Fourtitude.com - Reliable Transportation: 2005 Audi A6
    Page 1 of 3 123 LastLast
    Results 1 to 25 of 69
    1. Member corrado-correr's Avatar
      Jul 8th, 2004
      Detroit
      5,913
      07-13-2015 09:40 AM #1
      Hello and welcome to chapter 2 of adventures in reliable transportation (see chapter 1 here). In this instalment I give you this fine example of a fully depreciated luxury sedan, this full size, this four door, this Audi A6.
      Specs:
      2005 Audi A6 3.2L FSI Quattro
      Oyster Grey Metalic
      Sport package
      Cold weather package
      Premium sound
      Bi -xenon with AFS
      113k miles
      Check engine light: on.
      First order of business was the headlights, these had some of the worst fogging I've ever seen.
      IMG_20150713_091602 by Raven, on Flickr
      It took about an hour per light, started with 800grit, then 1k, then 2k, then a plastic polish, and finished with a bit of wax.
      IMG_20150711_172420035_HDR by Raven, on Flickr
      It's not perfect but its a huge improvement and should get me by until I have a chance to shoot them with some clear coat.
      IMG_20150712_202011492 by Raven, on Flickr
      I'll update this thread as I fix the things that that have gone wrong with it (and what ever else self destructs along the way).
    3. Senior Member chucchinchilla's Avatar
      Dec 25th, 2004
      Los Gatos, CA
      20,505
      2016 A6, 2014 X3, 1967 Bus, 1963 356
      07-13-2015 09:46 AM #2
      How much did you pay? These kinds of threads are best supplemented with numbers so we can all go "wow, he has total comfort and luxury for the price of a TV!"
      This forum is more and more of an embarrassment every day...
    4. Member corrado-correr's Avatar
      Jul 8th, 2004
      Detroit
      5,913
      07-13-2015 09:47 AM #3
      Quote Originally Posted by chucchinchilla View Post
      $4,800.
    5. Member fR3ZNO's Avatar
      May 4th, 2014
      CNY
      1,144
      B6 A4 Avant
      07-13-2015 09:51 AM #4
      Have you scanned the car for codes yet?
    6. Banned
      Sep 21st, 1999
      South Alabama
      13,063
      99 Passat 1.8Tm, 04 Passat 1.8Tm
      07-13-2015 09:53 AM #5
      Quote Originally Posted by corrado-correr View Post
      3.2L V6
      113k miles
      I'm gonna go out on a limb and assume this engine has timing chains and chain guide pads instead of a belt and tensioner(?).
      Mar 13th, 2013
      Clifton/Mountainside, NJ
      1,238
      07-13-2015 09:54 AM #6
      $4,800.
      Good buy.
    8. Member Smigelski's Avatar
      Dec 9th, 2008
      Annapolis, MD
      8,170
      '19 Ridgeline, '19 Miata
      07-13-2015 09:56 AM #7
      Quote Originally Posted by fR3ZNO View Post
      This would have been my first order of business.
    9. Member corrado-correr's Avatar
      Jul 8th, 2004
      Detroit
      5,913
      07-13-2015 09:56 AM #8
      what are my options for removing the front license plate mount?
      RS6 style?
      http://www.ecstuning.com/Audi-C6_A6-...lle/ES2717903/
      I think maybe this simple plate filler piece would be nice and classy.
      http://www.ecstuning.com/Audi-C6_A6-...ille/ES251316/
    10. Member corrado-correr's Avatar
      Jul 8th, 2004
      Detroit
      5,913
      07-13-2015 10:01 AM #9
      Codes? yes, it has them.
      Address 01: Engine (AUK) Labels: 06E-910-559-BKH.lbl
      Part No SW: 4F2 910 559 B HW: 4F1 907 559 A
      Component: 3.2l V6 FSI 0030
      Revision: --H15--- Serial number:
      Coding: 0000000000000000
      Shop #: WSC 02116 444 64487
      VCID: 2B5E81428AED4379EBD-807E
      2 Faults Found:
      012410 - Air Intake System
      P307A - 009 - Flow too Low
      Freeze Frame:
      Fault Status: 01100100
      Fault Priority: 2
      Fault Frequency: 254
      Reset counter: 40
      Mileage: 163288 km
      Time Indication: 0
      Date: 2014.01.17
      Time: 14:51:07
      Freeze Frame:
      RPM: 704 /min
      Mass Air / Rev.: 185.3 mg/str
      Temperature: 66.0°C
      Idle
      Voltage: 13.46 V
      Speed: 8.0 km/h
      000104 - MAP/MAF <-> Throttle Position Correlation
      P0068 - 007 - - MIL ON
      Freeze Frame:
      Fault Status: 11100010
      Fault Priority: 5
      Reset counter: 40
      Mileage: 163288 km
      Time Indication: 0
      Date: 2014.01.17
      Time: 14:51:07
      Freeze Frame:
      RPM: 704 /min
      Temperature: 66.0°C
      Idle
      Voltage: 13.36 V
      Bin. Bits: 00000010
      Readiness: 0000 0000
    11. Senior Member chucchinchilla's Avatar
      Dec 25th, 2004
      Los Gatos, CA
      20,505
      07-13-2015 10:06 AM #10
      Not a bad price. As for the plate filler, go with the simple one. Once you start doing RS grilles it's a slippery slope on performance looking mods on a non-performance oriented car and that's when it goes from classic to clapped out.
    12. 07-13-2015 12:18 PM #11
      Didnt know these could be had for that cheap theyre resale was much better than c5s a few years back
      Jun 16th, 2009
      NW 'burbs of Chicago
      3,248
      '15 FiST, '13 Quest
      07-13-2015 01:56 PM #12
      the engine alone almost makes it worth it.
    14. Moderator Harv's Avatar
      Oct 31st, 2004
      PA
      19,443
      W116 - W123 - AMG - Land Rovers
      07-13-2015 02:41 PM #13
      Don't these have transmission issues? Issues meaning they die.
    15. Member
      Jun 16th, 2009
      3,248
      '15 FiST, '13 Quest
      07-13-2015 02:48 PM #14
      The tiptronics get sticky servo valves in the valve body, and the Torque Converter seals leak. You can keep it in manual mode to mask some of the issue.
      Technically the gearboxes are fine. You can replace the valves alone, but it's difficult to figure out which one you need. And the TC fix is pricey. Will make you strongly consider a manuel swap.
    16. Member Shmi's Avatar
      Mar 25th, 2009
      Why is it so hot here, AZ.
      8,371
      2012 A6 3.0T, 2013 BMW 128i
      07-13-2015 02:51 PM #15
      http://wiki.ross-tech.com/wiki/index.php/P307A/012410
      good luck.
    17. Member rconn14's Avatar
      Sep 6th, 2006
      hoboken no jokin
      5,757
      2004 R32, 2012 Abarth
      07-13-2015 03:50 PM #16
      in
      Instagram: @clink_clank_clunk
    18. Member BeBop!'s Avatar
      Jun 18th, 2009
      SoCal
      2,397
      07-13-2015 05:34 PM #17
      Reliable?
    19. Member Uber Wagon's Avatar
      Dec 8th, 2003
      Pickup Truck Capital of US
      15,463
      Audi S3, BMW X3, and a Toyota Appiiance
      07-13-2015 05:37 PM #18
      Quote Originally Posted by BeBop! View Post
      Reliable?
      Here we go again.
      Beer: The cause of, and solution to, all of life's problems.
    20. Member Sir UNBANNED_GERBIL M.B.'s Avatar
      Jan 15th, 2003
      Orangeville
      15,231
      His+Hers= Bose, THXII, 12 cylinders, 48v, 7.5L, 4 turbos, 795hp, torque vectoring, torsen, 28spks
      07-13-2015 07:58 PM #19
      The 3.2 is a pretty damn stout engine. I had it in my A4. And over the 5 years of ownership the power train never let me down.
    21. ***** (Cat) Lover Pizza Cat!!!!'s Avatar
      Dec 2nd, 2006
      Near McBanagon
      21,138
      1) allmistake 2) V8 rental 3) merican vw
      07-13-2015 08:01 PM #20
      As long as you don't mind cleaning this, it could be a pretty decent buy.
    22. Member corrado-correr's Avatar
      Jul 8th, 2004
      Detroit
      5,913
      07-20-2015 10:11 AM #21
      TLDR: I cleaned a thing, mended something, and the check engine light is now off.
      First the front US plate panel delete with the grey plate filler.
      IMG_20150717_173519607 by Raven, on Flickr
      Simple to remove this piece - just two screws at the bottom.
      IMG_20150717_173825132_HDR by Raven, on Flickr
      The new plate filler panel
      IMG_20150717_174033581 by Raven, on Flickr
      IMG_20150717_174048580 by Raven, on Flickr
      The floor mats were in bad shape, and rather than trying to clean them up I ordered some gey weathertech rubber mats (front and rear).
      IMG_20150717_175012254 by Raven, on Flickr
      IMG_20150717_175326973 by Raven, on Flickr
      The cover of the hazard light switch had fallen victim to a shop vac by the hands of the previous owner. So I ordered a new switch.
      IMG_20150717_175707745_HDR by Raven, on Flickr
      IMG_20150717_175813625 by Raven, on Flickr
      Sunday morning I addressed the check engine light. P0307A and P0068 together were suposed to indate a dirty throttle body that needed to be cleaned and then forced an adaptation. So I did exactly that.
      The throttle body with notable carbon build up.
      IMG_20150719_113625765_HDR by Raven, on Flickr
      IMG_20150719_114403581_HDR by Raven, on Flickr
      Removed and cleaned the throttle body with carb cleaner and a microfiber cloth.
      IMG_20150720_093610 by Raven, on Flickr
      IMG_20150720_093549 by Raven, on Flickr
      Then I spent a good amount of time cleaning the engine bay (form the looks of it it had never been cleaned in all of its 114k miles. I also did a little more headlight polishing.
      IMG_20150719_132245868 by Raven, on Flickr
      IMG_20150719_175900593_HDR by Raven, on Flickr
      De-badged the rear.
      IMG_20150719_175930825_HDR by Raven, on Flickr
      IMG_20150719_203927505_HDR by Raven, on Flickr
    23. Member fR3ZNO's Avatar
      May 4th, 2014
      CNY
      1,144
      B6 A4 Avant
      07-20-2015 10:13 AM #22
      Looks like you also debadged the engine cover.
    24. Member Sir UNBANNED_GERBIL M.B.'s Avatar
      Jan 15th, 2003
      Orangeville
      15,231
      07-20-2015 10:14 AM #23
      Nice car and good work cleaning it up. As i've said I am a big fan of the 3.2. It's a very smooth engine. I hope the car serves you well.
      Funny you should say that. The exact same thing happened to my S8
    25. Member 2.0smurf's Avatar
      Sep 7th, 2006
      NJ
      2,754
      07-20-2015 10:20 AM #24
      Love the car, my Dad's got an 07 sport (I believe) with the 3.2 in it. He's got over 210k on the car and it still drives smooth, he babies the car and loves it.
    26. Member dieselraver's Avatar
      Nov 11th, 2007
      The City That Never Sleeps
      13,383
      07-20-2015 10:22 AM #25
      love a good thread. in for this
      Current Cars: 2018 BMW///M3 6 Speed Manual Yas Marina Blue over Sakhir Orange Leather | 2017 Volvo S90 Inscription T6 AWD | 2004 Infiniti FX35
      Previous Cars: 2016 GLI DSG SEL | 2015 Touareg Lux TDI | 2014 GLI 6 Speed Manual Autobahn | 2012 Odyssey EX-L | 2010 Outback 6 Speed Manual | 2008 VW GTI 6 Speed Manual | 2008 BMW 328xi 6 Speed Manual | 2007 VW Rabbit 5 Speed Manual | 2001 Honda Accord
