Hello! Need help my Skoda Octavia 1Z, 2008 2.0TDI 103kw
Backup lamps dont work, i guess its switch problem, vcds checked switch and always OFF.
Mirror parking lights dont work, right corner light dont work, steering wheel buttons not responding and xenon terminal 56.
i put my autoscan.
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 55 56 62 69 72 76
VIN: TMBGE61Z288030842 Mileage: 278820km/173250miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
Address 01: Engine Labels: 03G-906-021-BMM.clb
Part No SW: 03G 906 021 JC HW: 03G 906 021 AB
Component: R4 2,0L EDC G000SG 1369
Revision: --H07--- Serial number: SKZ7Z0H4775347
Coding: 0000072
Shop #: WSC 73430 000 00000
VCID: 69D95B2F408C395623D-803C
1 Fault Found:
008194 - Particulate Trap Bank 1
P2002 - 000 - Efficiency Below Threshold - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 278537 km
Time Indication: 0
Date: 2000.00.00
Time: 14:55:01
Freeze Frame:
RPM: 2184 /min
Speed: 114.0 km/h
(no units): 5.10
(no units): -10.20
Mass Flow: 45.51 g/s
Temperature: 336.0°C
Temperature: 20.7°C
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0000641
Shop #: WSC 73430 790 00000
VCID: 3F8DA5776E8867E6AD9-806A
No fault code found.
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1Z0 907 044 AB HW: 1Z0 907 044 AB
Component: ClimatronicPQ35 120 0600
Revision: 00120022 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 76E300530132E6AEBEF-8023
1 Fault Found:
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000005560832
Coding: E98A0F130004140043110D000000000000097F065C00000C00 0000000000
Shop #: WSC 80152 462 20586
VCID: 71E9334F685CC1966BD-8024
Subsystem 1 - Part No: 1Z1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 220208 022 0601
Coding: 00055223
Shop #: WSC 80152
Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 220208 046 0204
Coding: 00471077
Shop #: WSC 80152
2 Faults Found:
00985 - Right Tail Light (M2)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 83
Mileage: 278822 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 11.75 V
ON
ON
OFF
OFF
OFF
00979 - Lamp for Low Beam; Right (M31)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 83
Mileage: 278822 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 11.50 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 AA HW: 1K0 909 605 AA
Component: Q2 AIRBAG VW8 027 0900
Revision: 11027000 Serial number: 003B5D14BML5
Coding: 0020786
VCID: 6BD521274A702B46511-803E
Subsystem 1 - Serial number: 6332MSME3C657560F
Subsystem 2 - Serial number: 6342MSME2F706625F
Subsystem 3 - Serial number: 6351HSME14025A3D5
Subsystem 4 - Serial number: 6361HSME136C4C5FQ
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BG HW: 1K0 953 549 BG
Component: J0527 051 0100
Coding: 0002042
VCID: 78FF0E6B0B2690DEAC3-802D
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 002 0010
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1Z0 920 842 D HW: 1Z0 920 842 D
Component: KOMBIINSTRUMENT VD1 1612
Revision: V1612036 Serial number: SKZ7Z0H4775347
Coding: 0007101
Shop #: WSC 00011 888 96745
VCID: 387FCE6B4BA650DE6C3-806D
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 P HW: 1K0 907 951
Component: J533__Gateway H16 0192
Revision: H16 Serial number: 2500K08220027D
Coding: E9817F4E4002022302
Shop #: WSC 00269 211 64280
VCID: 3467FA5B57CEB4BE40B-8061
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VD1 1612
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 3T0 035 680 A HW: 1Z0 035 680 A
Component: RNS-MID H04 2764
Revision: AB001001 Serial number: SKZ6Z7H7060055
Coding: 000004000000000100
VCID: 2E53E83379E29E6E36F-807B
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 D HW: 1T0 959 701 D
Component: Tuer-SG 006 1203
Coding: 0000246
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.069 H08 1901
Shop #: WSC 73430 000 90108
VCID: 3561C75F5CB4ADB6775-8060
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 80801A085283007F3F02850500084F01807C00
VCID: 8305E987C2E04306091-80D6
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 D HW: 1T0 959 702 D
Coding: 0000246
VCID: 3979CB6F70AC49D693D-806C
Address 55: Xenon Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000007
Shop #: WSC 73430 790 08192
VCID: F4E7BA5B974E74BE00B-80A1
1 Fault Found:
01533 - Terminal 56 (High Beams)
011 - Open Circuit - Intermittent
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 J HW: 1K0 959 703 J
Component: Tuer-SG 006 1301
Coding: 0000144
Shop #: WSC 73430 790 1012544
VCID: 377DCD5746B85FA6659-8062
Address 69: Trailer Labels: 1K0-907-383-MY7.lbl
Part No SW: 1K0 907 383 HW: 1K0 907 383
Component: ANHAENGERELEKTR 003 0020
Coding: 0000001
VCID: EADBA423C58AB24EAA7-80BF
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 J HW: 1K0 959 704 J
Coding: 0000144
Address 76: Park Assist Labels: 1Z0-919-283.lbl
Part No SW: 1Z0 919 283 C HW: 1Z0 919 283 C
Component: Parkhilfe 8-Kan H04 0020
Coding: 0010001
VCID: 3E73D87369826EEEA6F-806B
1 Fault Found:
01628 - Sensor for Parking-Aid; Front Mid-Left (G254)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 3
Reset counter: 83
Mileage: 278822 km
Time Indication: 0
Date: 2000.00.00
Time: 13:15:10
End ---------------------------------------------------------------------
Maybe someone know what is problem.
