Fourtitude.com - Hardtail advice
    Page 3 of 3 FirstFirst 123
    Results 51 to 57 of 57
    Thread: Hardtail advice
      Nov 19th, 2006
      Arden, NC
      4,014
      2009 BMW 328it, 2017 Acura MDX
      10-14-2019 08:11 AM #51
      I was joking before about needing wider rims, but maybe that IS your problem with the 2.6” tires. The main advantage of 2.6s is the lower pressure you can run on them without bottoming, but if you’re on skinny rims, you’re going to have sidewall flop unless you boost the pressure. When you boost the pressure though, you’re losing the smoother ride and better traction.
      I also wonder if the tires are creating a weird contact patch by being pinched.
      So basically, wider rims=lower pressure and all of its corresponding benefits with less flop. Eh?
    3. Member Samson's Avatar
      Dec 2nd, 1999
      12,285
      Lifted G-wagon, lifted AWD Prius
      10-14-2019 08:50 AM #52
      Quote Originally Posted by mrothwell View Post
      Yeah, very well could be. But I don't care $2newrims to find out. Some of the disadvantages can't really be helped (reduced straight line traction, excessive weight, not as responsive). The reduced rolling resistance claim may be true, especially on rough trail... but like all things, it's a tradeoff. I do like the round profile that the 24mm rims give the tires though, and they are 2.55" wide at somewhere around 18-20psi out back and a couple less up front. That pressure seems to be about what people run in these things as well, at least from what the internet says. The more rounded shape of the sidewall likely gives them less support though, which might be messing with something.
      Or, putting 2.6" 890g tires on an XC hardtail and expecting it to still be all XC-like is an unrealistic expectation. They're probably a ton of fun on a downhill, but... well, you used to live here.
    4. Member Samson's Avatar
      Dec 2nd, 1999
      12,285
      10-18-2019 08:43 AM #53
      In a move that surprises nobody, putting the 2.3 back on the bike resulted in a much better experience. I'm going to build the Top Fuel back up and try the 2.6s on that, at which point I'll come to the same conclusion. Then I'll sell them.
    5. 05-25-2020 09:11 AM #54
      Samson, have you tried fitting a 36 chainring on the Chisel frame? Was there sufficient clearance? My chainline is currently at around 52.5mm.
    6. Member Samson's Avatar
      Dec 2nd, 1999
      12,285
      05-25-2020 02:36 PM #55
      Quote Originally Posted by vwconvert View Post
      Yep, a 36t fit fine. I would imagine a 38t and possibly larger would fit. I ended up selling the frame after I bought the Crockett frameset, otherwise I'd go check.
    7. 05-26-2020 01:46 PM #56
      Thanks. Already sold the Chisel? Didn't like it?
    8. Member Samson's Avatar
      Dec 2nd, 1999
      12,285
      05-26-2020 02:13 PM #57
      I liked it, but I didn't ride it much (400 miles total). The Top Fuel is still around, and it suits my riding style a bit better. The Chisel was a lot of fun and remarkably compliant (though the Crockett is too... maybe new aluminum frames are just a lot better than they used to be?), and had I not decided that I just had to get a pink and purple frame, I'd still have it.
