Fourtitude.com - Negatives about installing an Air Intake 2.5L
    Results 1 to 22 of 22
      Mar 13th, 2016
      PA
      162
      2013 VW Jetta SE 2.5 sun/con.
      04-03-2016 11:49 PM #1
      What are the negatives of installing an air intake on a 2013 2.5? I keep hearing good and bad and not sure if it's worth it. I made a post recently buying one but I'm not sure if I learned much. Would like to buy a Aem short ram intake (21-733c if you want to look it up) as it's easy to install and won't suck water up. I heard you lose power under 3000 rpms and have throttle lag
    3. Member thygreyt's Avatar
      Jun 7th, 2009
      fort lauderdale, FL
      12,954
      1k-m-cbta-02q-PTE5858
      04-04-2016 12:40 PM #2
      an intake is not free.
      um... i dont see any negatives, at all.
      Mar 13th, 2016
      PA
      162
      04-04-2016 12:50 PM #3
      Quote Originally Posted by thygreyt View Post
      In terms of hearing you lose low end power?
      And some people say the engine air and fuel mixture can be messed up also, but won't the computer adjust for that?
      Jul 25th, 2011
      norwalk, ca
      490
      2012 JSW 2.5T 5MT; 2015 GSW 1.8tsi 6AT; 2016 Polaris Slingshot
      04-04-2016 02:58 PM #4
      Plenty of us run/ran intake and/or exhaust without software change will no ill-effects. They will give you a little bump in power, and a change in the sound the car makes. The stock tune does compensate for the increased airflow, and you don't lose ANY power on our engine with an intake.
      Here are some dyno charts of intakes, showing an increase throughout the powerband.
      Peter
      Nov 20th, 2012
      Colorado
      172
      MKV GLi
      04-04-2016 07:54 PM #5
      The stock air intake system is beyond idiotic to me.. I have no idea how they came up with that stupid ass deigns. Ive been trying to buy the APR CF intake for the last month, but totally out of stock everywhere
    8. 04-04-2016 11:51 PM #6
      I've tried both a cold air intake and a shorter ram style. Vastly prefer the shorter ram setup mainly because the longer CAI assembly was far too loud due to sound being directed down toward road surface. No performance difference.
      Mar 13th, 2016
      PA
      162
      04-05-2016 12:27 AM #7
      Quote Originally Posted by Moon5 View Post
      Are you running a SRI right now?!
    10. Junior Member
      Nov 24th, 2013
      Quebec
      82
      2009 Rabbit 2.5L - 1944 Ford GPW
      04-05-2016 10:52 AM #8
      Quote Originally Posted by Alex3280 View Post
      Short ram intake =/= Short runner intake manifold. Both are often called SRI but in case you meant the manifold.
      Short ram is just a shorter tube usually with a heat shield that draws air from the grille instead of from the wheel well like a CAI.
    11. Member
      Jul 20th, 2001
      5,294
      Fahrvergnügen
      04-05-2016 08:16 PM #9
      This. 100%.
    12. Member
      Oct 23rd, 2014
      Pennsylvainia
      274
      2010 Jetta 2.5L 5 Speed Manual, 1989 Honda Accord(Gone but Not Forgotten)
      04-06-2016 08:29 AM #10
      Quote Originally Posted by kölsch View Post
      This. 100%.
      It's pretty damn close if you go to advanced and make one
    13. Guest pete@blackforest's Avatar
      Aug 18th, 2011
      Raleigh, NC
      7,522
      VW/Audi/BMW
      04-06-2016 09:38 AM #11
      Quote Originally Posted by mkV Fanatic View Post
      Especially true if you have a CBTA 2.5l (no MAF, no SAI).
    14. Member
      Mar 13th, 2016
      PA
      162
      04-06-2016 09:41 AM #12
      What's cbta
    15. Member thygreyt's Avatar
      Jun 7th, 2009
      fort lauderdale, FL
      12,954
      04-06-2016 10:09 AM #13
      What's cbta
      engine code refering to +08.5 2.5L engines. they are map based, not MAF as the earlier versions.
    16. Member
      Mar 13th, 2016
      PA
      162
      04-06-2016 12:57 PM #14
      Pros and cons of map vs maf? Sorry this is all new to me
    17. 04-06-2016 03:04 PM #15
      Unsure about the maf location. But the Map sensor location on our 2.5's is terrible. It's located closer to bottom of the intake manifold, underneath the throttle body. In order to clear my P0106 code, I had to thoroughly clean the intake manifold. This has happened twice already. I'm most definitely getting a catch can to solve this once and for all.
      If anyone knows an answer to this, why wasn't the MAP sensor placed closer to somewhere at the top of the manifold?
    18. 05-28-2016 10:01 AM #16
      Yes, the Neuspeed ram setup. Much prefer it over the CAI system.
    19. Member
      Apr 13th, 2013
      SoCal
      126
      Golf MK6
      05-29-2016 01:53 AM #17
      Quote Originally Posted by AHouseOnFire View Post
      I think they choked it on purpose to not hurt GTI sales. The Apr intake is discontinued.
      2012 Golf Mk6
    20. Member
      Jan 11th, 2012
      El Segundo, CA
      159
      2012 VW Golf 2.5l
      05-29-2016 02:09 AM #18
      The only negative I can think of for the apr carbonio intake is the increased chance of hydrolock since the intake opening is so much lower than stock. You'd have to drive through some serious puddles for that to happen though.
    21. Member mjb8482's Avatar
      Mar 4th, 2008
      Buffalo, NY
      306
      2007 Jetta WE 2.5T (BGQ) --sold! 2013 Golf 2.5T (CBUA)
      05-29-2016 12:50 PM #19
      Quote Originally Posted by miguelr View Post
      Per my Bentley manual, it was designed to bring in heated air. Must be for emissions reasons. Certainly not for performance!
      Instagram: @mjb8482 | Buffalo, NY
    22. Junior Member Tenac's Avatar
      Mar 8th, 2015
      Agoura Hills, CA
      36
      '07 Rabbit
      05-30-2016 02:20 PM #20
      The best choice I've ever made with the Neuspeed Short Ram Intake off a forum member used; 3.5k+ RPM sounds much more wookie-er and I kept the engine cover off of course, because that thing was just an air-restricting, sound-dampening invention by the devil.
      On-Topic however:
      It would throw a CEL for a couple hours maybe once or twice a week, but I started using 91 and it's not as often, and I just passed smog the other day.
      The CEL was because the system was running too lean (codes P0171 and P0174), but I always found it happened in colder weather and it still sounded very healthy, and the light would be off the next day. I'll clean my MAF, clean and re-oil the intake, or do THIS to see if any of them help, but it's not really a high priority atm.
    23. 03-26-2020 04:44 AM #21
      Hello folks, i'm interested if Jetta mk6 and golf mk6 2.5l have same Oil Dipstick, cause i have golf's broken and couldn't get one, Jettas are more available in my region.
    24. Member JaxPlanet's Avatar
      Sep 17th, 2018
      169
      2012 JSW 2.5
      03-27-2020 01:44 PM #22
      Quote Originally Posted by goco97 View Post
      Welcome to the forum!
      Your question is not related to this post so it won't get the attention it needs.
      I would start by going to parts.vw.com and looking up your dipstick and then look at the bottom where it says "WHAT THIS FITS" and it will show you all the variants it fits.
      If that doesn't help, start a new post, like "Oil dipstick question for a <insert year and model of your VW here>".
      You can also post it the model-specific forum for your VW so it will get even more attention.
      Good luck!
      As for the original post: I love my Neuspeed P-Flo and it looks great with a Beetle engine cover.
