12V swap so the 3.6L will reuse axles/Wavetrac equipped 5 speed trans/motor mounts/subframe/crossmember + more
      see my full thread on MK2 forums here https://forums.vwvortex.com/showthrea...#post110617209
      BIG THANKS to Frank aka G60ing for his 'how-to' thread .. its a huge help! link: https://forums.vwvortex.com/showthrea...ions-amp-Links
      ok I have a new purpose at the yards, 1st step 24V MK4 accessory bracket and belt drive parts
      found one!
      much needed junk
      a little 12v to 24v comparison
      the local dismantler of the 3.6L VR6 gave me ECU and engine harness with the motor but no accelerator pedal and chassis harness etc, so the hunt is on
      fsi pedal
      other bits such as in tank fuel pump (same on 2L and 3.6L) & the fuel control module ...which is different between motors but they didn't even charge me for it hahaha
      playing around with Ladenhueter List (shelf warmer parts) almost got a custom 3.6L downpipe (needs a merge collector etc..)
      when it rains in socal we just can't deal
      my first 3.6L junkyard find, need a MAF and 3.6 fuel control module, wiring, dipstick etc..
      bingo! the warehouse is turning into a junkyard
      got some OEM goodies from Autotech
      MK5 GTI fuel filter, shop here: http://autotech.com/mk5-20t-fuel-filter.html
      24V MK4 no a/c belt, shop here: http://autotech.com/24v-vr6-2-8l-no-ac-belt.html
      (edit: 5 wire sensors are needed for downpipe) Bosch 4 wire 02 sensors for after cats, shop here http://autotech.com/universal-bosch-...en-sensor.html
      more junking
      gathering the last bits of my wire harness before it goes to Matt @ Eurokraft https://www.facebook.com/eurokraftperformance/
      beetle obd port
      ce2 plugs f/g1/g2/z1 from a mk3
      also got this corrado 02a trans support to help handle the big power once its in
      found another passat 3.6L (this time 4-motion) about an hour away, luckily it was a 40% sale so I went a little overboard
      stripping it down
      got tons of hoses that the dismantlers cut and a bunch of spare goodies (hpfp, injectors, solenoids, sensors, etc)
      cutting my 24V MK4 acc bracket to clear fsi injector 1
      the 3.6L alternator took some 'massaging' to fit and not hit the injector, thanks Frank (G60ing) for the build thread to bypass alot of the trial & error
      everything bolted up with MK4 24v non a/c belt
      also the smaller 3.6L belt tensioner pulley was used on the MK4 24V tensioner body
      some little 304SS downpipe fab goodies arrived: merge collector, cat flange and 02 sensor bungs
      Here are some of the existing Autotech parts we are using to get going on the downpipe:
      two MK2 16V/8V header flanges to mate to the exhaust manifold (just had to drill them out to accept the bigger 3.6L M10 studs):
      shop here http://autotech.com/spare-mk2-8v-16v...nc-plated.html
      and 2.25" flex couplers, shop here http://autotech.com/vibrant-2-25-x-4-flex-coupler.html
      Got our ECU back from S&P
      Stage 1 Malone Tune and IMMO defeat for the swap!
      thanks for the quick turn around guys
      S&P site: http://s-pautomotive.com/custom-parts/
    3. Member G60ING's Avatar
      Jun 27th, 2000
      Annapolis Area MD
      15,811
      04-10-2018 09:39 PM #2
      Great job and thanks
    4. 04-12-2018 01:03 PM #3
      Very cool!
      Looking forward to seeing it completed
    6. 04-12-2018 01:31 PM #4
      intake manifold before cleaning
      manifold after.
      debating if I should paint it black and/or re-badge to MK3 'VR6' badge or 'R36' badge, sucks the 'V6' cannot be removed without causing a hole in the plenum
    7. Member G60ING's Avatar
      Jun 27th, 2000
      Annapolis Area MD
      15,811
      04-16-2018 07:40 AM #5
      I like the Audi panel. Ideally I’d have someone 3D print a panel with R36 or 3.6 VR6 FSI or something like that. I figure I can always go back and do it later.
    8. 04-16-2018 02:20 PM #6
      Quote Originally Posted by G60ING View Post
      it does look good, I wonder how it attaches?
    9. 04-16-2018 03:26 PM #7
      so Matt from Eurokraft notified me that my engine harness was missing an important piece (that the dismantler must've cut) so I had to trek back out to the middle of nowhere to the next 3.6L (san bernardino)
      I figured to play it safe I would just pull the entire harness
      after a couple of hours of ripping it apart I was left with this
      and grabbed all of this for $41
      and got some important lower coolant hoses/junctions/check valve for $3
    10. 05-01-2018 03:58 PM #8
      time to clean up some carbon buildup!
      before, eeeewwwww
      rigged the shop-vac up to some hoses, poked a hole for the media blaster (using walnut)
      fun stuff, glad the shop vac is keeping the gunk out of my face
      after about 30 mins... still some more work to go obviously
    11. Member G60ING's Avatar
      Jun 27th, 2000
      Annapolis Area MD
      15,811
      05-01-2018 09:41 PM #9
      Fun stuff
    12. 05-07-2018 07:30 PM #10
      got some goodies, cheapo B6 accelerator pedal overlay (ebay: from china) to match my TT style pedals....and Audi Q7 intake manifold cover from an Audi dismantler
      getting the manifold prepped and de-badged for a rattle can paint job
      high temp flat black
      calling it done
      swapped out the thermostat
      and the H20 pump
      getting the 3.6L oil cooler off so the front motor mount won't hit, smaller spare 12V cooler and cap/stud going on
      was able to fit the 3.6L water hoses to it w/o issue
      last bit of progress from the weekend was getting the injectors out for cleaning/testing
    13. 05-10-2018 12:44 PM #11
      did a little heater core bypass, found a 180 hose at pep boys and a coupling reducer at home depot to adapt to the smaller hose off the hard pipe
      should do the trick
      also cleaned the carbon some more, I'm calling it a day on this one
      started like this
      ended like this
    14. 05-17-2018 03:20 PM #12
      changed out some spark plugs, shop here: http://autotech.com/passat/b6-3-6l-2...park-plug.html
      also I decided to get a new valve cover (comes with new gasket, bolts, bolt o-rings, and of course a new PCV oil separator that are prone to fail) shop here http://autotech.com/passat/b6-3-6l-2...lve-cover.html
      I've added a bunch of OEM 3.6L related things online here http://autotech.com/passat/b6-3-6l-2006-2009.html]http://autotech.com/passat/b6-3-6l-2006-2009.html[/url]
    15. 05-24-2018 01:39 PM #13
      clearing up some engine bay space with an after market slim fan setup with alloy shroud (mk3 VR6)
      Also it will simplify things with my 3.6L harness
      got my tracking # from Matt @ EuroKraft - I'm really excited about this harness, super plug and play
      also got the first little portion of the downpipe going thx to Claudio
    16. Member
      Jul 4th, 2016
      Palmyra, PA
      253
      2014 FiST, 92 Corrado 3.6
      05-24-2018 03:08 PM #14
      Looks good so far have you mocked up the engine in the bay to look for clearance issues? I know G60ing said the original 3.6V crank pully is too thick for a corrado bay unless you massage the frame rail
      Former username: Magics5rip
      Corrado 3.6 build thread
    17. Member G60ING's Avatar
      Jun 27th, 2000
      Annapolis Area MD
      15,811
      05-24-2018 05:12 PM #15
      Quote Originally Posted by choobs View Post
      The stock Touareg crank pulley won’t fit. The Passat crank pulley will fit. I just picked up a forged crank and Touareg crank pulley so I need to figure out whether I will try to get fluidamper to make a new pulley or machine down this pulley or get a passat pulley.
    18. Member
      Jul 4th, 2016
      Palmyra, PA
      253
      05-24-2018 09:40 PM #16
      Thanks for the info, starting to put together a parts list here so these details will most certainly help
    19. Member G60ING's Avatar
      Jun 27th, 2000
      Annapolis Area MD
      15,811
      05-25-2018 02:10 PM #17
      Quick update, the forged crank passat crank pulley is almost the same as the touareg pulley which doesn't fit. I might just have to have my touareg one machined.
    20. 05-30-2018 12:23 PM #18
      the forged-crank bottom end looks cool, too bad no fluidamper solution for that yet
      as for my build I got the passat BLV pulley and a fluidamper pulley on the shelf if needed (I was planned on tossing it on later to compare drive-ability improvements)
    21. 06-19-2018 12:55 PM #19
      Making some progress on the 3.6L now
      thanks Charles (-camber) and Bozzani VW for the help on the injector seals https://www.bozzanivw.com/
      shop for 3.6L injector parts here:
      http://autotech.com/passat/b6-3-6l-2...ctor-seal.html
      http://autotech.com/passat/b6-3-6l-2...or-seal-2.html
      so fresh and so clean!
      figured I'd pull the HPFP and inspect the internals and the oil seal
      glad I checked because the internals were so gummed up I was unable to remove them from the cap!
      luckily I had a spare cap and Autotech Internals - shop here http://autotech.com/autotech-high-vo...-2-0t-fsi.html
      assembled! I also threw on a new pump to cyl head gasket - shop here http://autotech.com/passat/b6-3-6l-2...nder-head.html
      time to toss back on the intake manifold, new gasket going on, shop here http://autotech.com/passat/b6-3-6l-2...ket-06-07.html
      starting to look like a motor again
    22. Member turboit's Avatar
      Oct 4th, 2001
      Delaware
      4,249
      '07 Audi S4 Avant, '93 Corrado SLC
      06-20-2018 08:04 PM #20
      Awesome! I'm inspired to start back up on my build again
      Sent from my Pixel XL using Tapatalk
    23. Member jddaigle's Avatar
      May 30th, 2003
      Denver, CO
      7,118
      2008 Passat Wagon VR6 4motion, 2013 FIAT 500 Sport
      06-21-2018 12:18 AM #21
      As an OEM 3.6 owner I love seeing these comprehensive overhauls. It’s a pretty goddamn stout motor. I hope it’s got a long life ahead of it in the aftermarket!
      - Jeff
      B6 Passat 3.6 & 4motion Resource Thread
      Now: 2008 VW Passat 3.6 4motion Wagon, 2013 Fiat 500 Sport
      Then: 1987 Volvo 745GLE, 1989 Volvo 745GL, 1994 Volvo 940T, 1995 Infiniti G20, 2000 VW Passat 1.8T, 2001 VW Jetta Wolfsburg Ed (x2), 2004 VW Golf TDI, 2006 Jetta TDI
    24. 06-21-2018 11:43 AM #22
    25. 06-27-2018 07:09 PM #23
      here's the "putting stuff back together" pics
      routing the manifold vacuum tubing and harness for injectors etc.
      I put a cool looking 08 3.6 Passat dipstick in (junkyard)
      throttle body, vacuum, evap stuff going back on
      plugged all the coolant hard lines for looks since B6 passat runs passenger coolant bottle and I'm going to re-use a drivers side early MK2 bottle
      ebay'd some 5 wire 02 sensors from a similar donor car
      Heres the original 3.6L alt/a/c harness and a custom relayed slim fan harness (from Matt at Eurokraft) It runs off the original MK3 VR6 fan switch and will be single speed
      Here's where Eurokrafts hard work really shows...the custom 3.6L to Ce2 body harness
      so on the right is all the ce2 fuse box connectors I junkyarded and a nice Tach adapter box that Eurokraft sourced
      up top will be the FSI fuel controller green box wires (the only 2 wires that will not be 'plug and play') - I think I can handle that
      top left is original 3.6 coolant switch to ECU
      bottom left is MK3 02A reverse and starter connectors
      the rest is Passat 3.6 accelerator pedal plug, 3.6 02 sensor plugs (just 2 not 4) ECU was tuned to match the deleted 02 sensors, 3.6 MAF plug, OBD port, MK3 02A VSS connector, 3.6 connector to alternator harness etc..
    26. 07-13-2018 07:39 PM #24
      Its go time!
    27. Member
      Apr 21st, 2009
      Seattle
      1,415
      07-14-2018 01:32 AM #25
      Awwwww yeaaahhh
