Fourtitude.com - 02M Pedal to the floor...issue
    Results 1 to 12 of 12
    1. 07-15-2015 03:50 PM #1
      Ive read alot about this issue seems like nobody has a fix for it. Ive added the slave spacer, I went to add the spacer to the input shaft but my input shaft wasnt worn enough to fit the spacer on the tranny.
      Pedal stinks only when its at full throttle, then i would have to manually pull it up.
      Any other things to look at? has anybody sourced the problem?
      setup is 3.6 engine using an 16lb flywheel, R32 pressure plare, 6 puck disc.
      Thanks for any answers.
      Racing Improves the breed..
      "I have fought the good fight, I have finished the race, I have kept the faith"- 2 Timothy 4:7
      CrossroadsLI
      MY ALL MOTOR BUILD THREAD
    3. Angry Administrator nater's Avatar
      Apr 10th, 2000
      87,612
      2018 Atlas 4MO, 2008 3.6L Passat 4Mo, 98 O2M 3.0L VRT, '04 .:R32, 2014 CC R-line
      07-16-2015 09:32 PM #2
      Air? I had to bleed mine a lot after my swap.
    4. Member aka_deno's Avatar
      Mar 29th, 2005
      MD
      3,537
      '00 GTi VR6; '04 R32, '15 Passat TDI 6MT
      07-20-2015 04:09 PM #3
      Did you happen to see if your input shaft had any play to it? check out my post in this thread i just made: https://forums.vwvortex.com/showthrea...1#post88022936
      I thought my slave cylinder failed; but my clutch disk actually snapped into 2-pieces. Not sure if you have the same issue; just figured i would offer an update to my current 02M issues.
    6. 07-20-2015 04:11 PM #4
      Quote Originally Posted by aka_deno View Post
      i checked my input shaft back in the winter. bought the shim but my tranny wasnt worn enough to fit the shim. A buddy of mine actually told me he had thd same issue in his turbo vr and it was the pressure plate. I will order an clutch masters soo
      Sent from my LG-H810 using Tapatalk
      CrossroadsLI
    7. Member MtnDewBro's Avatar
      Jul 18th, 2011
      Wantagh, NY
      452
      B6 S4, MK4 golf 2.0, mk4 jetta vr6
      08-17-2015 02:05 AM #5
      Im having the same issue with my s4. I also have a bit of a rattle sound when the clutch pedal isnt depressed. Think it could be the same thing deno?
      Sent from my HTC One_M8 using Tapatalk
      My sh!t's always broken.
    8. Member MtnDewBro's Avatar
      Jul 18th, 2011
      Wantagh, NY
      452
      08-17-2015 02:07 AM #6
      Oh **** nevermind. Holy **** that clutch got #rekt
    9. 08-17-2015 06:33 AM #7
      im in the process of changing the clutch i will report back once i get everything back up and running.
      CrossroadsLI
    10. 01-07-2016 04:39 PM #8
      i added the 02m accumulator, problem still happens. Im in the process or changing my slave (throwout bearing went bad) and I will do the clutch master cylinder and master cylinder as well. Hope I find a problem with the either masters
      CrossroadsLI
    11. Angry Administrator nater's Avatar
      Apr 10th, 2000
      87,612
      01-07-2016 06:26 PM #9
      Quote Originally Posted by fourthchirpin View Post
      OMG this is still going on?
      Definitely report back how this is resolved. Sorry to hear you are having these problems.
    12. 01-08-2016 07:04 PM #10
      Quote Originally Posted by nater View Post
      I will. PM sent
      CrossroadsLI
    13. 12-22-2017 07:46 PM #11
      problem solved! transmission was coming off the block at full throttle. locktite all transmission bolts to the block and problem solved.
      CrossroadsLI
    14. Member Mr.loops's Avatar
      May 27th, 2010
      Kelowna, B.C.
      1,850
      1997 Jetta GLS, 1991 Jetta 1.8L, 92 1.8L Golf
      12-23-2017 11:54 AM #12
      Wow!
      Congrats on finding the solution
