Fourtitude.com - Looking for advice on a obd1 12v vr swapped mk2
    Results 1 to 7 of 7
      Jan 30th, 2003
      MN
      391
      mk2helios radog60
      03-02-2016 11:04 PM #1
      Ok im not too familiar with vr6 and then a swapped mk2 vr. Question is i bought this car with obd1 setup and now it has a obd2 motor. Everything seems to be working properly other than it needs a maf. It didnt come with the correct one. The plug for the maf on the car is a 6 pin and the maf i have is obd2 4 pin. I dont know which exact years i need to look for for the 6 pin. Otherwise ive heard of people converting to the 4 pin. However im not sure how to do that. Can someone point me I the right direction to pics or other info? Thank you in advance!
    3. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      37,228
      15 Jetta 92 Corrado VR6
      03-02-2016 11:44 PM #2
      To convert to 4pin you need to be coilpack and use an ecu from a 94/95. If you are dizzy you are stuck.
      Probably easier to find a 6pin maf.
      -Paul
      Aug 8th, 2004
      Rockaway,NJ
      7,906
      94 golf
      03-02-2016 11:44 PM #3
      6 pin maf is corrado or 93-94 Passat.
      Jan 30th, 2003
      MN
      391
      mk2helios radog60
      03-03-2016 08:57 AM #4
      Quote Originally Posted by need_a_VR6 View Post
      My setup is coilpacks and i believe it is a obd1 ecu.
      Jan 30th, 2003
      MN
      391
      mk2helios radog60
      03-03-2016 08:58 AM #5
      Quote Originally Posted by bonesaw View Post
      Thanks. Are there any other models besides passat?
    8. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      37,228
      03-03-2016 09:10 AM #6
      92-early 94 Corrado, and non US 93-94 mk3s. Passat and Corrado will likely be the easiest to find.
      -Paul
    9. Member
      Jan 30th, 2003
      MN
      391
      mk2helios radog60
      03-04-2016 10:02 AM #7
      So i have a obd1 ecu and coil packs how would i convert to the 4 pin?
