Hey guys, I need some help figuring out which class my car is in for SCCA Autocross. I'm pretty sure it's in street prepared but I think I confused myself on the class rules.
It's a 83 VW Rabbit GTI, everything done to it is bolted on, not welded and can be reversed. It has:
-motor swap from a 1.8l 8v to a scirocco 1.8l 16v
-stock 8v transmission
-short shifter kit
-stock fuel system
-serpentine belt setup
-TT header
-adjustable can gear
-bolt in adjustable strut mounts (can adjust caster and camber)
-H&R coilovers
-extended balljoints
-tie rod flip kit
-front strut bar
-4 point lower control arm brace
-rear 3 point strut brace
-rear swaybar
-the rear seat has been taken out
-scirocco front and rear disc brakes with drilled and slotted rotors
-14x7 Revolution RFX's
-Kuhmo v710 race tires
-a/c removed
-factory manual steering
-short shifter kit
-stock fuel system
-TT header
-H&R coilovers
-tie rod flip kit
-front strut bar
-rear swaybar
-a/c removed
