Fourtitude.com - VR6 12V TPS signal issue
    Results 1 to 3 of 3
    1. Member markeysscirocco's Avatar
      Oct 23rd, 2006
      Cleveland, OH
      2,801
      95' VR6 GLX Passat 87'16VT Scirocco Custom, 00'VR6 Jetta
      03-16-2017 01:17 PM #1
      Been having trouble with TPS signal to ECU but when I tested it, it showed having a signal. Engine idle low and rough and hesitates bad at around 2500-3000 rpm. If I disconnect the TPS it doesn't have any issue other than high idle that surges. TPS is new. Swapped ECU to confirm issue and same results. Cut what seemed to be bad signal wire and re pinned with same issue?! Could it be TPS calibration ?! This is cable and not motorized. Help!!
      Sent from my iPhone using Tapatalk Pro
      I like Turbo's
      Markeysscirocco
    3. Semi-n00b
      Feb 20th, 2018
      Albuquerque New Mexico
      18
      95 Audi A4, MK4 Jetta VR6, Dodge Dakota
      03-13-2018 06:22 PM #2
      You could have a frayed or shorted a wire somewhere further up the wiring harness or at the harness pigtail or sensor pigtail.
    4. Member markeysscirocco's Avatar
      Oct 23rd, 2006
      Cleveland, OH
      2,801
      03-15-2018 12:56 PM #3
      I had the same problem with new tps and vag com measures no signal and went through the same exact procedure you did and I finally swapped the MAF sensor and bam fixed it! 185k on this motor and a year of this issue. I would at the very least get a known good MAF and test this known issue!
      I like Turbo's
      Markeysscirocco
