Fourtitude.com - 2001 s4 driver side fan issue
    Results 1 to 2 of 2
    1. 01-01-2017 08:07 PM #1
      I have a 01 s4 6speed manual the driver side fan is always on doesn't matter what the temp is at is it possible to just disconnect that one fan? Until I can fix the issue does anyone know where I can disconnect it from I know it's under the plastic piece by the power steering reservoir is ?
    3. Member GRMNMUSL's Avatar
      May 22nd, 2009
      New York
      400
      B5 S4 Avant/04' Allroad
      10-03-2018 11:08 AM #2
      You have to remove the fan itself I thing its a 32mm open end wrench. You have to use a pry bar and brace the fan shaft/bolts so it doesn't move.
      Once you crack it it just spins off.
      The thermal fan clutch is like $50-60 just replace it. I have a good used one for $25 shipped but you might as well just replace it new.
      https://blog.fcpeuro.com/audi-a6-2.8...eplacement-diy
      Buncha B5's... Too many to list!
      01' S4 Avant/04' Allroad
      Squatt/Chirp/Puff.... Woooooooosh!
