Fourtitude.com - NEW LIQUIMOLY - Molygen New Generation Engine Oil (5w-40)
    Results 1 to 16 of 16
      Jan 17th, 2017
      NNJ
      279
      2017 Jetta S A/T 1.4T
      09-14-2017 09:00 AM #1
      Thoughts?
      ES#3246016 - 20232 - Molygen New Generation Engine Oil (5w-40) - 5 Liter - Full synthetic oil with fluorescent, friction-reducing additive! - Liqui-Moly - Audi BMW Volkswagen MINI
      1.4 TSI, UNI 1+
    3. Banned
      Dec 9th, 2014
      www.volkswagenownersclub.com
      1,726
      09-16-2017 10:44 PM #2
      DOUBLE POST!
      https://forums.vwvortex.com/showthrea...il&p=107661721
      Plenty of THOUGHTS in your original post, why post AGAIN?
      Again:
      Molygen, not new news...
      Back in April of 2016:
      Liqui Moly's Molygen New Generation engine oil is the brand's newest high-quality premium engine
      oil. It features molecular friction control, and has an effective chemical friction modifier that permanently
      protects the surface of all parts of the engine. The special Molygen additive ensures that the engine oil
      is of low viscosity and has a high shear stability and reliably prevents the formation of deposits, significantly
      reducing frictional losses in the engine and providing the optimum protection from wear. A fluorescent green
      oil smooths and refines the surface structure on areas of contact, ensuring optimal performance.
      This unique oil contains a fluorescent green chemical friction modifier to smooth out hard metal surfaces,
      reducing overall engine wear and heat due to friction. Tests have shown a reduction in friction coefficient
      of as much as 15%! MolyGen oil is also a great choice for modern turbocharged engines which produce
      much more heat.
      Technical Specifications:
      Density at 15°C - .855kg/cm3
      Viscosity at 40°C - 80.7mm²/s
      Viscosity at 100°C - 14.0mm²/s
      Viscosity Index - 180
      Flash Point - 230°C
      Recommended for the following oil and manufacturer specifications:
      ACEA A3
      ACEA B4
      API SN
      API CF
      BMW Longlife-01
      MB 229.5
      Porsche A40
      Renault RN 0700
      VW 502.00
      VW 505.00
      https://www.ecstuning.com/b-liqui_mo...ter/20232~liq/
      It glows under UV light too, so leaks can be easily traced.
      Available in 5W-20, 5W-30, 10W-30, 10W-40, and 5W-40.
      Ads also say florescent green in color, with synthetic based tungsten friction modifiers:
      https://youtu.be/QL92HG1thmY
      Also, Mobill 1 (HTHS)- 3.6 / Liqui Moly and Motul also share this HTHS. AMSOIL (HTHS)- 3.9
      All you need is Mobile 1 Euro 0W40, as low as $22.88 at WALMART...
      __________________________________________________ ____________________________________________
      Quote Originally Posted by Ronny Bensys View Post
      For a turbo engine, best choice is 5w30 but never 10w40.
      10w40s are semi-synthetic oils which are not suitable for TFSI/TSI family engines.
      Yeah, if the label says Synthetic Blend. Otherwise, you can buy full synthetic oils in the
      10W40 weight, but still not recommended in any area where temps fall below freezing.
      What do "euro specs" mean in the US? Isn't it a marketing trick?
      Not really... Euro Spec is the the 502/505 spec, which you can get at Walmart now, Castrol Edge 5W40, and
      Mobile 1 Euro 5W30 and 0W40.
      You can get away with using the right NON Euro Spec oil. I had a TDI, and used Rotella T6 then
      DELO400.
      Quote Originally Posted by 16VSerenity View Post
      Please use 5w40, as VW recommends and requires to keep your warranty. The engine was built to certain specifications and to run with 5w40. Do NOT use a thinner oil, such as 5w30, it was not made for your engine. Buy and use the correct oil. It is not that hard to find it. Heck, order it from Amazon. Some of the better brands for 5w40 are Motul, Liqui Moly, and Pentosin.
      Sent from my SM-G900V using Tapatalk
    4. Banned
      Dec 9th, 2014
      1,726
      09-16-2017 10:47 PM #3
      There, now you have a duplicate of what was there, since, well, people
      like to duplicate their posts...
      Jan 13th, 2017
      Texas
      473
      15' GTI
      09-18-2017 08:38 PM #4
      I could see a tech at the VW dealer saying WTF when they see green oil. Lol
      Sent from my Nexus 5X using Tapatalk
      Jan 13th, 2017
      Texas
      473
      15' GTI
      09-18-2017 08:45 PM #5
      I would be curious to see if anyone reports lower engine temperatures when using this oil.
    8. Member formgen's Avatar
      Jul 14th, 2007
      221
      2016/VW/Golf R
      03-07-2018 08:40 PM #6
      I just filled up with it and it is not lower temp.
    9. Junior Member
      Jan 29th, 2017
      26
      2015 CVCA Jetta TDI
      06-20-2018 01:55 AM #7
      I love liqui moly actively coming out with oil/additives like molygen, I am just disappointed that molygen is only for gas engines and not diesels. I will say however the 10w-60 is a good oil in the cr150 tdi, but only keep it for 5-6k miles (amazon has 7 liters for $64). Trying the liqui moly 5w-30 after a poor experience with the 5w-30 from pentosin....which led me getting the heavier oil. hope something may specifically come out for diesels like molygen diesel or so.. wonder what color that'd be.
      I am finding it difficult to locate a liquimoly dealer, as hard as trying to find an amsoil dealer. Up in Washington state you can go to a given napa and find both, but down in Florida I cannot find any within a 100 mile radius of my house. Good prices at idparts.com and blauparts.com on oil.
      The Pentosin oil went up in smoke and threw idiot lights on dash, the 507 spec found at Advanced auto. Finding out that reliably a grade/tier 4 oil is what these cars like basically found by liquimoly or amsoil for 8-10k intervals. Walmart bandaids are ok like castrol and mobile if needed, but would not throw those past 5k.
      Jan 3rd, 2012
      coal township penna
      321
      2001 Mk IV 200,000 traded jetta for 2001 Audi TT 225Q Roadster
      01-21-2019 07:26 PM #8
      today you can mail order almost anything + a bit of searching will get better deals IMO. girlfriends 13 malibu 2.5 DI engine is a bit oil thirsty at almost 60 thou, so i tried the 5-40 liqui-moly on amazon + its drinking less. told her to get another VW as her 08 jetta 2.5 was using very little oil + got better mpg's locally where she drives mostly.
    11. Member KarstGeo's Avatar
      Jan 19th, 2018
      Richmond, VA area
      2,050
      2018 VW Atlas SEL 4Motion 2018, VW Golf Sportwagen S 4Motion DSG
      01-31-2019 10:24 AM #9
      The issue with this oil is that while LM says it's "recommended" for cars requiring a VW-502 approved oil, this actually isn't VW-502 approved due likely to the additive package. I'm sure it's great, but make no mistake, it's not a VW 502 oil.
      2018 Atlas SEL VR6 4Motion - K&N drop-in, deAuto interior, fog, and full tail LEDs
      2018 Golf Sportwagen S 4Motion DSG - Unitronic St2 IS20 ECU/St2 TCU/downpipe/K&N drop-in+air box/duct mods+block off/CTS TIP+TIH+TMD/034 dogbone insert/Golf R RSB
    12. Member
      Jan 13th, 2017
      Texas
      473
      15' GTI
      01-31-2019 11:39 AM #10
      Quote Originally Posted by KarstGeo View Post
      I wouldn't use it for the same reason you stated. Recommended does not mean it's actually approved.
      To be fair though, "not approved" doesn't mean it failed VWs tests, it could just mean this oil was never tested for approval by VW.
    13. Member KarstGeo's Avatar
      Jan 19th, 2018
      Richmond, VA area
      2,050
      01-31-2019 12:14 PM #11
      Quote Originally Posted by OldBeater View Post
      That was my point...I'm not using it unless it has the 502 approval.
    14. 09-30-2019 02:46 AM #12
    15. 09-30-2019 02:48 AM #13
      502 is a crappy old spec.
      MB 229.5 is the top spec. 502 is a joke.
      https://online.lubrizol.com/relperftool/pc.html
    16. Member KarstGeo's Avatar
      Jan 19th, 2018
      Richmond, VA area
      2,050
      10-07-2019 03:43 AM #14
      And sone of the 502s also meet 229.5 like my Kool Aid LM.
      Sent from my SM-G973U using Tapatalk
    17. 10-14-2019 02:33 AM #15
      $22/jug oil meets 229.5 and is a better formula than $40/jug LM.
    18. Member KarstGeo's Avatar
      Jan 19th, 2018
      Richmond, VA area
      2,050
      10-17-2019 06:36 AM #16
      Quote Originally Posted by A.Junkie View Post
      What makes it a better formula specifically? They both have the same approvals.
