Fourtitude.com - Mk4 O2J 1st Gear whine
    Results 1 to 13 of 13
    1. Member cmdshft's Avatar
      Oct 17th, 2011
      Hackensack, NJ
      1,005
      2003 GTI 1.8T Airlift 3P
      12-04-2016 02:22 AM #1
      Been noticing lately that 1st whines from ~2500rpm and up. No other gear has any whine.
      Around the end of spring/beginning of summer, I changed the gear oil with Syncromesh (had a grinding 3rd and no longer grinds) and replaced the end cap seal, the 2 pivot pin o-rings, re-sealed the tower emblem and put in 2 new axel flange diff seals. Never noticed any noise until recently.
      Any idea what could cause this noise? Is there anything I should worry about? I have no other symptoms other than noise. Trans does not leak anymore.
      @cmdshft
      Jan 3rd, 2012
      coal township penna
      321
      2001 Mk IV 200,000 traded jetta for 2001 Audi TT 225Q Roadster
      12-04-2016 01:33 PM #2
      like my 2001 wolfie the O2J tranny was a poor shifting box from new + by 99,xxx could barely get into 5th others poor as well, i put Redline MT-90 in it + shifting was better + better as i drove more! at 150,xxx ripped teeth off 5th in hi boost 25lb mode!! a good rebuild by APTuning in Lebanon Pa + all is well except my bank account!!!
    4. Member cmdshft's Avatar
      Oct 17th, 2011
      Hackensack, NJ
      1,005
      12-06-2016 08:49 PM #3
      So no actual info to share?
    6. Member cmdshft's Avatar
      Oct 17th, 2011
      Hackensack, NJ
      1,005
      01-13-2017 07:01 PM #4
      Bump.
      I'm thinking of changing the gear oil back to an OEM spec oil due to the whine, since I noticed this has come on a while after putting Syncromesh in. My shifting has been very good, especially now that I've installed new engine and trans mounts and I am getting solid shifter bushings soon as well. Hoping using an OEM oil will take away the whine.
    7. Member cmdshft's Avatar
      Oct 17th, 2011
      Hackensack, NJ
      1,005
      01-14-2017 11:47 AM #5
      Any ideas?
      @cmdshft
    8. Member cmdshft's Avatar
      Oct 17th, 2011
      Hackensack, NJ
      1,005
      01-16-2017 01:06 AM #6
      talkin to meself here
    9. Member cmdshft's Avatar
      Oct 17th, 2011
      Hackensack, NJ
      1,005
      01-18-2017 08:47 PM #7
      bump
    10. 01-24-2017 08:19 PM #8
      The noise could be from 1st and reverse rubbing on each other of the over center spring breaks.
      It can also be caused when the needle bearings sit and basically pit the bearing surface of the gear or shaft, which at certain speeds will whine. Worn bearing can cause it also. So you will have to pull the trans, take it apart and verify whats going on inside.
    11. Member cmdshft's Avatar
      Oct 17th, 2011
      Hackensack, NJ
      1,005
      01-25-2017 02:26 AM #9
      Quote Originally Posted by HGB View Post
      Should I worry about it though? It gives me no problems.
      I'm going to try so MOS2 additive first and see if that quiets up the whine.
    12. Member cmdshft's Avatar
      Oct 17th, 2011
      Hackensack, NJ
      1,005
      01-26-2017 07:08 PM #10
      Also, would a bad inner CV whine as well?
      @cmdshft
    13. Member cmdshft's Avatar
      Oct 17th, 2011
      Hackensack, NJ
      1,005
      02-17-2017 02:23 AM #11
      Quote Originally Posted by cmdshft View Post
      Bumping for this question to get answered.
      I seriously have no issues with shifting, engagement and no popping out. Just the minor whine. Wondering if my Syncromesh oil is too thin causing it to whine on 1st.
      Also of note, the sound isn't audible with the windows down. Only with the windows up all the way do I really hear it in the cabin.
      I imagine it's really not that big of a deal, this is not the original trans, found the receipt for a rebuilt trans in the car's manual from 5 years ago.
    14. Member cmdshft's Avatar
      Oct 17th, 2011
      Hackensack, NJ
      1,005
      02-22-2017 01:55 PM #12
      Bump
      @cmdshft
    15. 08-04-2019 10:02 PM #13
      Hey cmdshft,
      I’ve got the same problem going on with my VR6, used synchromesh as well and it just started... Did you figure out how to get rid of it?
