Fourtitude.com - Tires 245 255 series on A3/S3
    Page 2 of 2 FirstFirst 12
    Results 26 to 35 of 35
    1. Member RyanA3's Avatar
      May 11th, 2005
      Ardmore/Philly
      5,486
      2015 Audi S3, 2018 VW Atlas SEL Premium
      04-17-2015 05:44 PM #26
      keep us posted, ^ post a pic once mounted.
      good luck
    3. 04-17-2015 05:56 PM #27
      Ok thanks will do, your car looks awesome btw
    4. 03-30-2017 09:13 PM #28
      What do people think I should go with in terms of tyre size - stock height Audi S3 8V Sedan.
      I am fitting these rims to my S3 sedan (pictured below). They are 19x8.5 +43.
      I am tossing up between 245/35/19 or 255/35/19 in tyre size. I gather the 255 will fit ok in this sizing?
      What would you go for? Any help appreciated. I like the idea that I will have a slightly higher sidewall with the 255 so the ride might be a tad bit more compliant and softer.
    6. Member RyanA3's Avatar
      May 11th, 2005
      Ardmore/Philly
      5,486
      04-01-2017 07:46 AM #29
      Quote Originally Posted by rogerpro View Post
      245 35 19 is perfect
      do not go with 255
    7. 05-05-2017 11:44 AM #30
      Thanks for the info on this thread, I ordered 245/35/19 Michelin Pilot Sport 4S tires for my 2015 S3 with Magnetic Ride and ECS Tuning flush spacer kit. I'll post pictures of how they fit after they get installed tomorrow.
      Tires are the best mod, I can't wait to be off these Continentals
      Nov 12th, 2016
      Denmark
      178
      2012 Audi A3 1,6 TDI SB
      03-07-2019 04:39 AM #31
      Does anyone have a picture or any information on fitting 245/35/19 tyres on a Sportback, preferably on the OEM 8x19 or aftermarket 8.5x19 rims? I know that sportbacks are narrower than the sedans and can't take as wide wheels as the sedans can and I was unable to find any pictures on this setup online so far.
      2012 Audi A3 1.6 TDI, Stage 1, Dakota Grey Metallic, Eibach Pro (front) & MSS Streets Kit (rear) with Bilstein B4
    9. Member RyanA3's Avatar
      May 11th, 2005
      Ardmore/Philly
      5,486
      03-16-2019 05:00 PM #32
      Quote Originally Posted by dp_motley View Post
      Only Sedans here in USA
      19x8.5 +47 down to 40 is epic. Closer to 40 the better.
      245/35 wants 19x8.5”
      This combo is perfect on this platform!!!
    10. Member brew1's Avatar
      Apr 6th, 2004
      Richfield WI
      228
      16 A3 8V Quattro Sedan S-Line (Black), 15 A3 8V Quattro Sedan (Silver)
      04-18-2019 08:33 PM #33
      2016 A3 sedan here. For those running 19x8.5 wheels with 245/35 rubber with unmodified suspensions, are wheel spacers needed?
      Thanks!
    11. Member brew1's Avatar
      Apr 6th, 2004
      Richfield WI
      228
      04-19-2019 01:11 AM #34
      Forgot to mention that i currently run 19 x 9 Acari Racing wheels with 225x35 rubber. Looking to add some sidewall but would prefer not to use spacers.
    12. 04-19-2019 08:28 AM #35
      Quote Originally Posted by brew1 View Post
      Is the offset of the wheels the same? You should have plenty of room. Use an online calculator:
      https://www.willtheyfit.com/index.ph...h=9&offset2=30
      (I run the RS3 stagger on 9" wide wheels 255 up front 235 in the back. Lowered on 034 springs and front camber plates. plenty of room up front for 265 but price differential wasn't worth it.)
