Fourtitude.com - Turning an old 1920's Ford Garage into a DIY Garage
    Page 1 of 26 1234511 ... LastLast
    Results 1 to 25 of 635
    1. Member TheDeckMan's Avatar
      Sep 26th, 2004
      19,276
      GMC, SAABs,VW's, MG ect..
      10-31-2017 05:45 PM #1
      This thread is dedicated to the insanity of many of the garage projects to the cars rebuilt and modded along with the road trip adventures to find great beer and food in the north east kingdom of the old colonies. In memory of a great friend and mentor Denis Basak that really profoundly influenced my automotive interest in a great way.
      A little over a year ago I bought this place which was originally a grist mill in the late 1800's with lots of history to turn into a garage space to work on the cars.
      In 1928 it was moved up the street to a higher location along the lake and turned into a Ford Garage until ~1975 when it was closed and became just a repair garage. It spent until 2016 as a garage/body shop/machine shop.
      This summer was the beginning of the overhaul of the space. First required removal of lots of left over scrap and such from the shop and to create a starting point in hope of finishing enough to be able to work on some of the cars this winter prior to turning attention to the rest of the space.
      A quick job of cutting some legs to convert this old wall mounted bench into a portable work station for saw/wood working was first up.
      Opening framed going towards where the lift will go in.
      After some cleaning and painting of the walls/floor in the new parts/assembly room
      Wire racks make great organizers for parts and when taking things apart to keep all of one cars parts in a common area
      Some of the old machine shop items still there prior to removal
      Next up was to get some air to the already existing lines throughout the building. The intent is to have the Husky unit and eventually once I repower the three-phase Wayne as a large air capacity system to be able to do some extensive sand blasting/painting as needed.
      There was an old Wayne two stage in the back room that I decided to turn into office space to rent, so it had to come out as well as the old wall bench which was turned into the portable wood work bench.
      Using an engine lift made this pretty easy to move without feeling like I was going to die. Ended up clearing the door frame by 1/4"....which is close to a mile right?!
      Next focus was to get the future rental area sorted out by doing some floor repairs, creating a work area that did not make you cringe.
      Countless hours were spent with a punch and hammer with a little help from beer pounding down the nails prior to sanding these old floors to remove oil ect.
      Followed by extensive floor sanding and painting
      Next up was to put the partition up and some new lighting
      Some good beer while doing a copper patch and more painting is never a bad thing
      Back to the garage as the weather was nice and stopped raining for a week, so it was time to grind the floors, but alas many things still had to be moved first so from sun rise to sun set on a Saturday it was cramming everything in this room into the two other garage sections.
      First layer of grinding was to remove all the grime off. Using sand as a ball bearing surface as well to help clean the teeth on the grinder helped a lot.
      Then switching over to carbides allowed a nice finish cut as you can see here. For the 2100sq/ft it took the better part of twenty hours of grinding to complete and let me tell you that for days your cleaning dust out of your hair/beard.
      Then next was to do the epoxy, which I chose to use Legacy Industrial's HD kit which came with everything you need to do the project. Overall took about two hours to do all 2100 sq/ft seen here. Now that the floors are done the walls are driving me mad as they desperately need a coat of paint. Some places that were more porous than others sucked up the epoxy. Which resulted in needing a 2nd coat. I would strongly advise if taking this project on that you do a 2nd coat. The first coat eats up the epoxy and took 15 gals where as the 2nd coat only required 5 gallons of epoxy and went on within an hour.
    3. Geriatric Member ValveCoverGasket's Avatar
      Mar 20th, 2002
      northwest corner, WA
      41,353
      duramax, tdi westy, dieselgate tdi, and an mg
      10-31-2017 06:08 PM #2
      wow thats gonna be one hell of a DIY shop. awesome!!
    4. Senior Member LT1M21Stingray's Avatar
      Sep 13th, 2006
      Somewhere North of Lyon Mountain.
      23,727
      SR71 C30 t53a/b/b
      10-31-2017 06:26 PM #3
      Wow, that is one cool project!
    5. Member turbinepowered's Avatar
      Mar 18th, 2007
      Upstate SC
      9,726
      '86 Interceptor 700, '82 Quantum Coupe, Hyundai Elantra GT Daily
      10-31-2017 06:53 PM #4
      I am so in for this one.
      Quote Originally Posted by zukiphile View Post
      There is an area of a normal brain that lets the owner know the object works and needs to be left alone. Not all of us have it. It is like being colorblind.
    6. Member CoreyB's Avatar
      Nov 26th, 2009
      Wethersfield, CT
      1,967
      monty green money pit, 01 nogaro blue Audi S4
      10-31-2017 07:31 PM #5
      Awesome work Noah Let me know if you ever need a hand on the weekends. I'd love to come check the place out.
      Have a Porsche related question, or need specific info about a Porsche model? Please feel free to ask. I am a certified Porsche tech
    7. I’m not a loser. I’m a winnah!! patrikman's Avatar
      May 10th, 2008
      44.5 North, 88 West
      38,797
      made in ‘murica truck and wagon
      10-31-2017 07:33 PM #6
      That’s awesome, I’ve always fantasized about a similar endeavor. Kudos for you for going after it!
      Any exterior pics?
      this signature kills fascists.
    8. Member 8V Fury's Avatar
      Jul 26th, 2003
      Sacramento, California
      5,933
      1994 vw golf sport, 1990 vw jetta coupe
      10-31-2017 08:14 PM #7
      Love the progress and outcome.
      real deal<p>After spending two months in the mk3 forum it drove into the woods and set fire to itself.
    9. Member Pennywise's Avatar
      Oct 18th, 2003
      San Francisco, CA
      8,405
      2015 Honda CRZ, 1991 Honda Civic Si, 1997 BMW M3/4/5
      10-31-2017 08:26 PM #8
      Fantastic.
      Quote Originally Posted by woofsburger View Post
      It's reassuring to know that when I finally hit the 98th percentile of US individual income, that I may then buy my dream car - a Toyota Avalon.
      Sep 29th, 2004
      Sydney, Australia
      1,770
      E46 M3, 90 Series Landcruiser, Kluger
      10-31-2017 08:33 PM #9
      Tears of joy!
    11. Member Vettes, Volvos and VWs's Avatar
      Mar 5th, 2006
      Sudbury, ON
      4,214
      Five Germans and a Japanese Misfit
      10-31-2017 09:21 PM #10
      OMG YES
      Quote Originally Posted by Baconator14 View Post
      vettes, volvos, and vws for president
      Quote Originally Posted by UAlvarez View Post
      you're a boss. your sig is appropriate
      My Weak Shiz l Milk █Bg█ Mafia Click here and PM me for Speed-Tech Hood Extensions!
    12. Turtles walk slowly, but get angry fast! Smooremin's Avatar
      Jan 10th, 2006
      Chicago, Il
      8,581
      2019 Audi eTron, 2018 R8 RWS, 2002 Chevy 2500HD, 1988 16v Scirocco
      10-31-2017 09:30 PM #11
      Any exterior pics?
      This.
      I saw your pics in OT and felt the same way.
    13. Senior Member Iroczgirl's Avatar
      Feb 17th, 2007
      Bend, OR
      33,929
      Hot hatchback coupé heaven
      10-31-2017 09:37 PM #12
      Waw, amazing!
    14. Geriatric Member Air and water do mix's Avatar
      Aug 5th, 2004
      Southern Indiana
      43,230
      '66 Beetle (X2) '08 Fit
      10-31-2017 10:02 PM #13
      I am so freakin’ “in” for this one. That looks killer.
      I just wish I could buy you a round and talk about your plans for it. It’s impressive as hell.
    15. Member VierSpeed's Avatar
      Apr 12th, 2008
      Lake Huron, Ontario
      3,793
      '03 911 C4S, '19 Model 3 AWD LR, '14 Ram, '16 FZ-07
      10-31-2017 10:06 PM #14
      █ ♣ █....|....└┼┼┤....|....Wait, what? - Iroczgirl
    16. Member
      May 12th, 2012
      Denver
      1,602
      1984 GTI, 993 turbo
      11-01-2017 08:27 AM #15
      Nice shop, makes my garage look like a dungeon
    17. Member TheDeckMan's Avatar
      Sep 26th, 2004
      19,276
      11-01-2017 08:45 AM #16
      Quote Originally Posted by CoreyB View Post
      Thanks Corey! I will be in touch for sure as planning pulling the 996 motor as soon as things get buttoned up a little bit more.
      Thanks
      Any exterior pics?
      From the 20's some of the old photo's I was able to chase down. I have yet to be able to chase down later pictures from post WWII until the closing of the garage.
      Last night was some simple moving things around to get back to being able to tackle the new stairs into the attic that replace the old death trap that was removed as they were in the middle of the room in the new office space. Moving the wood work table out from one of the other bays via a using the pallet jack and trash can trick to prevent any damage to the fresh floor.
      Then time to move the Husky air compressor to have some air for the tools once again. Using the pallet jack to move it around then using some old car floor mats to walk it into place made it as easy as pie by ones self. Using an old blanket or floor mats to protect the floor paint when moving heavy stuff helps a lot. Often when moving equipment with fork trucks from outside into a freshly painted floor area using some Lauon sheets or felt flooring to clean the wheels of the fork truck which can bring in lots of debris from outside.
    18. Senior Member dubdaze68's Avatar
      Oct 29th, 2001
      21,810
      11-01-2017 09:07 AM #17
      Oh, and now you need one of these to go with the finished job. This is a Model T-era Ford service sign, much like the one in the picture. You can see it's double sided, just like the one in your 20's picture.
      DCIVW
      CE.
    19. 11-01-2017 09:13 AM #18
      So in for this. It appeals to so many of my interests at once.
    20. Member Stromaluski's Avatar
      Jun 15th, 2005
      Greenville, SC
      3,215
      11-01-2017 09:18 AM #19
      IN!
    21. Member Stromaluski's Avatar
      Jun 15th, 2005
      Greenville, SC
      3,215
      11-01-2017 09:20 AM #20
      Quote Originally Posted by TheDeckMan View Post
      Is there a living space attached to it or is that all just office space?
    22. Geriatric Member Hostile's Avatar
      Nov 18th, 2001
      Near Rabbit5GTI
      39,207
      '15 STi & '16 .:R
      11-01-2017 09:22 AM #21
      Wow, neat project.
      I can't believe you painted that wood floor.
      iain
    23. Member TheDeckMan's Avatar
      Sep 26th, 2004
      19,276
      11-01-2017 09:32 AM #22
      Quote Originally Posted by dubdaze68 View Post
      Yeah it could for sure use one, it is on the list to hunt down in the near future.
      The lower part of the building is office space with the upper two floors being my living space.
      Quote Originally Posted by Hostile View Post
      Wow, neat project.
      I was hoping not to, but doing multiple repairs to sections that were going to potentially be issues for trip hazard for the rental office was more the worry.
      There was already existing office spaces where the old line shafts ran for the grist mill. This area never was used for machining so the floors ended up staying in much better condition when these offices were put in ~15 years ago.
      Common kitchen area for the office spaces
    24. 11-01-2017 09:43 AM #23
      wow thats pretty BA. What are those things behind the desk in the shot with the safe on the wall.
    25. Member G60ING's Avatar
      Jun 27th, 2000
      Annapolis Area MD
      15,892
      11-01-2017 10:01 AM #24
      Nice seeing all the pics in one thread. great progress Noah.
      I used Legacy for my garage floors, did you use clear on them?
    26. Geriatric Member Hostile's Avatar
      Nov 18th, 2001
      Near Rabbit5GTI
      39,207
      '15 STi & '16 .:R
      11-01-2017 10:04 AM #25
      Ahh, got it. That is a really awesome old building. Thanks for saving it.
      iain
