Fourtitude.com - MK2/3 front camber plates
    Results 1 to 3 of 3
    1. Member BumblebVR6's Avatar
      Nov 21st, 2001
      Houston, TX
      2,548
      98 GTI VR6 / 05 A4(B6)
      11-28-2016 10:04 AM #1
      Has anyone installed these? Trying to source a solid alternative to the mounts available out there. Mainly interested in the solid mounting with spherical bearing in these. The camber adjustment is also a nice feature:
      http://www.performancebyie.com/iemk3...FQsQgQodNCAAiA
      or
      http://www.ground-control-store.com/.../II=727/CA=195
      Oct 10th, 2014
      Pittsburgh, PA
      227
      1991 Jetta Gli & 1990 Jetta Coupe
      01-24-2017 01:23 AM #2
      I have also been looking at options for a set of camber plates. I saw a similar pair cant remember where but ill look for them and post a link if I can find it. The pair I saw really caught my eye. maybe USRT?
      Found it.
      http://www.usrallyteam.com/index.php...oducts_id=1399
    4. Member o2bad455's Avatar
      Aug 22nd, 2003
      Northeast USA and Canada
      1,257
      VW A1-Chassis ABA16vT VWMS, VW A5-Chassis PD-TDI DSG, Audi B5-Chassis 2.7T 6MT
      01-29-2017 12:15 PM #3
      Keep in mind that spherical bearings are much better at handling radial loads rather than axial loads. There are three resulting approaches:
      1) Use spherical bearing in axial loading but replace frequently.
      2) Use otherwise greatly oversized spherical bearing in axial loading.
      3) Use some other means or bearing for axial loading and let the spherical bearing handle just the radial loading.
      If memory serves, the Ground Control plates use method #3 and work well. In my experience, though, the simpler spherical bearing types (e.g., Carrera) work fine and are usually designed to let you replace just the bearing quite easily (e.g., single circlip, etc.). If you get some that use a common bearing size, they can usually be sourced immediately/locally due to common interchange rather than having to wait for replacements to be shipped from the original supplier. YMMV
