What do I do?
6K views 1 reply 1 participant last post by  Geramy1232
My GTI today after not being driven for 2 weeks turned on the airbag, ESP, and ABS lights while driving it was driving normal and they just started turning on one by one. Any idea what this could be? Should I try resetting it while disconnecting the battery?
#2 ·
Update: here is the data log of the codes
VIN: WVWEV7AJ2AW127518
CAN network gateway
Part #: 1K0907530AA
Coding: E9811F07001612000000 (hex)
Component: J533 Gateway
[No fault codes]
Engine
Part #: 1K0907115AM
Coding: 0403010A18070160 (hex)
Component: 2.0l R4/4V TFSI
Fault codes:
P0033 Turbo Charger Bypass Valve (N249), Control Circuit
53271 Manufacturer-specific code
P2015 Intake Manifold Flap Position Sensor (Bank 1): Implausible Signal
Engine
[failed to connect]
Engine
[failed to connect]
Transmission
[failed to connect]
ABS
Part #: 1K0907379AM
Coding: 114B600CC9240001881006E5931F00413008 (hex)
Component: ESP MK60EC1
Fault codes:
00287 Right Rear Wheel Speed Sensor (G44)
Brake booster
[failed to connect]
Parking brake
[failed to connect]
Power steering
Part #: 1K0909144H
Coding: [none]
Component: EPS_ZFLS Kl. 74
Fault codes:
01316 ABS Control Module
Steering angle
[failed to connect]
Active steering
[failed to connect]
Steering wheel
Part #: 1K0953549CF
Coding: 532 (decimal)
Component: J0527
[No fault codes]
Airbags
Part #: 5K0959655B
Coding: 00003031 (hex)
Component: AirbagVW10G
Fault codes:
9483008 Manufacturer-specific code
Instrument cluster
Part #: 5K6920970G
Coding: 270F00 (hex)
Component: KOMBI
[No fault codes]
Infotainment display
[failed to connect]
Infotainment display (front)
[failed to connect]
Infotainment display (rear)
[failed to connect]
Infotainment display (rear left)
[failed to connect]
Infotainment display (rear right)
[failed to connect]
Infotainment display (roof)
[failed to connect]
Navigation
[failed to connect]
Voice control
[failed to connect]
Radio
Part #: 1K0035180AC
Coding: 0100040004 (hex)
Component: Radio Prem-8
Fault codes:
02635 Tuner not enabled / activated
Digital radio
[failed to connect]
Satellite radio
[failed to connect]
Sound system
[failed to connect]
Media player
[failed to connect]
Media player
[failed to connect]
Media player
Part #: 5N0035342B
Coding: 010000 (hex)
Component: SG EXT.PLAYER
[No fault codes]
Media player
[failed to connect]
TV tuner
[failed to connect]
Digital TV tuner
[failed to connect]
Infotainment system
[failed to connect]
Infotainment system 2
[failed to connect]
Telephone
Part #: 1K8035730C
Coding: 412100 (hex)
Component: Telefon
[No fault codes]
Immobilizer
Part #: 5K6920970G
Coding: [none]
Component: IMMO
[No fault codes]
Towaway protection
[failed to connect]
Headlight aiming
Part #: 5M0907357C
Coding: 1446940 (decimal)
Component: AFS-Steuergeraet
[No fault codes]
Left headlight
[failed to connect]
Right headlight
[failed to connect]
Tire pressure monitor
Part #: 1K0937087G
Coding: 000000 (hex)
Component: RDK
Fault codes:
01325 Control Module for Tire Pressure Monitoring (J502)
[failed to connect]
Heater & air conditioning
Part #: 3C8907336N
Coding: 0000000000 (hex)
Component: Climatic
[No fault codes]
Rear heater & A/C
[failed to connect]
Auxiliary heater
[failed to connect]
Auxiliary heater
[failed to connect]
Parking sensors
[failed to connect]
Parking/steering assist
[failed to connect]
Auto-leveling suspension
[failed to connect]
All-wheel-drive system
[failed to connect]
Differential lock
[failed to connect]
Chassis
[failed to connect]
Suspension
[failed to connect]
Central electronics
Part #: 1K0937087G
Coding: 6F180ABE90252A048088008174008BAC47650086534D8D60648020200000 (hex)
Component: BCM PQ35 H+
[No fault codes]
Central electronics 2
[failed to connect]
Body/convenience system
[failed to connect]
[failed to connect]
Driver's door
Part #: 5K0959701B
Coding: 1076 (decimal)
Component: Tuer-SG
[No fault codes]
Front passenger's door
Part #: 5K0959702B
Component: Tuer-SG
[No fault codes]
Rear left door
[failed to connect]
Rear right door
[failed to connect]
Trunk
[failed to connect]
Driver's seat
[failed to connect]
Front passenger's seat
[failed to connect]
Rear seat
[failed to connect]
Rear seat (driver's side)
[failed to connect]
Entry assist (driver)
[failed to connect]
Entry assist (passenger)
[failed to connect]
Ignition authorization
[failed to connect]
Battery regulator
[failed to connect]
Battery charging
[failed to connect]
Convertible top
[failed to connect]
Roof electronics
[failed to connect]
Windshield wipers
[failed to connect]
Trailer
[failed to connect]
Adaptive cruise control
[failed to connect]
Lane-change system
[failed to connect]
Lane-maintain system
[failed to connect]
Position sensing
Part #: 5N0919879
Coding: 2 (decimal)
Component: Kompass
[No fault codes]
Back-up camera
[failed to connect]
Telematics
[failed to connect]
Driver ID
[failed to connect]
Intercom
[failed to connect]
Additional functions
[failed to connect]
Operations
[failed to connect]
Hybrid engine
[failed to connect]
Back-up camera
[failed to connect]
Image processing
[failed to connect]
Sliding door (left)
[failed to connect]
Sliding door (right)
[failed to connect]
Sent from my iPad using Tapatalk
