Fourtitude.com - LED DRL / Fog Lights?
    Results 1 to 7 of 7
      Feb 25th, 2011
      Canada
      278
      2006/Audi/A3/2.0T
      02-28-2018 01:11 PM #1
      So has anyone done this? I have a set of LED lights that are pulling about 12W. As you can guess, that's not enough power to make the dash warning go away since the stock H7 bulbs are 55W. So I put in 2x 5ohm 50W in series (=10ohm 100W) and that is still enough power to make the dash warning go away but the load resistors are still too hot to just stuff in the back of the assembly. I'd really worry about melting wire insulation. I've thought about letting them dangle in air but I worry there would be too much vibration and the wires will eventually break. Most guys that do this just screw the resistors to metal part under the hood but there is no metal to be found in behind the fog light housing. My next thought was to get 2 more load resistors and see how low I can get the power to keep the dash warning off as well as split the power over 4 resistors instead of 2. People that do this mod for turning flashers rarely worry about heat dissipation because the duty cycle is like only 50% and they aren't on long enough to heat up anyhow.
      Apr 21st, 2010
      Lake Tahoe
      328
      2008 A3 VRT
      03-04-2018 12:01 PM #2
      I put in LED DRL in place of the halogens. I recoded the central Electronics module 4 LED drl and also have the blinker function where the side with the blinker active DLR turns off
      Sent from my XT1650 using Tapatalk
      Current Rides:
      2000 Toyota Celica GT-S Supercharged - 2008 Audi A3 3.2 - 2003 Audi RS6 Avant - 2008 Audi TT 3.2 - 2002 S6 Avant Manual w/ S8 engine - 1990 Audi Coupe Quattro(SOLD) - 1993 Toyota MR2 Big Turbo(SOLD) - 2000 Audi S4 Stage 3(SOLD) - 2001 Audi S6 Sedan (SOLD)
      Check Out My Facebook
    4. Member kevichar's Avatar
      Nov 15th, 2002
      Mississauga Ontario
      226
      06/Audi/A3 premium 6 spd
      03-08-2018 02:21 AM #3
      Quote Originally Posted by korben007 View Post
      I have retro projectors and the light out is bad as cheap hids and ballasts. Id like to go LED. But i heard it cant be done in projectors. If I use the high beam halogens as LED wondered if that could work? What set up and type of LEDS you use? Brighter than halogens?
      Sent from my LG-M470 using Tapatalk
    5. Member
      Apr 21st, 2010
      Lake Tahoe
      328
      2008 A3 VRT
      03-08-2018 10:19 AM #4
      Quote Originally Posted by kevichar View Post
      On the bi-xenon lights the inside reflector does nothing but DRL. So I'm not concerned with anything besides that. Hi and low beam are all done in the outside projector. To avoid error codes the central Electronics had to be coded to LED DRL.
      Current Rides:
    6. Member kevichar's Avatar
      Nov 15th, 2002
      Mississauga Ontario
      226
      03-08-2018 12:36 PM #5
      Ah is yours a newer model? Mine never came with LED'S Mines an 06
      Feb 25th, 2011
      Canada
      278
      2006/Audi/A3/2.0T
      03-28-2018 05:51 PM #6
      So I think I found the perfect compromise for the load resistors on the fog LED's
      I used 4x50W resistors on each LED to split surface area up and help keep it cooler. The 4 I used were 2x 5ohm and 2x 2.5ohm. That's 15ohm when in series (but parallel to the LED) and it brings up the power just enough to fool the warning light. Mind you there is still a few seconds after a cold start where you get the warning but it goes away pretty quick. Bench testing at 14V kept the resistors warm but no where near the burning hot that you get with a single 5ohm.
    8. Member tylaughter's Avatar
      Aug 31st, 2010
      Orange County
      200
      2014 VW JSW; 2001.5 Audi S4 Nogaro
      07-01-2018 05:02 AM #7
      Which bulbs are those?
      Sent from my iPhone using Tapatalk Pro
