Fourtitude.com - Audi A6 Check Engine Light Flashing....Help
    Results 1 to 4 of 4
    1. Member malibuboats91's Avatar
      Dec 2nd, 2008
      1,015
      2016 Audi S3
      11-10-2015 07:49 PM #1
      I recently picked up a 2003 Audi A6 3.0 with approximately 120,000 miles. Today while driving it the check engine light started flashing so I pulled over shut it off, then started it again and it was fine. This same thing happened one other time. I scanned it with my vagcom and came up with some codes, but I'm not sure what particular code would be the cause of the flashing CEL. It seems as though the converters are prone to failure but I'm not sure if I should remove it or not. I also saw that there were misfires so I'm not sure if thats the cause of the flashing CEL. Any help would be much appreciated!
      Tuesday,10,November,2015,15:37:08:17965
      VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
      VCDS Version: 15.7.1.0 (x64)
      Data version: 20150904
      www.Ross-Tech.com
      VIN: WAULT64B73N054211 License Plate:
      Mileage: Repair Order: AudiA6
      Chassis Type: 4B (4B - Audi A6/S6/RS6/allroad C5 (1998 > 2006))
      Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67
      75 76 77
      Address 01: Engine Labels: 06C-909-559-ASN.lbl
      Part No SW: 8E0 909 559 E HW: 8E0 909 059
      Component: 3.0L V6/5V G 0003
      Coding: 0016752
      Shop #: WSC 02325 785 00200
      VCID: 377DEBD6450BA986AC-515C
      6 Faults Found:
      16805 - Warm Up Catalyst; Bank 1
      P0421 - 001 - Efficiency Below Threshold - MIL ON -
      16684 - Random/Multiple Cylinder Misfire Detected
      P0300 - 001 -
      16690 - Cylinder 6
      P0306 - 001 - Misfire Detected
      16689 - Cylinder 5
      P0305 - 001 - Misfire Detected
      17831 - Secondary Air Injection System; Bank 1
      P1423 - 002 - Insufficient Flow
      16688 - Cylinder 4
      P0304 - 001 - Misfire Detected
      Readiness: 0000 1000
      Address 02: Auto Trans Labels: 01V-927-156.lbl
      Part No: 4B0 927 156 FF
      Component: AG5 01V 3.0l5V USA 0910
      Coding: 0001002
      VCID: 70EF10CA60E53EBEAD-515C
      No fault code found.
      Address 03: ABS Brakes Labels: 4B0-614-517.lbl
      Part No: 4B0 614 517 R
      Component: ABS/ESP allrad 2330
      Coding: 06497
      Shop #: WSC 01234
      VCID: 306FD0CAF0657EBEED-5122
      Address 08: Auto HVAC Labels: 4B0-820-043-MY2.lbl
      Part No: 4B0 820 043 AM
      Component: A6-Klimavollautomat 0105
      Coding: 00110
      Shop #: WSC 02325
      VCID: 65C1719EFF27EB16CE-257E
      4 Faults Found:
      01810 - Actuating Motor for Temperature Flap; Right (V159)
      41-10 - Blocked or No Voltage - Intermittent
      00819 - High Pressure Sensor (G65)
      07-10 - Signal too Low - Intermittent
      01592 - Air Quality Sensor (G238)
      57-00 - Electric Circuit Failure
      01317 - Control Module in Instrument Cluster (J285)
      49-10 - No Communications - Intermittent
      Address 15: Airbags Labels: 4B0-959-655-AI84.lbl
      Part No: 4B0 959 655 Q
      Component: Airbag 8.4EP 2001
      Coding: 0000607
      VCID: 3E73FEF26A3198CE6F-5140
      Address 16: Steering wheel Labels: 4B0-907-487.lbl
      Part No: 4B0 907 487 F
      Component: Lenkradelektronik D01
      Coding: 01002
      Shop #: WSC 02325
      VCID: 2F6DD3B6ED5B6146F4-5140
      Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
      Part No: 4B0 920 983 EX
      Component: KOMBI+WEGFAHRS. VDO D17
      Coding: 02262
      Shop #: WSC 08701
      VCID: 020B4A020E493C2E4B-5140
      WAULT64B73N054211 AUZ7Z0B2251642
      Address 35: Centr. Locks Labels: 4B0-962-258.lbl
      Part No: 4B0 962 258 M
      Component: Central Lock/Alarm D37
      Coding: 15885
      Shop #: WSC 02325
      VCID: 3365DFC6017345A690-4F02
      4 Faults Found:
      01371 - Alarm triggered by Door Contact Switch; Driver's Side
      35-00 - -
      01369 - Alarm triggered by Hood Switch
      35-00 - -
      01561 - Rear left door
      59-10 - Can't Unlock - Intermittent
      01562 - Rear right door
      59-00 - Can't Unlock
      Address 36: Seat Mem. Drvr Labels: None
      Part No: 4B0 959 760 B
      Component: Sitzmemory R1 F 0102
      Coding: 00001
      Shop #: WSC 00000
      VCID: 2C57C4BADC4D1A5ED1-4AFE
      Address 55: Headlight Range Labels: 4Z7-907-357.lbl
      Part No: 4Z7 907 357
      Component: dynamische LWR D09
      Coding: 00050
      Shop #: WSC 02325
      VCID: 04074C1A145D321E79-4B16
      Address 56: Radio Labels: 8E0-035-1xx-56.lbl
      Part No: 4B0 035 195 L
      Component: symphony II NP2 0051
      Coding: 00205
      Shop #: WSC 40201
      VCID: 29593DAED3BF0F762A-4EB0
      End-------------------------(Elapsed Time: 05:15)--------------------------
      2015 GLI SEL
      35% Tint || DG Springs || Koni Yellows || APR Stage 1 || APR Carbonio || Unitronic Catback || Valentine One
    3. Member malibuboats91's Avatar
      Dec 2nd, 2008
      1,015
      2016 Audi S3
      11-13-2015 04:35 PM #2
      Bump
      2015 GLI SEL
    4. Member malibuboats91's Avatar
      Dec 2nd, 2008
      1,015
      2016 Audi S3
      11-14-2015 11:33 AM #3
      Bump
      2015 GLI SEL
    6. Member malibuboats91's Avatar
      Dec 2nd, 2008
      1,015
      2016 Audi S3
      11-14-2015 02:38 PM #4
      I scanned it again today and pulled this.
      VCDS Version: Release 15.7.1 (x64) Running on Windows 10 x64
      www.Ross-Tech.com
      Saturday,14,November,2015,13:37:53:17965
      75 76 77
      Coding: 0016752
      VCID: 377DEBD6450BA986AC-5140
      1 Fault Found:
      P1423 - 002 - Insufficient Flow - MIL ON
      Readiness: 0000 0101
      Coding: 0001002
      Coding: 06497
      Shop #: WSC 01234
      Coding: 00110
      Shop #: WSC 02325
      VCID: 65C1719EFF27EB16CE-2578
      2 Faults Found:
      Coding: 0000607
      VCID: 3E73FEF26A3198CE6F-515C
      Coding: 01002
      Shop #: WSC 02325
      VCID: 2F6DD3B6ED5B6146F4-5122
      Coding: 02262
      Shop #: WSC 08701
      VCID: 020B4A020E493C2E4B-515C
      Coding: 15885
      Shop #: WSC 02325
      VCID: 3365DFC6017345A690-4F1E
      1 Fault Found:
      Coding: 00001
      Shop #: WSC 00000
      Coding: 00050
      Shop #: WSC 02325
      VCID: 04074C1A145D321E79-4AFE
      Coding: 00205
      Shop #: WSC 40201
      VCID: 29593DAED3BF0F762A-4E94
      End-------------------------(Elapsed Time: 05:09)--------------------------
      2015 GLI SEL
