Fourtitude.com - List of aftermarket parts available for 1.4T engine ( NORTH AMERICA )
    Page 7 of 7 FirstFirst ... 34567
    Results 151 to 164 of 164
    1. 06-17-2019 07:38 PM #151
      Quote Originally Posted by Poetic50 View Post
      is there any more info on this?
      they showed the turbo, any info on upgraded internals/manifold/intercooler/piping? I'm quite curious on the parts and cost on this one!
    3. 06-17-2019 09:38 PM #152
      Quote Originally Posted by Kessel00 View Post
      That looks like the older twin charged 1.4. Which would make sense given the claimed power figures.
    4. 06-17-2019 11:34 PM #153
      Quote Originally Posted by Romanov View Post
      Sadly it’s is the older twin charged . However RTMG made 230HP with only 0.8 Bar of boost on a 1.4Tsi with a GtX 2860r turbo. Not bad considering the boost and the HP.
    5. 06-18-2019 10:37 AM #154
      I'm curious what the full potential of the 1.4T would be if there were upgraded engine internals with a new intake manifold, perhaps plasma igniters.... everyone says go 2.0! Hell, might as well drop in a V6 twin turbo if there's room.
    6. 06-18-2019 12:43 PM #155
      VR6 Jetta would be SICK
    7. 06-18-2019 08:56 PM #156
      Nah a 2.7TT. Lol
    8. 07-03-2019 08:43 AM #157
      http://www.turbosmartdirect.com/Prod...psi-Black.html
      Has anyone purchased and installed one of these?
    9. 07-03-2019 12:39 PM #158
      Unless you change the turbo for something that doesn't have a wastegate already there's no need. The stock turbo is internally wastegated.
    10. 07-03-2019 10:33 PM #159
      Quote Originally Posted by Tsiguy View Post
      Installed unitronic catted downpipe today, no different sound, still quiet with stock exhaust but definitely gained alot of torque, car yanks you to the right when it shifts gears at full throttle, will be giving a stage 2 review in the next few days
      Any updates on the stage 2 tune?
    11. 07-08-2019 09:36 PM #160
      Having some issues with the car after dp install and tune, about $500 into investigating it and still havent found the problem, car is running lean, will update after issues are resolved
    12. 07-09-2019 03:30 PM #161
      Exhaust leak? Check around the o2 sensor and the clamp mounting the dp to the turbo, might need retorqued or refitted
    13. 07-10-2019 06:06 AM #162
      Sent from my iPhone using Tapatalk[/QUOTE]
      That's the next thing I have to check, changed all coils and plugs
      Changed o2 sensor
      Checked for vaccum leaks and have had no luck
    14. Junior Member vwmeater's Avatar
      May 3rd, 2004
      Quebec, Canada
      80
      07-10-2019 10:30 PM #163
      How did you find out it was running lean?? DTC in ecm? How are the fuel trim?
      Jetta GLI 2002 vr6 24v: ABD CAI, TT cams, ECS crank pulley, Gruven Parts water pump + tensioner pulley, 4bar fpr, Unitronic stage 2 with Magnaflow high flow cat and rear resonator, 034 track mounts, GC spring/Koni yellow , Autotech rear sway bar/no front, Neuspeed strut bar, TT lca/spindle, , Ecs 12.5mm spacer, Hawk HP+ with 12.3in, To come: 13.1 brakes with 4pot touareg caliper!
    15. 07-11-2019 09:44 AM #164
      Quote Originally Posted by vwmeater View Post
      My buddy hooked his computer up and ran the codes and it came back saying it was running lean, and I'm new to tuning so that other stuff is basicly spanish
