Fourtitude.com - 3.6 24V VR6 Swap Questions & Links
    Page 15 of 15 FirstFirst ... 51112131415
    Results 351 to 358 of 358
    1. Member G60ING's Avatar
      Jun 27th, 2000
      Annapolis Area MD
      15,739
      09-28-2019 08:53 AM #351
      It’s so great, after all the driving the only fluid leak is a minor dribble from the transmission. It took some wrenching to achieve that. At first the power steering and oil filter flange leaked. Then after I cured those the 2nd block’s vacuum pump delete leaked and with a new blockoff plate that’s cured.
      Now I just need to install some output flange seals.
      Jul 4th, 2016
      Palmyra, PA
      245
      2014 FiST, 92 Corrado 3.6
      11-16-2019 11:49 PM #352
      Did you ever solve the fuel level sending unit issue? I ran across this adapter box on the internet. I am guessing it is a microprocessor based solution that outputs a voltage scaled to your ohm limits.
      Testing the B6 level sender rheostat, the limits I tested for that are 55 ohm to 250ohm empty to full. Corrado is arond 40 ohm to 285ohm full to empty. Fairly close but you could really dial that in with that conversion box possibly without flipping the float too.
      Former username: Magics5rip
      Corrado 3.6 build thread
    4. Member G60ING's Avatar
      Jun 27th, 2000
      Annapolis Area MD
      15,739
      11-17-2019 08:37 AM #353
      Oh that’s great, I haven’t resolved it but in the past year of driving have gotten very used to how it works.
      First I try to fill up every 200miles (10gallons) but realistically can go 280-300 miles (18-20mpg) even if I’m pushing it and 320 if I’m not pushing the car hard, 20-23 mpg.
      Second the float goes from empty up to about a 1/4 tank and when above 1/4 tank I begin to get concerned about filling up.
      All that said it would be cool to get it fixed to work correctly. Thank you
      https://www.tanksinc.com/index.cfm/p...rod/prd748.htm
    6. Member G60ING's Avatar
      Jun 27th, 2000
      Annapolis Area MD
      15,739
      11-20-2019 01:47 PM #354
      Anybody looking for misc 3.6 sensors, coilpacks, MAF ping me. I often have them from cars I pull harnesses from. $25 minimum or $75 for the care package of everything pictured below.
      Jul 9th, 2015
      SLC, UT
      818
      1987 MK2 GTI 8V, 1981 Lago blue 2 dr 1.8t swap AEB upper, AWP lower K04 tuned
      12-11-2019 08:06 PM #355
      Quote Originally Posted by G60ING View Post
      I am doing a swap for a buddy, im sure I will need these parts
    8. Member G60ING's Avatar
      Jun 27th, 2000
      Annapolis Area MD
      15,739
      12-12-2019 01:34 AM #356
      I replied to your message, I still have this care package available.
    9. 01-05-2020 05:42 PM #357
      Hey bro, thanks to all your help with the wiring diagram. Here she is
    10. Member G60ING's Avatar
      Jun 27th, 2000
      Annapolis Area MD
      15,739
      01-05-2020 11:17 PM #358
      Beautiful, nice work. Do you have a link to the build?
