Fourtitude.com - Let's Discuss Ceramic Coatings
    Page 6 of 9 FirstFirst ... 23456789 LastLast
    Results 126 to 150 of 202
    1. Junior Member nc_detail_garage's Avatar
      Dec 26th, 2017
      Charlotte
      91
      B9 S4 / Levante
      07-11-2019 05:33 PM #126
      Quote Originally Posted by vwlifer27 View Post
      So, I just had my 2019 GTI professionally coated. Single stage paint correction, then coating. It looks great, but of course I missed a large rock chip on my lower rocker. It's so low that you need to get on your hands and knees to see it. Its a deep pit.
      I am wondering if because its so deep the coating didn't actually get in there and I will be able to touch it up? I just do not want any rust popping up from the chip.
      My installer said that any existing rock chips will be fine as the ceramic coating will seal it up as if it was a 'clear coat'. I have been reading online however, that chemicals in ceramic coating will interact with in treated rock chips and cause 'damage' (however that is just one article I read, haven't seen anything else that says this). He said it wont cause something to rust.
      Thoughts? I'm guessing I can carefully touch up any new paint chips in the future (carefully as to only get touch up on the bare metal and not the surrounding coating)?
      Lastly, the coating he put on is good for 5 years. If I still have the car at that point and choose not to get it put on again, can I just start waxing like I normally would or do I need to get another polish/correction?
      He also missed a scratch on the clear coat prior to the ceramic coat. He is going to stop back out and redo that area. I don't blame him for missing it, its right on a leading edge of a door and it looks like it could just be light hitting it, but its actually a scratch. A weird one at that.
      I am bummed as this car is only a month old and 1222 miles and already has a giant pit and a scratch (which I don't know how it got there).
      I would touch up the chip if it made it all the way through to the metal. Ceramic is super thin and won't provide the same benefits as clear.
      The coating will obviously degrade over time and 5 years is the manufacturer's suggested life. I'm assuming you should have a warranty card if a pro did it. Realistically, your paint will be swirled in five years and will need to be corrected again if it bothers you. Otherwise, just go about your life and apply whatever protection choice.
      There isn't a definitive means to tell if the coating is still present beyond the water behavior. Ceramic can get 'clogged' and in a relatively short amount of time depending on conditions. Typically a good wash with proper soap and an annual iron-x will properly cleanse the paint to rejuvenate the ceramic if you notice the water behavior starting to fade. I do a more serious 'topper' every six months after a iron removal treatment for my sanity. I'm going on year 2 of 5 w/ my feynlab ceramic.
    3. Member vwlifer27's Avatar
      Jun 14th, 2005
      Minneapolis
      2,212
      2019 GTI, 2004 R32, 2016 GLI
      07-11-2019 08:13 PM #127
      Quote Originally Posted by nc_detail_garage View Post
      Will the touchup even bond over the ceramic? It’s deep so can’t be sure if the coating made it all the way in, but if it did, will it bond?
    4. Member Bad Rabbit Habit's Avatar
      May 5th, 2005
      Manteca, CA
      3,867
      A Rabbit with a snail.
      07-11-2019 09:41 PM #128
      This is relevant to my current situation. I do have a big twist though. I want to do my rabbit, which is covered in rock chips that have rusted over. Plus, there is old vinyl strips, also in poor condition. The picture is of the roof, but the rest of the car is similar. I know with a buff, all the little specks will disappear, but I am curious how a coating will react to the bigger spots. Also, the vinyl will be impossible to mask, so if that is a problem, this will be a non starter.
      -Jon
      ig:badrabbithabit Formerly known as: monoaural
    5. Member vwlifer27's Avatar
      Jun 14th, 2005
      Minneapolis
      2,212
      07-12-2019 04:37 AM #129
      Quote Originally Posted by Bad Rabbit Habit View Post
      I’m digging the look of your Rabbit.
    6. Junior Member nc_detail_garage's Avatar
      Dec 26th, 2017
      Charlotte
      91
      B9 S4 / Levante
      07-12-2019 09:27 AM #130
      That's a tricky one. I would be careful on this one, especially using an orbital as it'll pick up and rub around the rust particles. Unfortunately I would not try and correct the paint if you brought it to me for a service. At best I would try and remove all the surface rust via multiple iron removal treatments and clay. After that I would use touch up paint to address the worse spots and move on. Keep in mind that you'll want to super careful not to grind the rust around, thus further damaging the paint.
      Same story for the vinyl stripes. They will not polish like paint and you'll likely just remove the top layer of the vinyl.
      There's nothing wrong with doing a diy ceramic but if it were my car I would just keep it simple and use paint sealants. Or, take a look at Gyeon CanCoat. I get about 7 sedans out of the 200ml bottle which makes it very cost effective. It's rated for 6 months with proper maintenance.
    7. Junior Member nc_detail_garage's Avatar
      Dec 26th, 2017
      Charlotte
      91
      B9 S4 / Levante
      07-12-2019 09:31 AM #131
      Best case, put a tiny amount of compound on a q tip and rub the chipped area. If not, then just use what you have and put touch up paint on. Use small amounts and build layers w/ the paint but since it's so low on the body panel I wouldn't over think it. Ceramic isn't this wonder solution that unfortunately the industry has made it out to be. I've removed many coatings from various manufacturers with light polishing despite claims of wet sanding and very heavy compounding is needed.
    8. Member vwlifer27's Avatar
      Jun 14th, 2005
      Minneapolis
      2,212
      07-12-2019 11:11 AM #132
      Thanks for the reply. My detailer said that it would be pointless to put it on as it won't bond. This is encouraging news. I lived in NC (was born there, but only lived there for the first few years of my life), I would be coming to you. I checked out your site and you run a cool business.
    9. Junior Member nc_detail_garage's Avatar
      Dec 26th, 2017
      Charlotte
      91
      B9 S4 / Levante
      07-12-2019 02:13 PM #133
      If it were me, I would either take it back to your detailer and have him rub out the ceramic from ding and apply touch up. It's a five minute task. Or, just apply the touch up yourself and be done with it. You'll know within a few minutes when the paint is dry whether or not it's going to bond. My money is that i'll stick just fine.
      And thank you for the kind words. I detail part-time for fun, a couple cars a month.
    10. Member HorrorPunk's Avatar
      Oct 8th, 2014
      West Hollywood
      210
      2019 Dodge Charger Scat Pack, 2020 Kia Soul EX (Vortex user since 2002)
      07-12-2019 05:43 PM #134
      I've been thinking about getting a ceramic coating for my new Charger Scat Pack... found a local place that comes VERY highly recommended & top rated, but they are pricey.
      For $1,800 they will:
      • Hand wash & clay wax
      • Repair ALL scratches & chips with factory paint
      • Apply 4 individual layers of Ceramic Pro coating
      • Apply 1 layer of Ceramic Pro light as a top final sealing coat
      • Apply 1 layer Ceramic Pro light to all exterior plastics
      • Apply 1 layer of Ceramic Pro to wheels & brake calipers
      • Apply 1 layer of Ceramic Pro leather/textile to seats
      • Vehicle reported to CARFAX (which can supposedly increase your cars value)
      • "LIFETIME" warranty, which covers fixing ANY scratches and chips as long as you own the car for, FREE.
      I've called a handful of other places around LA and they all quote around $500 for ONE layer or $800 for TWO layers of Ceramic coating, but non offer free scratch/chip repair work.
    11. Member
      May 1st, 2006
      So Cal
      650
      2016 Miata Club & 2019 Accord Hybrid
      07-13-2019 12:58 PM #135
      Quote Originally Posted by HorrorPunk View Post
      There's a couple things that stand out about this list:
      1. They don't mention anything about paint correction, which is the most labor intensive thing that should be done before applying a ceramic coating.
      2. 4 layers is at least one too many of the same product.
      PS: I've had great experiences with a place in Anaheim. If you want a recommendation, PM me.
    12. Junior Member nc_detail_garage's Avatar
      Dec 26th, 2017
      Charlotte
      91
      B9 S4 / Levante
      07-15-2019 09:40 AM #136
      That's similar to my pricing, assuming a heavy paint correction is included. I hope they didn't use the term repair all scratches. That's an odd way of referencing it. I also hope they have seen the car in person before quoting. Keep in mind the 'lifetime' warranty is contingent upon annual maintenance performed by their shop. I would call and check pricing but it's typically ~$250. I would confirm if they're doing wheels off coating or just the faces. I'm assuming they are but worth checking if the barrels will be coated. That's the real beneficial part.
      Just for more sanity, I have yet to see any empirical evidence that the carfax adds any value. Until then, it's just conjecture
      The biggest part to all this is the maintenance. Ceramic isn't a one and done solution. If you value good paint condition and clarity then it's worth understanding and refining your wash/dry process.
    13. Member HorrorPunk's Avatar
      Oct 8th, 2014
      West Hollywood
      210
      07-15-2019 03:47 PM #137
      Saying "scratches" is my wording, sorry. I was writing down all the notes from when I met with them & couldn't remember how to say that correctly. (I only have a few VERY small scratches on my car since it's only 5 months old that don't penetrate the paint.)
      There is NO annual maintenance I need to get done by them. The rep said "just do your best to wash it often & wax it once or twice a year and we got you covered for life if you ever get a scratch."
      Wheels off coating.
      Weather permitting, I hand wash my car every week and get a hand-wax every 6 months. My cars are always parked in a garage at home and when at work.
      Quote Originally Posted by proximal View Post
      My bad... I used the wrong wording. Paint correction is included before applying the coating.
    14. Member
      Aug 18th, 2015
      Cleveland, OH
      1,271
      2020 Cayman GT4 - Miami Blue - PCCB
      07-15-2019 03:53 PM #138
      Wheels off coating.
      I bolded a big red flag here....
      The entire point of a ceramic coating in almost all use cases is so you don't have to wax it (think: long lasting, durable wax). If you're waxing it every 6 months, you're literally not even using the ceramic coating and you just paid a bunch of money for someone to polish the car. To reiterate: you should not have to wax a car with a ceramic coating.
      I also can echo what the other guy said in that usually most of these legitimate coatings (ceramic pro or otherwise) have a stipulation in the warranty that requires you to keep up with "maintenance" washes at an authorized installer of said coating. If it's not that, then it's either something else, or the shop is providing a warranty instead of the coating manufacturer.
      ASP.NET / C# Software Engineer
      2020 718 Cayman GT4 - Miami Blue - PCCB
      2017 718 Cayman - GT Silver - PDK/Sport Chrono/PSE - gone
      2016 Golf R 6MT - Deep Black Pearl - gone
    15. Member HorrorPunk's Avatar
      Oct 8th, 2014
      West Hollywood
      210
      07-15-2019 03:56 PM #139
      Quote Originally Posted by iliveoncaffiene View Post
      Thanks for that... I have ZERO knowledge on ceramic coating, so my post was in hopes to get advice/thoughts on it.
      I also can echo what the other guy said in that usually most of these legitimate coatings (ceramic pro or otherwise) have a stipulation in the warranty that requires you to keep up with "maintenance" washes at an authorized installer of said coating. If it's not that, then it's either something else, or the shop themselves is providing a warranty.
      Yikes... NO thanks. I'm sure that would cost a lot too!
    16. 07-15-2019 03:58 PM #140
      How does the coating handle power coated wheels brake dust (occasionally use track pads)? Just had a set of wheels refinished and I asked a few local people that detail and one used ceramic pro for around 100 and i got another quote for 300 using one of gtechniqs product. I cant recall which specific product. I've been told it makes it easier to clean, but sometimes I get the salesman vibe from the people I know.
      And does the ceramic coating play well with say a wheel cleaner like sonax?
      Not much of a detailer, but I dont like brake dust, I find washing my cars a tedious process and rather be driving them at the track all day or working on something mechanical where that feels more relaxing to me.
    17. Member
      Aug 18th, 2015
      Cleveland, OH
      1,271
      07-15-2019 04:05 PM #141
      It's usually a yearly or bi-yearly thing (at roughly $200-300 a pop). This depends on your detailer. It's really not that expensive in the grand scheme of things.
      In general, you're paying for the ease of your maintenance (you don't have to wax it, you can wash it less often). It's always going to be cheaper to do your own maintenance and get the same results - it's just going to take more work on your part more often.
      Quote Originally Posted by Aw614 View Post
      I have Ceramic Pro Strong (also called Wheel & Caliper) on my shiny silver wheels. They still get dirty as hell from brake dust but I just spray some iron-x / de-greaser on them and wipe off all the dust - there is 0 scrubbing involved (unless it's a stuck on piece of tar / tar + rock that I have to get off). They go back to brand new looking without too much effort.
      If I wait too long there is some yellowy build up that requires me to let the stuff sit there longer and maybe a slight bit of scrubbing - but only with a microfiber. I've yet to have to use any type of wheel brush with bristles to clean my wheels.
      The coatings are engineered to stand up to chemicals for the most part, but that being said I doubt you'll need to use any strong cleaner to clean them if they're coated correctly (meaning they took the wheels off and coated the barrels and everything).
    18. Junior Member nc_detail_garage's Avatar
      Dec 26th, 2017
      Charlotte
      91
      B9 S4 / Levante
      07-15-2019 04:37 PM #142
      Not necessarily. I still wax my car every 6 months despite being coated - Feynlab Self Heal lite. I use Shine Supply Cherry Silica wax. Nothing wrong with that but for clients vehicles I suggest using a different topper every six months or at least annually. I promote the sacrificial layer concept. That said, I suggest and sell CarPro Elixir as the drying aid and CarPro Reload for the 6mo/12mo topper.
      We're expecting a lot from these coatings and multiple years is a long time from a few microns worth of product. Spray sealants just help and slow the degradation and are easy and affordable. I'm very surprised that the shop said they do not need to see the car each year to support the lifetime warranty. That contradicts what I know about CP and from fellow detailers. The point of the annual CP maintenance is for them to apply Ceramic Sport (1 year) coating to achieve the promoted 'lifetime' duration.
      My issues with the 'lifetime' coating or any coating >= 5 years is the paint condition. The car will scratch over time regardless of how diligent one is with their maintenance. I don't see a point in having a protected car if the paint is trashed. Its the fine swirls and rub marks that are the culprit, not the parking lot scrapes that most think will be protected against. For this reason, the longest coating I suggest for my clients is 3yrs. I value paint condition over any coating and steer folks back towards paint enhancements (light polishing) and sealants if I feel it's a better use of their funds given their maintenance habits.
    19. Junior Member nc_detail_garage's Avatar
      Dec 26th, 2017
      Charlotte
      91
      B9 S4 / Levante
      07-15-2019 04:43 PM #143
      It'll help but it's not a fool proof solution as there isn't one. I charge $100 per wheel to remove/prep/coat/reinstall. It's a time consuming process and all the wheel coatings I've seen/used are rated at 12 months. Cleaning is easier but a cheaper solution would be to use CarPro Hydro2 after each cleaning. This is just another spray on rinse off sealant but it's cheap and effortless. The durability is super short but you're not vesting a lot of time or effort into the application. I have BC Forged wheels on my s4 and re-coat them each year when I swap to my winter setup. If I didn't have the second set, they wouldn't be coated due to the long process vs short life trade-off.
      Sonax Full effect will not hurt the coating. The iron removal agents will only help keep the wheels clean from accumulating brake dust. The better you are at maintaining them, the easier the washing will be going forward
    20. Member
      Jul 7th, 2016
      1,906
      ‘77 Ford Bronco ‘85 Toyota 4x4 ‘87 930 ‘07 BMW e91 ‘08 Xterra
      08-14-2019 04:53 PM #144
      I did a DIY job of Gyeon Q2 Syncro on my daily it looks nice and glassy and water jumps right off of it. I just finished yesterday so nothing else to report yet.
      This pic is after one 12 mile round trip commute so of course the front wheels are already a darker shade of gray.
      Ceramic Coated by willtel, on Flickr
    21. Goes in two directions RAVatar's Avatar
      Sep 28th, 2005
      Savannah, GA
      3,579
      '14 Toy RAV4Runner '20 Toy Corolla Smurf '13 Ferrari 458 Italia Size: XS
      08-14-2019 05:38 PM #145
      I'm having a big internal battle with myself about getting the funsize Ferrari corrected and coated.
      My big issue is that the PO says the car was already ceramic coated. That's as may be, but he did not correct the paint before coating it. He also didn't correct the paint before the entire front end of the car was 3M filmed. I can't tell if the 3M is halo'd/scratched up or if it's the paint underneath. Seeing the condition of the paint on the non 3M'd panels, I'm wondering if it is the paint and he just threw 3M over the paint as it was.
      Am I going to need to remove the 3M to make correcting worthwhile? I'd hate to do that, because my entire hood, entire front bumper, both mirrors and half my front fenders are all 3M covered.
      It needs correction. Badly. And I want to get it taken care of before the rainy season this winter. I actually just visited the NC Garage guy's detailing page. Charlotte is only 4 hours away. Hm...
      Off Topikstan CSB Thread, First Responder (c) 2013
      IG - the_cama_lens
      OG:SAV912
      Quote Originally Posted by Time for an aSS
      She got so pissed off she dumped her tits out at me.
    22. Senior Member Iroczgirl's Avatar
      Feb 17th, 2007
      Bend, OR
      34,017
      Hot hatchback coupé heaven
      08-14-2019 09:56 PM #146
      Typical Westmoreland "patina" (result of poor factory paint prep). Been there, done that.
      I have only two suggestions:
      - Leave it alone.
      or
      - Repaint the car.
      When I first got my westy, I tried everything to correct the paint. The more I did, well, the paint never looked better, and the vinyl always looked worse.
      In the end I had it repainted.
    23. Member Bad Rabbit Habit's Avatar
      May 5th, 2005
      Manteca, CA
      3,867
      08-15-2019 09:50 PM #147
      Quote Originally Posted by Iroczgirl View Post
      - Leave it alone.
      or
      - Repaint the car.
      I just want to keep it in stasis. I love how it looks, and just want to keep it from getting worse. That, and super easy cleaning.
      -Jon
    24. 01-19-2020 08:08 PM #148
      Read the whole thread. Quick question.
      The part of this that gives me some pause is the need to hit the car with a cutting polish of some sort in order to get "old" protectant off.
      I have two cars I'm considering this on:
      SQ5: bought used from the Audi dealer. It clearly has some sort of Ceramic coating on it because it beads like crazy. The frustrating bit here is that I want to do some paint correction work on one of the doors and I can't seem to make a dent because the ceramic is so "hard".
      Do I:
      - Wait a year or two until it naturally wears off?
      - How do you know when it's actually gone?
      - Since I can't tell what brand Ceramic is on it, are there compatibility issues?
      i've been using old school carnuba to keep up on the finish and it's working fine. But, would like to try Ceramic. I guess the main question is: do I need to basically polish the old coat off (along with a layer of clear coat)?
      Macan:
      We bought this new and it's never had Ceramic. It has had Carnuba though. Do I just wait until the Carnuba is gone (no beading) or -- again -- do I need to hit it with a cutting polish to be sure?
      I'm pretty clear on how to proceed once you start with Ceramic. The bit I'm confused about is how to create the right "baseline" for new and previously-coated cars.
      Thanks!
      '10 997S, '16 SQ5, '18 Macan S. Many departed fun cars.
    25. Junior Member
      Jan 5th, 2013
      Northern VA
      73
      2016 Tesla Model S P90D, 2006 BMW M Roadster, 2016 Lapiz Blue Golf R, 1989 Fairlady Z 2+2 TT
      01-19-2020 11:02 PM #149
      Quote Originally Posted by smstiles View Post
      Do I:
      Macan:
      Thanks!
      A carnuba wax will not stick to a ceramic coating with any sort of longevity. I'd recommend a product called Beadmaker by P&S, or Adam's ceramic wax if you want to use a topper for your ceramic coating.
      The ceramic coat should come right off with a Microfiber cutting pad and a correction compound. If you're still seeing swirls it's more likely because you have "hard" paint, and may need to do a more passes or use a more aggressive compound. Meguiars 110 should do the trick on most stuff. You're going to need to polish the entire panel- it will look weird if you just try recoat one section.
      For carnauba wax, you can remove with just a strong soap. I like Adam's stripper soap. Nothing wrong with a nice carnauba wax though- in my opinion it has a better looking finish on most cars than the coatings.
    26. Member VRhooptie's Avatar
      Jul 24th, 2009
      NOVA
      1,258
      NA Miata
      01-20-2020 11:18 AM #150
      Recently bought a new car and used Carpro Cquartz 3.0 for the second time. First time I did it was on my GTI. I swired removed, polished, used Carpro Eraser to remove oils and then did two coats of the Cquartz, however the second coat was applied 24hrs later. I found the second coat removed some of the shine/wetness which was odd. I then applied reload as per instructions. The coating lasted nicely however lost some of its beading qualities. I always used Adams quick detailer as a drying agent but don't think that was the cause. I should've used some of their Reset carwash but ended up selling the car.
      GTI
      Untitled by Vr6 Hooptie, on Flickr
      The G37 I applied only one coat and topped it with Reload, not because I ran out of CQuartz of course Its still in the garage curing but so far Im happy with the results
      Pre-Detail- Paint was in great condition. Just a few swirls here and there
      MK3 GTI VR6(Sold) Mk4 Gti 1.8T(Sold) Mach 1(Sold ) 20th Anniversary GTI (Sold) Saab 9-2x (Sold) MK6 Golf TDI (Sold) Imola ZHP x2 (Sold)
      2018 GTI (Sold) G37 IPL (Sold)
