Fourtitude.com - Tires 245 255 series on A3/S3
    Results 1 to 25 of 35
    1. Member RyanA3's Avatar
      May 11th, 2005
      Ardmore/Philly
      5,486
      2015 Audi S3, 2018 VW Atlas SEL Premium
      03-23-2015 10:35 AM #1
      This thread can be a place to discuss tire sizes.
      Post #9 below has a ton of answers!!
      I've got my TireRack cart loaded up with 8 tires, I only need 4
      Others, feel free to reply with feedback on my application AND with your own questions.
      Help, can't decide! 245 or 235 rubber?
      I have an S3 with:
      -> H&R Sport Springs
      -> 19 x 8.5 et 47 Wheels
      these wheels are currently wrapped with 225/35 and they are STRETCHED!
      -> No plans for spacers
      Stock Size:
      Since the stock 19x8 wheels are on 235/35, and I'm going up to a 19x8.5, I guess the 245 is perfect?
      for my aftermarket wheels, 19x8.5, both a 235 and 245 are ideal. Both suggest a 8.5 wheel width.
      Protection for the wheels:
      The wheels are expensive!
      Obviously, a 235/35 will be "better". Little more protection. Little more comfort.
      But how about a 245? Should be slightly wider, thus a slightly taller sidewall, I am thinking.
      Handling:
      More side wall usually = the handling suffers
      if you've moved up to a 245 or 255, since the sidewall is increased a bit, how was handling affected?
      Rubbing is Racing:
      I drive the car on spirited car club cruises on country roads, lots of dips.
      And at times, I have a couple photo clients in the back, with gear in the trunk.
      Say not to rubbing! Should I stick with 235?
      S-Tronic / Gearing:
      235 to 245 is a 1.07% differential. Not much but it's a difference.
      Can we change the tire size with vag-com?
      if we can update with vag-com, it would fix a speedo reading.
      Looking for any feedback from the masses. Be honest!
      And ask questions!
      NO PM. Just ask here! Don't be shy.
    3. Member A3_yuppie's Avatar
      Jun 5th, 2006
      Orange County, California
      1,435
      2006 A3 2.0T (traded in), 2009 A4 2.0T Quattro, 2015 A3 2.0T
      03-23-2015 04:10 PM #2
      Quote Originally Posted by RyanA3 View Post
      S-Tronic / Gearing:
      if we can update with vag-com, it would fix a speedo reading. I wouldn't expect it to have any affect on the transmission, so it's worth mentioning....
      the last time I moved up a tire size on an automatic, I was not happy.
      the car noticed the change in tire size and the shift results were sloppy.
      Yes, I have seen threads that mention adjusting tire size in the UK (with scant details). But supposedly this only addresses the TPMS (and maybe ABS) issue(s), not transmission or driving characteristics due to running a larger overall tire diameter.
    4. Member CbutterK's Avatar
      Feb 27th, 2015
      AZ
      143
      16 M3, 03 911 X51, 93 S13, 15 Tiguan R-Line, 08 Durango LTD Hemi
      03-23-2015 04:43 PM #3
      On my S3, I tried on 255/35/19 tires on 19x9.5 rims, 255/35/19 tires on 19x9 rims, 245/35/19 tires on 19x9 rims, and 245/35/19 tires on 19x8.5 rims. I have H&R Supersport springs. None of them have rubbed, as long as I used appropriate spacers to prevent rubbing against the shocks. I have not noticed any changes in the car's feel, other than different tires having more or less road noise, harder or softer, etc. Where I noticed the biggest difference is when I used wider spacer in the rear to push out the rear tires more than the fronts, the car had more understeer & less turn in response. While 255/35/19 still worked just fine, I feel that 245/35/19 is the best set up on a 19x8.5 rims. the outer lip of the tires will protect the rims, as the 245 tires will not be stretched on 8.5 rims.
    6. Member RyanA3's Avatar
      May 11th, 2005
      Ardmore/Philly
      5,486
      03-23-2015 07:01 PM #4
      Quote Originally Posted by CbutterK View Post
      this reply is so informative. and so perfect.
      thank you for posting!
      pics!?
      I ordered 245 series tires before lunch today. so you just made me feel a little better!
    7. Member 08CandyWhite's Avatar
      Jan 31st, 2003
      Westminster, CO
      7,768
      18' Tiguan SE 4Mo 00' TT 5MT
      03-23-2015 07:31 PM #5
      Reading this thread makes me very confident and happy.
      Planning on running a set of 19"x9" ET 52 with 255/35R19's on them.
      2018 Tiguan SE 4Motion - Pure White - Sunroof - 3rd Row
      2000 TT - Denim Blue - Denim Blue leather
    8. Member CbutterK's Avatar
      Feb 27th, 2015
      AZ
      143
      03-23-2015 08:12 PM #6
      pics!?
      You are welcome. I was fortunate to have several sets of rim/tire combos from my TT-RS. I wanted to find out what works & what doesn't, so I spent the weekend trying out different combos... Man did my back hurt! But it was worth it, cause now we know exactly what works! I'm new here and upload challenged at the moment. Once I figure out how to do it, I'll put up some pics of the different setups I tried. If you want to see them sooner, just pm me with your email addy & ill send it to you directly.
      You wont regret going with 245s I believe. Also, I believe VCDS has an option to pick larger size diameter tires to compensate for speedo difference. The stock 18 & 19 setup already has about .4" difference anyway.
    9. Member CbutterK's Avatar
      Feb 27th, 2015
      AZ
      143
      03-23-2015 08:23 PM #7
      Quote Originally Posted by 08CandyWhite View Post
      Yup. That's exactly the set up I tried too. It's the stock TT-RS rim/tire size. With this setup, you will need to run 3mm spacer for the front & 5mm spacer for the rear to clear the shocks on the inside. The rims still have a few mm clearance, but the lip of the tire where it meets the rim sticks out just enough to rub against the plastic cover of the shock in the rear. So, tire rubbing against the plastic once in a while during upstroke(when shock extends) is probably not going to bother anyone(unless friction causes fire, lol), but I decided to run the 5mm spacer in the rear to make sure it clears with some space. I did not try the front without spacer, since I already knew I didn't want the rear track to be much wider than the front(too much understeer).
    10. Member RyanA3's Avatar
      May 11th, 2005
      Ardmore/Philly
      5,486
      03-24-2015 12:44 AM #8
      Yup that's why I'm sticking with a square setup.
      Can't wait. THX for the info!
    11. Member RyanA3's Avatar
      May 11th, 2005
      Ardmore/Philly
      5,486
      03-24-2015 10:12 AM #9
      CbutterK
      You are a wealth of info!
      Here is text and images from CbutterK:
      On my S3, I tried on the following:
      H&R Supersport springs:
      then he texted me a ton of pics.
      UNBELIEVABLE job with all of the trial and error.
      lot's of time spent, I speak for everyone, THANK YOU THANK YOU THANK YOU!!
      info revised at 530pm 3/25 est
      image #1
      19x9et45
      245/35/19 -> which he said would be the ideal tire size for the car
      Nitto NT05
      3MM SPACER Front in pic
      5MM SPACER Rear in pic
      this setup did not require any spacers.
      spacers installed, just so I can see how much we can go without rubbing on the outside
      1 Tire and wheel info S3
      2 Tire and wheel info S3
      3 Tire and wheel info S3
      image #4 is:
      19x9.5 et53
      255/35/19
      yokahama ad08
      needed 12mm spacers to clear the shocks on the S3
      so he returned them to his ttrs.
      4 Tire and wheel info S3
      5 Tire and wheel info S3
      6 Tire and wheel info S3
      image 7 and 8:
      His stock TTRS rims/tires
      19x9 et52
      255/35/19 toyo
      needed a 3mm spacer in the front
      needed 5mm rear
      7 Tire and wheel info S3
      8 Tire and wheel info S3
      9 Tire and wheel info S3
      this is 245/35 19x8.5 et45:
      10 Tire and wheel info S3
      more pics below
      I ordered 245/35/19 to install on my 19x8.5 et47, no plans to use spacers.
      I will have them put on by the weekend.
      Stay tuned for pics and feedback.
    12. Member SKNKWRX's Avatar
      Sep 27th, 1999
      Denver, CO
      6,019
      2018 Oryx Golf R, 1991 E30 M3, 2013 Rising Blue Golf R, 1989 Toyota 4Runner
      03-24-2015 12:16 PM #10
      So TTS/TTRS wheels will bolt right up? I am about to give up on finding a used TTRS and trade my TTS on an S3 and I have a set of Forgestar F14s 19X9 et44 what I would like to run with 255/35 RE-11s. This setup would work it appears on the S3?
      NR/NR
    13. Member RyanA3's Avatar
      May 11th, 2005
      Ardmore/Philly
      5,486
      03-24-2015 02:13 PM #11
      Quote Originally Posted by SKNKWRX View Post
      I wouldn't rush to get an S3 if I were you.
      If you don't require four doors, why would you?
      if you love tossing the TTS around, you may miss it.
      anyhow, the hero shared his info on:
      19x9 et52
      255/35/19 toyo
      so you should be good.
    14. Member CbutterK's Avatar
      Feb 27th, 2015
      AZ
      143
      03-24-2015 03:45 PM #12
      Thanks Ryan"S"3 for posting pics on my behalf. You pretty much got everything perfect! Only correction, the black 19x9 +45 with 245/35/19 NItto NT05 tires did not require any spacers. I have 3mm front & 5mm rear spacers on in the pics, just so I can see how much we can go without rubbing on the outside. The stock TTRS wheels, 19x9 +52 with 255/35/19 tires on the other hand, DID require 3mm front & 5mm rear to clear the shock tubes on the inside.
      Thanks again Ryan!
    15. Member CbutterK's Avatar
      Feb 27th, 2015
      AZ
      143
      03-24-2015 03:49 PM #13
      Yup. Stock TTS/TTRS wheels will bolt up with 3mm front/5mm rear spacers to clear the shock tubes. Your F14 +44 will bolt right up without the need for any spacers, even with the 255 tires. even the hub bore is the same between the TTS/TTRS and the 8V chassis at 57.1mm!
    16. Member RyanA3's Avatar
      May 11th, 2005
      Ardmore/Philly
      5,486
      03-24-2015 05:29 PM #14
      Thanks again Ryan!
      thx Chad!
      I corrected the post, so it's accurate now.
      you da man!
      4 beers, make sure you don't drive.
    17. Member SKNKWRX's Avatar
      Sep 27th, 1999
      Denver, CO
      6,019
      03-24-2015 08:31 PM #15
      19x9 et52
      255/35/19 toyo
      I am really all over the map. I have just about given up on a TTRS and now another possible one comes across my radar. I took a long look at my TTS today and I just dont think I can do a sedan.
      NR/NR
    18. Member CbutterK's Avatar
      Feb 27th, 2015
      AZ
      143
      03-24-2015 09:04 PM #16
      I totally get it. I almost sold my TT-RS recently to get another car, but I just couldn't do it. It only has 3600 miles on it, with APR DP & Stage 2 tune, forge elbow bov, cts intake, H&R, etc. I'd lose too much money, and besides, there is nothing out there for same money that performs this well at the track & still feel high quality. Before my TT-RS, I also had a 2011 TTS, APR stage 2+ tune, APR HPFP, B&B DP, and again, for the money, nothing even came close IMHO. I kept the HPFP & B&B DP incase I pick up another one, lol...
      All that said, I love my S3!!!!! If I dont look back to see the back seats, I swear it feels as sporty as my TTS did! I really feel like the S3 is a great practical alternative to the TTS...
    19. Member RyanA3's Avatar
      May 11th, 2005
      Ardmore/Philly
      5,486
      03-25-2015 09:02 AM #17
      Chad, are any of images 19x8.5 245/35?
      Seems it may require an offset around 40 to look aggressive.
    20. Member SKNKWRX's Avatar
      Sep 27th, 1999
      Denver, CO
      6,019
      03-25-2015 11:31 AM #18
      Exactly what I am driving now, 2011 TTS APR stage 1 with Meisterschaft valved exhaust and an intake and TTRS wing grill and brakes. With 70k on the odo its time for something newer and the only thing appealing is the same car with more HP. I like the S3 but I know I will never LOVE it like I do this coupe. In talks to trade my TTS and my 2013 Golf R APR Stage 2+ on a 2013 low mile loaded SUzuka Grey TTRS. If this one doesnt work out I will probably give up and go S3.
      NR/NR
    21. Member CbutterK's Avatar
      Feb 27th, 2015
      AZ
      143
      03-25-2015 12:19 PM #19
      The pic of just the rims/tires are the 19x8.5 +45 with 245/35/19 tires. Unfortunately, I forgot to take pics with them on the car after the lowering. I have pic with those tims on the car at stock height, if that helps. BTW, it didnt look too set in without any spacers, but if you want the flush look, you can go anywhere up to 10mm spacers on your +47 rims without rubbing on the fenders. I'll text you stock height pic with those rims on.
    22. Junior Member
      Nov 12th, 2014
      Dallas, TX
      29
      2016 Audi S3 on Order
      03-25-2015 02:12 PM #20
      Pics please
    23. Member RyanA3's Avatar
      May 11th, 2005
      Ardmore/Philly
      5,486
      03-25-2015 03:35 PM #21
      Quote Originally Posted by Cesar2387 View Post
      Pics please
      I will post them asap, got them from chad.
      plus, my 19x8.5 are on my car now. so I'll get mine up too.
    24. Member RyanA3's Avatar
      May 11th, 2005
      Ardmore/Philly
      5,486
      03-25-2015 03:44 PM #22
      here is ^
      again, this is suv height
      Stock height S3. 245/35 on 19x8.5 et45
    25. Member RyanA3's Avatar
      May 11th, 2005
      Ardmore/Philly
      5,486
      03-26-2015 03:10 PM #23
      Oh it's a good day.
      It's a GREAT DAY!
      Wheels - HRE Flow Form 01 - optional fog finish 19x8.5 +47
      Tires - Conti Extreme DS (summers) 245/35
      225/35 Tires were removed from my HRE that I used on my Golf R.
      I ordered the new rubber from TR.
      The tires were installed and an alignment was done today, around 700-800 miles after the h&r sport springs went on.
      CK Auto Image
      https://www.facebook.com/maximizingyouride
      718 Washington Ave, Philadelphia, PA 19147
      (215) 627-2258
      A guy named Gabe is a tech there, he is a TTS owner and major Audi enthusiast.
      he's tight with all of the Audi Group of Philly guys on FB.
      ask for him. he has more patience than anyone on earth.
      he will do whatever it takes to get your alignment perfect.
      he will never scratch a wheel.
      and they have great equipment.
      245/35/19
      The car feels so much better now!
      Looks great too!
      More relaxed over bumps. More comfy, but still sporty. Nice and quiet.
      These tires are 3lbs lighter than Michelin PSS.
      Reducing unsprung weight great for many reasons.
      Better steering/braking/acceleration/mpg. You can feel 3lbs at each corner.
      A set of 4... the conti are $204 cheaper. That is a free tire.
      I had these tires on the Golf, they are FANTASTIC in the dry AND wet.
      They last longer than the PSS. Great performance, but even better value.
      245/35/19
      245/35/19
      245/35/19
      245/35/19
    26. Member RyanA3's Avatar
      May 11th, 2005
      Ardmore/Philly
      5,486
      03-29-2015 03:30 PM #24
    27. 04-17-2015 05:40 PM #25
      Since this thread is dedicated to tire size, I figured I would show an example of a 235/35/19 on a 19x8.5 wheel, for anyone who is on the fence for what tire size to go with.
      I'm still waiting on audi center caps to arrive before I mount them on my S3. but this shows an "off the car perspective", just a very minimal stretch.
      Cheers
