Fourtitude.com - My Coastal Range Rally story, or: Roadkill is more fun to watch than live.
    Page 3 of 4 FirstFirst 1234 LastLast
    Results 51 to 75 of 76
    1. Member Bad Rabbit Habit's Avatar
      May 5th, 2005
      Manteca, CA
      3,946
      A Rabbit with a snail.
      09-21-2020 08:12 PM #51
      Passed 1500 miles! Did some more research, found instructions for a different adjustment method. It was to make sure you have no knock, either by race gas or retarding timing. Set timing to locked at 10. Went through the rev range, not getting into boost, turning up the sensitivity until I got false triggers, then turning it down a touch. Then, set the timing back to the advance map. Ended up pulling out a bunch of timing under boost. I think the sensor still too sensitive, but I am confident it is safe. Had some weird spots in the timing map, so it now pulls smoother too.
      Also, turned up the boost to the full 1 bar I was running before. It feels a little down on power, but I took 8 degrees of timing out under boost.
      On a closed course, I used the speedhut gauge to clock a 1/4. [email protected] Previously did a 14.1 at 102 at 1 bar. According the internet 1/4 calculators, I am short 30whp. Can’t wait to get to the dyno, and turn up the wick.
      -Jon
      ig:badrabbithabit Formerly known as: monoaural
    3. Member Bad Rabbit Habit's Avatar
      May 5th, 2005
      Manteca, CA
      3,946
      10-07-2020 09:51 PM #52
      Ready for a paradigm shift? Or at least I hope you are sitting down. I am pulling the turbo motor out of the rabbit, and going 16v NA.
      Did the two one day rallies the DWA guys threw on this fall. First real driving I have done with the rabbit this year.
      Coming off the covid reset, plus spending time with the mostly stock e30, I apparently grew up a bit. On the rally, I never needed more than half throttle, or anywhere close to redline. I did do it a few times, I am not a monster. Also, on the second rally, I had a bunch of issues. Not all related to having 200 whp motor in a rabbit, but it did spark the desire to simplify. Also, I want to turn up the boost, and the chassis really isn’t up for it. So, I am buying a 2.0 16v with a 1.8 head, euro cams, ect this weekend. End goal is ITBs. Initial step will be to convert to obd1 aba management, as I already have most of the parts, and most of those that I don’t are needed for megasquirt when I get ITBs.
      This also leaves me with a freshly rebuilt turbo motor with no place to go. Oh wait:
      So, fox will the the turbo motor, converted to rwd, and boost turned up, for childish stuff like this:
      It was originally going to get a BEAMS swap, but a turbo motor is better for hooning, and NA is better for driving.
      -Jon
    4. Member kiznarsh's Avatar
      Apr 10th, 2007
      SoCal
      4,684
      987.2 | GTI
      10-08-2020 12:09 AM #53
      This "growing up" you speak of...what's it like?
    5. Member
      Dec 22nd, 2008
      4,018
      10-08-2020 02:33 AM #54
      What was the deal with not fitting in the Rocco?
    6. Member Bad Rabbit Habit's Avatar
      May 5th, 2005
      Manteca, CA
      3,946
      10-08-2020 07:43 AM #55
      Quote Originally Posted by thegave View Post
      First car I haven’t fit in. Owned a NA miata, which had more headroom.
      I sit very close to the wheel for my 6’1” height. I have to roll the seat too far back to be comfortable driving. And no helmet, so no autocross, and track days. And having the fox and ‘rocco next to each other, the fox is a way better start for a project.
      -Jon
    7. Member Stromaluski's Avatar
      Jun 15th, 2005
      Greenville, SC
      3,436
      10-08-2020 09:40 AM #56
      Turbo ABA Fox? Yes, please!
    8. Member Bad Rabbit Habit's Avatar
      May 5th, 2005
      Manteca, CA
      3,946
      10-14-2020 09:26 PM #57
      Obtained a 16v. It’s a 2.0, 1.8 head, Euro Intake cam.
      Made some orders, first time ever having headers.
      Also stacking parts for aba obd1 management. Using a SPA turbo crank wheel, auto passat throttle body, and a Techtonics chip designed to run a 16v.
      -Jon
    9. Member
      Dec 22nd, 2008
      4,018
      10-14-2020 11:56 PM #58
      But you know what would really make it scream? Throttle bodies.
      Do it. Just do it.
    10. Senior Member LT1M21Stingray's Avatar
      Sep 13th, 2006
      Somewhere close to Lyon Mountain.
      24,490
      SR71 C30 t53a/b/b
      10-15-2020 12:06 AM #59
      Quote Originally Posted by Bad Rabbit Habit View Post
      Hey, that's a euro 50mm intake manifold!
    11. Member
      Dec 22nd, 2008
      4,018
      10-15-2020 12:22 AM #60
      It’s two. The one on the motor is a 50mm as well
    12. Member Bad Rabbit Habit's Avatar
      May 5th, 2005
      Manteca, CA
      3,946
      10-15-2020 07:35 AM #61
      Do it. Just do it.
      I will. Just not yet. It’s only going to cost me ~150 of “wasted” money to run the obd1 stuff right now. Throttle bodies is gonna cost 2k+ unless I find deals. And deals take time.
      Quote Originally Posted by LT1M21Stingray View Post
      The one on the motor is a 42mm. The 50mm has bigger cutouts for the plug wires, and the plenum doesn’t have a step down to the runners. At least I hope the one on the motor isn’t a 50mm. I didn’t measure it.
      -Jon
      Nov 8th, 2002
      Whitefish, MT
      11,481
      17 JKU 08 Tundra 89 325i
      10-15-2020 08:11 AM #62
      I approve of this direction change.
      <------ Former 16V Rabbit owner.
    14. Member
      Dec 22nd, 2008
      4,018
      10-15-2020 11:06 AM #63
      Oh I thought 42mm runners have no cut-outs at all, but I see the step down. Hm
      Scratch the throttle bodies. Do this
      https://www.ebay.com/itm/Oettinger-1...-/124368400389
    15. Member cdncrdoguy's Avatar
      Jul 22nd, 2002
      Toronto
      582
      90 Diamond Silver Corrado/06 WRX Wagon - Gone but not forgotten 83 RabGti 91 VW Jetta99 Subaru 2.5RS
      10-15-2020 11:28 AM #64
      Having never owned a vehicle with the 16v engine but always wanting to (especially after reading about Jason Cammisa's Cabriolet) I am looking forward to seeing how this plays out.
      I was kicking around the idea of picking up a Cabrio and then changing the engine to have the 16v head to mimic the engine offered in Europe. This build might inspire me to keep looking.
      Sent from my Pixel 3a using Tapatalk
      Quote Originally Posted by MAC View Post
      Mecum just sold a '64 21 window for $170,000 at their Indianapolis sale. No word on how many later buses it was made out of.
    16. Senior Member Iroczgirl's Avatar
      Feb 17th, 2007
      Bend, OR
      34,177
      Hot hatchback coupé heaven
      10-15-2020 11:56 AM #65
      Once you go 16v, there's no going back!
      Meanwhile I think I have close to enough free cash to turbo my Rabbit.
      ...but then it was supposed to be turbo from the get go.
    17. Senior Member LT1M21Stingray's Avatar
      Sep 13th, 2006
      24,490
      SR71 C30 t53a/b/b
      10-15-2020 12:01 PM #66
      Quote Originally Posted by Iroczgirl View Post
      Is it?
      I have to jump start my 16V build project then.
    18. Senior Member Iroczgirl's Avatar
      Feb 17th, 2007
      Bend, OR
      34,177
      10-15-2020 09:31 PM #67
      Is it?
      A Scirocco with a PL is fun, but one with a nice 9A is the bee's knees. Still makes me smile every time I take it down empty twisty roads.
    19. Member
      Dec 22nd, 2008
      4,018
      10-15-2020 09:34 PM #68
      Is it?
      Dibs on your stroker.
    20. Member 3WheelGTi's Avatar
      Aug 29th, 2001
      Huntington Woods, MI occasionally
      7,239
      2003 Porsche 911 C4S, 2020 Ford Mustang GT, 2018 Jeep Grand Cherokee, 1982 VW Rabbit
      10-16-2020 07:31 AM #69
      Hmm, I like the change and nearly did the same.
      After my oil splosion at the track in July, I surveyed the damage to find a trashed head on my ABA.
      Then I must have hit my adult head really hard as I am building it back with high compression pistons and a super wicked TT 298 cam in an early OBD 1 head. Still 8 valves though.
      Hoping for roughly the same power...
    21. Member Bad Rabbit Habit's Avatar
      May 5th, 2005
      Manteca, CA
      3,946
      10-16-2020 07:55 AM #70
      Quote Originally Posted by cdncrdoguy View Post
      Jason has a very large part in my decision to do this. A couple conversations with him got me going down this rabbit hole.
      I’m still nervous it won’t be enough power. I have certainly gotten used to boost. Drove the e30 to work yesterday, and enjoyed it. This should have a slightly better power to weight than that. So, it should be ok, but I have had a turbocharged rabbit for over three years.
      -Jon
    22. Member cdncrdoguy's Avatar
      Jul 22nd, 2002
      Toronto
      582
      10-16-2020 09:12 AM #71
      I can completely understand where you are coming from as I daily drive a stage 2 WRX wagon and have had my G60 Corrado for nearly twenty years with the usual mods to it. But I still remember the way my old N/A 83 GTI handled and pulled with just a 272 cam, header and exhaust. With the 16v as your starting point, and if you get similar power to what Jason is getting, I bet you will be pleasantly surprised.
      My search is still ongoing for the right Cabrio. We don't have a lot of them in my market and most of the ones that come up are sketchy. When j started looking, I worried that the 2.0 litre would be disappointing but did not want to go with force induction (I already have a turbo and supercharger to worry about), I wanted it to be simpler like the GTI. That got me looking into what upgrades were available for the 2.0. When I saw the 16v hybrid option it immediately got my interest, since I always wanted to see what the 16v was like to drive.
      Looking forward to your updates.
    23. Member Stromaluski's Avatar
      Jun 15th, 2005
      Greenville, SC
      3,436
      10-16-2020 09:16 AM #72
      I'm going to have to disagree. I've had TERRIBLE luck with 16vs. I've 16v swapped two cars. A mk2 jetta coupe and my rabbit truck. I'll never do another 16v as far as I'm concerned.
    24. Member
      Feb 8th, 2002
      Lincoln, NE
      2,719
      1966 Corvair | 2010 Mazda5 | 2002 Chevy 2500HD | 2017 Locost 7 | Many Subarus
      10-16-2020 10:00 AM #73
      I love this idea generally - there's a point at which a car, especially a FWD car, has too much power for the platform and it just becomes less fun. Too much stuff breaking, too hard to put the power down, too much tiptoeing around the boost curve mid-corner, etc. Getting the power curve correct for the car and the roads you enjoy is the magic sauce, and it took me too many years to figure out that "maximum possible power" wasn't the right answer for that sauce.
    25. Senior Member LT1M21Stingray's Avatar
      Sep 13th, 2006
      24,490
      SR71 C30 t53a/b/b
      10-16-2020 10:47 AM #74
      LOL, no.
      The 8V stroker stays in the mk2 Scirocco, and the newish 16V stroker will go into the mk1 Scirocco.
    26. Member Bad Rabbit Habit's Avatar
      May 5th, 2005
      Manteca, CA
      3,946
      10-17-2020 09:27 PM #75
      Apparently I should have bought a lotto ticket, instead of writing terrible things on the internet.
      No clue what happened yet. I was heading back towards Patterson, taking it slow since I was dangerously low on fuel. All of a sudden, the oil pressure light comes on. Coast to the next pull off, check the obvious stuff, nothing looks out of place. Has oil on the dipstick. Start it up, sounds like I have marbles in the oil pan. Managed to catch a ride to cell service, 15 miles away in Patterson. Where I am currently, waiting for my wife to pick me up.
      I post this in the bay area thread, and now have more info. Once it got dropped off, I decided to risk cranking it, and see if it makes oil pressure once it cooled down. It did. So, I let it idle. Seemed like it was running on three, but that may be because I was cranking it with no spark, but still had fuel, so it was a tad rich. The oil filter housing is leaking pretty badly, so that maybe part of the issue. Gonna change the oil, and cross my fingers that I can drive it 30 miles to my buddies shop with the lift. Pretty sure I am out of AAA tows now, been a rough year for the rabbit.
      -Jon
