So I got the itch again, now I’m in a 3.2 Quattro! I was playing with a B5 S4, great car and we had a lot of fun. However It was sold when my daughter was born. I have been waiting for the right car ever since, and I have found it. I always missed my old A3 so I’m very exited about this car.
It’s a completely stock, quite neglected 06 with 124k. I have big plans for this car. This will be it’s story, let’s do a build thread!
Update, 5/23/18, modification list so far!
Engine...
Factory rotating assembly.
Fluidampr.
Arp head studs.
034 oil filter housing adapter.
034 head spacer.
Super tech valves, stainless intake, inconel exhaust.
Super tech dual spring, titanium retainers.
Turbo set up...
Precision 6262, ball bearing, t4 flange, 63ar.
Tial MVR 44 wastegate.
034 Intercooler pipping.
Garret fmic, high density 600hp core.
034 billet diverter valve.
034 billet slot maf housing.
Fuel system...
034 billet fuel rail.
Bosch 850 ev14’s.
Aeromotive adjustable regulator.
Detach DW65 In tank pump.
All 6an fittings and fuel line.
Exhaust...
CTS ceramic coated exhaust manifold.
CTS 3in down pipe.
CTS 3in mid pipe.
Mounts...
034 Billet engine and trans mounts.
034 Billet Spherical dog bone.
034 Torque mounts.
Suspension...
ST XTA coilovers.
ST Camber plates.
PowerFlex black front arm bushings.
034 Billet sway bar end links, front/rear.
034 rear sway bar.
034 Billet rear upper control arms.
034 Billet rear toe links.
034 Front subframe locking collars.
034 Billet rear subframe mount Inserts.
Brakes...
Front Brembo 17Z
Rear Brembo 4 Piston calipers, with CreationsMotorsports brackets and MK5 R32 310mm rotors.
42Draft Designs wheel studs.
Wheels...
BBS CH 028, 18-8 ET 43.
Engine...
Fluidampr.
Arp head studs.
034 head spacer.
Turbo set up...
Fuel system...
Bosch 850 ev14’s.
Exhaust...
CTS 3in down pipe.
CTS 3in mid pipe.
Mounts...
034 Torque mounts.
Suspension...
ST XTA coilovers.
ST Camber plates.
034 rear sway bar.
Brakes...
Front Brembo 17Z
Wheels...
