Fourtitude.com - g60 turbo conversion info
    Results 1 to 6 of 6
    1. 03-06-2016 12:08 PM #1
      Hi to all..i'm looking for a g60 turbo conversion..
      What is The max Power of g60 stock internals? And what about max Boost?
    3. 03-06-2016 03:26 PM #2
      Quote Originally Posted by francescodenetto View Post
      i put 308 thru pg block with stock rods. No Issues!
    4. 03-06-2016 03:28 PM #3
      308hp? With all stock internals?
      Inviato dal mio SM-N9005 utilizzando Tapatalk
    6. 03-13-2016 12:17 AM #4
      stock rods
    7. Member G60 Carat's Avatar
      May 14th, 2004
      Regina, SK
      6,546
      1982 BMW 320i, 1986 Jetta Carat 1.8/ABA Turbo
      03-15-2016 09:16 AM #5
      If you don't knock the motor the OEM cast pistons will cope with that. But being cast there is pretty no margin of error at that kinds of combustion pressure. If you get any knock you will crack them pistons/fracture the ring lands.
      "Criminally insane, with a few brief lucid intervals."
      | Rust | Zip-Ties | JB Weld | Bad Idle | Scrapes Ground | Rubs when Turning | Busted Ass Door handles |
    8. Member Slave2theBunny's Avatar
      Mar 15th, 2005
      Montreal Quebec
      239
      1981 VW Rabbit
      05-05-2019 09:24 AM #6
      Quote Originally Posted by jeffs vw View Post
      stock rods
      Apologies to OP, don't mean to hijack.
      Hi Jeff, do you have more details on your setup? I want to know how much the PG can hold depending on the internals, I have a PG bored out to 82.5 wossner pistons, arp everything. On my old JH, I was able to squeeze 197hp out of it (T3, megasquirt).
      Top end is all balanced TT big valve kit. Titanium retainers, heavy duty springs, tapered valve guides.
      Choice of replacement turbo will be dependent on available information I can get online.
