Fourtitude.com - Help! 2007 Toyota Camry Le (2.4L) won't work
    Results 1 to 16 of 16
    1. 10-18-2016 06:40 PM #1
      Fellow co-worker has a 2007 Toyota Camry with 100K+ miles. Per her report, she lent the car to a friend over the weekend, but received a call later that evening informing her the car started to buckle and eventually shut off after a left turn. Car was not being driven aggressively. Car towed to nearby mechanic, who alleged the engine had no oil on the dipstick and was "knocking really bad." Mechanic also said battery terminal was bad, which he replaced. After putting fresh oil in the car, he said the car continued to knock and kept dying out. Per the mechanic, car was being driven without oil for some time. Co-worker, who is diligent in this regard, routinely gets oil replaced, most recently 3-months ago at a lube shop. Car ran fine up till this event. Mechanic towed car to co-worker's house, stating the entire engine needs to be replaced, which will set her back approximately $5,000 - funds which she does not have, especially being a student.
      Any other explanations for what might be going on? Co-worker said car does start, per the mechanic, but does not accelerate, and eventually dies out. The knocking part sounds peculiar, cause a car without oil typically screeches with the metal-on-metal movement. Also, co-worker said no colored exhaust that would suggest oil being burned.
      Since people will likely want "pics of co-worker or get out" I give you this Google Image searched photo of co-workers discussing a project at work. I personally prefer the blonde on the left, as she seems she would be into ATM
    3. Banned ChillOutPossum's Avatar
      Nov 7th, 2007
      KLPR
      18,568
      '14 GMC Sierra, '88 Mitsubishi Jeep CJ3B
      10-18-2016 06:44 PM #2
      Sounds like the engine was run low on oil.
    4. Angry Administrator nater's Avatar
      Apr 10th, 2000
      87,611
      2018 Atlas 4MO, 2008 3.6L Passat 4Mo, 98 O2M 3.0L VRT, '04 .:R32, 2014 CC R-line
      10-18-2016 06:44 PM #3
      I run an auto repair shop. I see way too much of this. A car that had low oil (for whatever reason) can drive long enough to create an issue inside, but not spin bearings (which pretty much seizes most engines). They will knock badly even after putting oil back in. Metal noise? Maybe...but from the sounds of this something bad happened.
    5. Angry Administrator nater's Avatar
      Apr 10th, 2000
      87,611
      10-18-2016 06:45 PM #4
      Quote Originally Posted by GoHomePossum View Post
      My words exactly, without being a yenta.
    6. Banned ChillOutPossum's Avatar
      Nov 7th, 2007
      KLPR
      18,568
      10-18-2016 06:50 PM #5
      Quote Originally Posted by nater View Post
      One day I'll be as tactful as you, turtle man.
    7. 10-18-2016 08:25 PM #6
      I think 2,000 sounds more realistic ,how much a is toyota mill for this at a salvage yard 800.00$
    8. Member rimtrim's Avatar
      Dec 17th, 2004
      Phila PA
      3,993
      2007 Buick LaCrosse CX, 1986 Pontiac Parisienne Safari
      10-18-2016 09:08 PM #7
      These engines are known for burning oil. If the owner changes the oil on schedule but never checks it, it could easily have burned it all off.
      Toyota is actually re-ringing these engines for free if they burn more than 1 quart per 1K miles in a certified test. I imagine they won't change the whole engine if you failed to check the oil, though.
      -Andrew L
      "The whole economy is hinged on potholes." --Ray Magliozzi
      Thousands of hubcaps in stock at www.rimtrim.com | Pontiac Project Thread
    9. Angry Administrator nater's Avatar
      Apr 10th, 2000
      87,611
      10-18-2016 09:16 PM #8
      Quote Originally Posted by rimtrim View Post
      -Andrew L
      And they actually re-ring them with nothing else. No honing, etc. they slap new rings in and send you on your way. . It's true.
    10. Member rimtrim's Avatar
      Dec 17th, 2004
      Phila PA
      3,993
      10-18-2016 09:52 PM #9
      That's probably not such a bad thing. The Toyota oil-burning problems seem to be caused by stuck oil control rings due to carbon buildup. Nothing is actually worn out or damaged. I've heard plenty of stories of the '98-02 Corolla/Prizm 1ZZ engines going from crop-duster status to no oil consumption at all, just from a basic ring job. Of course, that's not going to help the owner in the OP, if someone drove the car around with no oil in the engine...
      -Andrew L
    11. Senior Member Iroczgirl's Avatar
      Feb 17th, 2007
      Bend, OR
      33,704
      Hot hatchback coupé heaven
      10-18-2016 09:59 PM #10
      Sounds like someone never checked the engine oil level.
      Consider it "lesson learned". A very expensive lesson indeed.
    12. 10-18-2016 10:18 PM #11
      The end result being one less friend?
    13. Member Benjamin.'s Avatar
      Nov 12th, 2001
      Hanover, PA
      9,943
      1990 Miata, 1991 F150, 2005 Grand Caravan, 2019 Odyssey EX-L
      10-18-2016 10:24 PM #12
    14. 10-19-2016 02:09 PM #13
      So presumably the engine is toast. Not sure if Toyota's have low oil warning, but one would expect that to, or at least a 'check engine' light, to come up. Besides motor being replaced, I assume there is no way to fix this.
    15. 10-19-2016 03:40 PM #14
      My wife had a 2010 Camry with the 2.4 I4 that lost at least 2 quarts of oil (I know it wouldn't even register on the dipstick. This happened after a Toyota mechanic didn't install the oil filter right (Thanks ToyotaCare).
      Long story short, the engine ran fine after that but was noisy on startup. It was quiet after it warmed up and didn't burn any oil. These motors are tough in my experience.
      if anyone is interested, the dealer extended the warranty to 150K miles in writing, so we were at least satisfied.
    16. Member Unilateral Phase Detractor's Avatar
      Aug 23rd, 2005
      Columbus, Ohio
      13,774
      10-19-2016 04:26 PM #15
      I feel bad for co-workers friend. Friend will probably be blamed even though it's pretty clear the oil level wasn't checked since the last change. Good luck...
    17. 10-19-2016 08:38 PM #16
      Do they have an extended policy for this? I have no clue but yea a used engine plus labor shouldn't be too much, 2k is a lot if strapped but a car is essential!
      Sent from my SM-G920T using Tapatalk
