Fourtitude.com - engine siezed after timing belt service
    Results 1 to 4 of 4
    1. Junior Member torchmonky's Avatar
      Apr 26th, 2006
      Oly
      61
      2001 GTI 1.8T
      07-30-2016 02:29 PM #1
      I'm not sure what gives. was a running car pulled into garage. 2001 audi tt engine code awp had a code for vvt failing to reach upper limit. I did timing belt kit and chain tensioner replacement. rolled engine over by hand afterward, all marks checked out so I pulled the tensioner pin and reassembled the front of the engine. tried to start it and the engine made a squeal and seized instantly. I believe the squeal was from the starter cause the engine didn't even make a quarter rotation. it is now locked in both directions. ill be stripping it back down to the timing belt when I have time, as of now not sure if its the top or bottom that is stuck and generally confused as to what happened.
    3. Junior Member torchmonky's Avatar
      Apr 26th, 2006
      Oly
      61
      2001 GTI 1.8T
      10-01-2019 02:53 AM #2
      BTW this was a faulty tensioner. Bolt bent when I released tension, and the roller locked up. Wow been awhile lol. Thanks for all the help.
    4. Semi-n00b
      Jun 5th, 2012
      Grand Junction, CO
      10
      e28, e21, B3 Quattro, MK2 GLI
      10-01-2019 12:04 PM #3
      Quote Originally Posted by torchmonky View Post
      Thank you for updating, despite the lack of help. New owners like me search the forums for info all the time. This was useful.
      Took 3rd and 4th place BMW show 'n shine at Wuste 2012!
    6. Senior Member Vegeta Gti's Avatar
      Feb 12th, 2003
      konoha village, hawaii
      21,484
      1984 GLi 20v, '16 M3, '85 Golf, '17 R
      10-03-2019 11:09 AM #4
      2001, that's a bea car not awp iirc
      Sent from my SM-N950U using Tapatalk
      :HOMEGROWN MOTORSPORTS..SingerVehicleDesign...1:4.9 SuaSponte #13Dead Rabbits. Ungluck on IG. MKIforLife
      Quote Originally Posted by .Ant View Post
      What vegeta said.
