Presenting the AWE Exhaust Suite for the Audi 8V S3. Available now.
Perfect quality, fitment, performance, tone, and options to go around. Presenting the AWE Exhaust Suite for the 8V S3:
SwitchPath™ Exhaust
Smooth bends, tight packaging, and two attitudes. The SwitchPath™ Exhaust is comprised of handcrafted 3-inch and 2.5-inch U.S.-sourced T304L stainless steel with a valved passenger-side tip outlet.
SwitchPath™ retains the factory valve behavior, and obeys the S3’s ECU commands based on throttle input, engine speed, and Drive Select. Sneaking out in the morning or creeping through town? Close the valve. Ready to rip? Toggle into Dynamic and your S3 will sing a signature AWE tune with enhanced crackles that will provoke a firm grin.
Track Edition Exhaust
For those who like it raw, rowdy, and light, the AWE Track Edition is for you. The Track Edition takes all of the precision engineering and performance of its SwitchPath™ counterpart, minus the valve on the passenger’s side and the muffler on the driver’s side. The result is a constant “valve open” mode.
Note: This version is known to get (really) rowdy, and may be too much for many. For that reason, this particular version cannot be returned due to sound preference. You’ve been warned.
https://www.awe-tuning.com/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/_/n/_npgp9fa.png[/IMG[/URL]]
[U]Conversion Kits:[/U]
We made it easy to convert between SwitchPath™ and Track Edition if you decide at a later date to change your volume. Easy.
[U]Tip Options:[/U]
AWE SwitchPath™ and Track Edition come standard with 102mm double-walled, slash-cut tips in your choice of chrome silver or diamond black, complete with stamped AWE logo.
[URL="https://bit.ly/2XvCyzY"][IMG]https://www.awe-tuning.com/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/0/2/02vpruww.png
What’s in the box?
Complete SwitchPath™ or Track Edition Exhaust, four 102mm double-walled, slash-cut tips in desired finish, and all necessary hardware for installation.
Performance Downpipes:
To further hone the tone and performance of your S3, we’re offering both resonated and non-resonated downpipes. Both versions feature our No Check Engine Light Guarantee, Fitment Guarantee, a unique internally-lined stainless flex-pipe section to isolate engine movement and offer our Lifetime Warranty on the downpipe (one year on the catalyst core).
Resonated Downpipe: Slightly louder than the stock S3 downpipe. Featuring our No CEL Guarantee (even without software) and a sophisticated and distinguished tone.
Non-Resonated Downpipe: Removes the resonator for a more aggressive note, much louder than the stock downpipe. Featuring our No CEL Guarantee (even without software) and a pronounced note.
What’s in the box?
Complete Performance Downpipe, 3” downpipe adapter. and all necessary hardware for installation.
About the AWE SwitchPath™ Remote:
Push-button mood control.
The AWE SwitchPath™ Remote and accompanying control box overrides the factory valving to allow the exhaust valves, whether it be on the AWE SwitchPath™ Exhaust or the stock exhaust, to be opened or closed manually via the SwitchPath™ Remote.
How to operate:
With the AWE SwitchPath™ Controller installed, the exhaust valves can be opened by pressing the “On” button found on the left side of the SwitchPath™ Remote. To close the exhaust valves simply press the “Off” button on the right side of the remote.
Please note, the AWE SwitchPath™ Remote overrides the stock valve control, meaning the exhaust must be opened and closed with the remote as desired.
Data:
- Proudly designed, engineered, and manufactured in-house at AWE
- Max gains of 12 hp and 9 ft-lbs of torque at the wheels (turbo-back, stock software)
- Available as valved SwitchPath™ or more unleashed Track Edition
- Handcrafted from CNC mandrel-bent 3” and 2.5” U.S.-sourced .065” wall T304L stainless steel
- Direct bolt-on for factory-like simplicity
- Less is more: clean, straight-through design maximizes performance
- Performance Downpipes are available as resonated or non-resonated
- 200 CPSI EURO6-compliant HJS catalyst
- 102mm double-walled, slash-cut tips available in chrome silver or diamond black
- Perfect fitment, guaranteed
- Features the AWE No CEL Guarantee
- Lifetime warranty
- SwitchPath™ exhausts are available with the AWE SwitchPath™ Remote for push-button mood control (Sold Separately)
SwitchPath™ Exhaust
[U]Tip Options:[/U]
What’s in the box?
What’s in the box?
- Open and close exhaust valves with the push of a button from inside the cabin at any time
- Works with stock system, or AWE SwitchPath™ Exhaust
- Comes as a set of two remotes with wiring harness, control box and mounting hardware
- Compact design perfect for a keychain or cup holder
- From quiet to aggressive with the tap of a button
- No Check Engine Light - Guaranteed
How to operate:
Data:
