Fourtitude.com - 3.6 4motion 6 speed swap
    Results 1 to 17 of 17
    1. 11-22-2017 06:40 AM #1
      Just letting everyone know I just finished a 6speed manual swap in my 2007 3.6 4motion passat wagon. Hit me up if your interested to learn more about the process
    3. 12-08-2017 02:12 PM #2
      Quote Originally Posted by Derek_APE View Post
      Absolutely interested! Any chance you'd write it up and post it here for all interested parties?
      Sent from my Moto Z2 Play using Tapatalk
    4. Member G60ING's Avatar
      Jun 27th, 2000
      Annapolis Area MD
      15,727
      2010 3.6 4-Motion CC, 1990 G60/TDI/R36 Corrado
      12-12-2017 01:51 AM #3
      Yes post up the details,I plan to do this whenever my CC's Automatic sneezes wrong. 2008 TT VR was what I had planned to use as a donor for the drivetrain and then just CC manual pieces for the other interior and manual bits. Any coding issues or unique driving issues?
    6. Member G60ING's Avatar
      Jun 27th, 2000
      Annapolis Area MD
      15,727
      12-12-2017 10:57 AM #4
      Here is what he posted in the B6 forum:
      I'll be 100% honest I'm still working out some bugs with the car. The car sat for a year due to a bad trans until I was able to get around to doing the trans swap. As of right now I have a parking brake fault, abs light (due to parking brake fault I believe) and an airbag light (bad sensor under the passenger seat) but the car is now my daily driver and is a blast to drive!! ?
      Here is a complete parts list
      -2004 r32 transmission
      -2004 r32 flywheel and clutch
      -2004 r32 starter
      -mk5 gti shifter box and cables
      -b6 passat 6 speed shift knob and boot
      -mk5 clutch pedal and master
      -clutch line (I used a braided universal line)
      -mk5 brake pedal (only need the pedal itself, not the bracket)
      - (2) b6 passat 2.0 manual LF axles...
      i made an axle spacer so I can use the same axle on both sides because I had trouble locating a RF axle to fit. I think a 2012 R axle will work but I could not verify a length and they cost $450. But the spacer was the cheaper route and makes buying a replacement axle easy and cheap.
      The ecu will need to be sent somewhere to have the automatic parts of it erased and the immo deleted. And then it will need coded for the manual trans via VCDS.
      The factory cluster can stay and recoded for a manual trans as well.
      You will have to make a custum transmission mount for the drivers side.
      And I had to run a couple wires to run the starter which was very simple to do. I'll add some pics as I get time.
    7. Member G60ING's Avatar
      Jun 27th, 2000
      Annapolis Area MD
      15,727
      12-12-2017 11:06 AM #5
      I made the trek over to Anderson Performance Engineering here are some of the pics:
    8. 01-13-2018 06:00 PM #6
      Sorry for the delayed response. I don't get on here much. Pm me if you have any questions. Thanks!
    9. Member jddaigle's Avatar
      May 30th, 2003
      Denver, CO
      7,068
      2008 Passat Wagon VR6 4motion, 2013 FIAT 500 Sport
      01-14-2018 10:56 AM #7
      Can you answer questions in this thread so that everyone can benefit?
      - Jeff
      B6 Passat 3.6 & 4motion Resource Thread
      Now: 2008 VW Passat 3.6 4motion Wagon, 2013 Fiat 500 Sport
      Then: 1987 Volvo 745GLE, 1989 Volvo 745GL, 1994 Volvo 940T, 1995 Infiniti G20, 2000 VW Passat 1.8T, 2001 VW Jetta Wolfsburg Ed (x2), 2004 VW Golf TDI, 2006 Jetta TDI
    10. 01-18-2018 04:12 PM #8
      No issues so far. I drive it about 100 miles every day. I am fighting an EPB fault but it was present before the swap. Parking brake button dodnt fix it so the EPB module is next..VERY fun car to drive!! I'm sure the exhaust and uni tune play a part in that as well. Lol
    11. Member G60ING's Avatar
      Jun 27th, 2000
      Annapolis Area MD
      15,727
      01-18-2018 04:18 PM #9
      Does it over rev when you shift from gear to gear while driving hard? Did you install a clutch switch?
    12. 01-18-2018 08:17 PM #10
      It has the typical vw rev float. But nothing abnormal because it was swapped. And as of right now I just have an always grounded relay to run the starter. When I get some free time I will wire the ground wire up to the clutch pedal switch. I work 2 jobs (operations specialist for a natural gas pipeline co, and running my shop) along with raising a family, so my free time is minimal. Haha
    13. Member G60ING's Avatar
      Jun 27th, 2000
      Annapolis Area MD
      15,727
      01-18-2018 09:52 PM #11
      I can respect that, thanks
    14. Junior Member c_cright's Avatar
      Mar 14th, 2009
      Chatham Kent
      40
      1998 VW Passat 1.8T, 06 Passat 3.6 4Motion, 06 CRF450R, minibike
      02-24-2018 06:39 PM #12
      Sick someone did it, eventually I'm sure it'll be all buttoned up like it would from factory.
    15. Senior Member kevin splits's Avatar
      Aug 23rd, 2010
      Arizona
      21,019
      01001011010011110 1010010
      10-23-2019 01:37 PM #13
      Just so everyone's aware, you can also use the manual trans, trans mount, shift box, and axles out of a 2008 Audi TT 3.2.
      "The Vile Bunch" ll v2lab ll eemilitiatv ll Stay Orange.
      2008 Mkv-sold; 2003 yellow SRT-4-sold; 2009 G8 GT-sold; 1991 Talon TSI- fully built-sold ; 2011 Mk6
    16. Member G60ING's Avatar
      Jun 27th, 2000
      Annapolis Area MD
      15,727
      10-26-2019 07:47 PM #14
      Quote Originally Posted by kevin splits View Post
      That’s actually the combo I figured I’d run. I haven’t seen anyone mention it but wouldn’t it make sense to swap out the rear diff to keep the rations the same?
    17. Member nycdub2's Avatar
      Feb 13th, 2005
      Queens, NYC ---->Gilbert, AZ
      1,326
      R36 4Motion Wagon, MK6 Jetta SEL, 5N2 Tiguan SEL 4Motion
      10-27-2019 02:23 PM #15
      The rear diff from mk4/TT mounting points are different and wouldn’t bolt up to B6 rear sub-frame. Also the Haldex module is old, would need to swap in newer module.
      Current: R36 4Motion Wagon, MK6 Jetta SEL, 5N2 Tiguan SEL 4Motion
      Past: MK2 GTI 16v, MK4 GTI VR6, MK4 Jetta, B3 Passat GLX Wagon VR6, B3 Passat GLX Sedan VR6, B3 Passat GL Wagon 16v, B3 Passat GL Sedan 16v
    18. Member G60ING's Avatar
      Jun 27th, 2000
      Annapolis Area MD
      15,727
      10-27-2019 07:40 PM #16
      Quote Originally Posted by nycdub2 View Post
      Good info, is that case with the 2008 TT too?
    19. Member nycdub2's Avatar
      Feb 13th, 2005
      1,326
      10-27-2019 08:44 PM #17
      In terms of mounting points the MK4/TT are the same, MK5/TT/A3/RS3 are the same, Tiguan 5N1 & 5N2/Q3/SQ3/RSQ3 are the same, and B6/Euro B7/CC are the same.
      I believe that B6 & Tiguan are compatible in mounting points.9
