Fourtitude.com - going to replace the front driver side axle. what is the torque specs?
    Results 1 to 3 of 3
    1. Junior Member
      Oct 29th, 2016
      41
      VW Golf 1997, Audi A6 1996 Avant quattro , Audi A6 2006 Avant quattro, Audi A3 2009 2.0 quattro
      11-03-2017 11:29 PM #1
      hi. I will try to replace the left front axle since the old one had the inner boot torn.
      I bough the set of new bolts as well. the center bolt has the red threadlock on in. but the six inner bolts have no threadlock. should I put some?
      Also what is the torque specs for the center bolt and for the inner bolts.
      For A6 it is 145ft-lb and turn another 180 degrees after this. it it the same for A3?
    3. Member tylaughter's Avatar
      Aug 31st, 2010
      Orange County
      200
      2014 VW JSW; 2001.5 Audi S4 Nogaro
      11-03-2017 11:53 PM #2
      RFT
      Sent from my iPhone using Tapatalk Pro
    4. Junior Member
      Oct 29th, 2016
      41
      11-05-2017 04:34 PM #3
      thanks. what is the torque on the six bolts near the inner join? Do I need to put thread lock on them?
