Fourtitude.com - What is the differences between EA888 Gen-1 and Gen-2?
    Results 1 to 8 of 8
      Dec 1st, 2009
      3,337
      2017 Audi SQ5, 2017 Corvette Grand Sport 7MT, 2010 Audi S4 6MT. 2015 Audi Q3 Quattro
      03-21-2016 12:20 PM #1
    3. Classified Advertiser
      Feb 4th, 2004
      30 S 5th Ave, Lebanon PA 17042
      25,191
      GTI s3+ 4mo, R s3+, MK4 R18 s3+, '74 100
      03-21-2016 04:31 PM #2
      Slightly different fueling system and Gen 2 had valvelift.
      Gen2 engines were only available in audi models I believe. A4, A3, and TT
      APTuning LLC, 30 s 5th Ave, Lebanon PA 17042, (717)272-0916
      aptuning.com - [email protected] - Facebook - Twitter
      APR Stocking Master Distributor - United Motorsport Distributor
      Dec 1st, 2009
      3,337
      03-21-2016 09:16 PM #3
      Thanks for the info.....so a side question...why does it seem that the Gen-2 (Audi valve-lift version) suffers so many more instances of oil consumption? I think the pistons and or piston rings are different, as that is what Audi claimed was the root cause of the excessive oil consumption issue.
    6. Classified Advertiser
      Feb 4th, 2004
      25,191
      03-22-2016 11:03 AM #4
      Quote Originally Posted by CC'ed View Post
      I don't believe its a design flaw in the sense that gen 2 is inferior. I almost think its a manufacturing/assembly issue.
      Dec 1st, 2009
      3,337
      03-22-2016 02:31 PM #5
      But both types of these engines are built in the same engine factory in Hungary...on the same production line. Did they only have the Audi Valvelift version built on the night-shift
    8. Former Advertiser AL@PagParts.com's Avatar
      Oct 23rd, 2008
      NY
      2,534
      07 AUDI 2.0T 07 VW GTI
      03-22-2016 10:33 PM #6
      They used completely different pistons and piston rings. I think they were going for a low friction compression primary ring which had sealing issues. Many pistons were actually replaced by Gen 1 pistons (from the transverse GTI) when warrantied.
    9. Member Bigo1087's Avatar
      Feb 19th, 2010
      Quincy
      250
      09 A3 SLINE TITANIUM, 2006 BMW M3
      04-29-2016 06:00 AM #7
      8P A3 doesn't have valve lift. It is the same engine as GTI, CC, Tiguan, Jetta.
      Sent from my Nexus 6P using Tapatalk
    10. Member kbad's Avatar
      May 26th, 2007
      southlake, TX
      1,246
      2010 CC 2.0T DSG Sport - Past VWs: 06 Passat 2.0T, 95 GLI, 87 Jetta Cpe, 80 Golf Cpe
      05-02-2016 04:18 PM #8
      hey man .. see page four of this pdf for more insight on the engines .. good luck!
