Selling my Neuspeed Power Module, I had it on my MK7 R for about a year and it served me very well. Great plug n play add on if you don't want to void warranty.. Now my lease is up deciding on keeping car and going to upgrade to a real tune now =)$240 shipped anywhere USA.
Features:
Two position switch:
+5 PSI Increase
+7 PSI Increase
Power Gain - 91 Octane Fuel (higher gains obtainable with better octane fuel):
+5 PSI / 38 HP
+7 PSI / 57 HP
Increases boost by modifying the charge pressure and map sensor readings
Allows ECU to remain in control of boost
The actual boost is increased by a precise amount
Boost is increased in a gradual, progressive fashion
Uses the closed loop control of the ECU to increase boost
Readings in the vacuum region are stock
No effect on cold start
No effect on warm-up
No change to idle, cruise and moderate acceleration modes of operation
Retains stock ECU programming
No change to factory ECU programming, communication or safety protocols
No ECU TD1 code to void manufactures warranty
Not effected by ECU reprogramming by the dealer
Makes use of existing ECU programming for higher boost levels
Correct Air/Fuel mixture maintained from the wide band O2 and closed loop mode of the ECU
Ignition timing optimized by the ECU
Easy Installation
Plug-and-play intercept at Boost and MAP sensor connector locations
Installation or removal can be completed in a few minutes (depending on model)
No trace Power Module was ever there after removal
Power Module can be sold or installed on another vehicle of the same engine type.
One Year Warranty
Notes:
Fits: 2015-UP Audi S3, TTS and 2015-UP VW Golf R.
CARB Pending. Emission testing to be California compliant and any states that follow.
Designed and Engineered Camarillo, California. Made in USA
Features:
+5 PSI Increase
+7 PSI Increase
+5 PSI / 38 HP
+7 PSI / 57 HP
Easy Installation
One Year Warranty
Notes:
