Fourtitude.com - 12 vrt hp numbers
    Results 1 to 11 of 11
    1. Member dubbin95's Avatar
      Mar 18th, 2007
      MA
      549
      95 vr jetta(sold) 95 jeep grand cherokee (sold) 82 custom Chevy p/u (sold) 97 CTD, 97 vrt
      08-03-2014 12:23 AM #1
      I have a 97 mk3 vrt with a ebay "gt35r" and I'm wondering what kind of numbers I can expect with 15lbs on stock compression? I have all other supporting mods,
      C2 42# software with 4" maf
      Homemade SRI Port matched
      2.5" kinetic DP
      FMIC
      Car pulls real strong, I am just curious what others have made with similar setups. Thank you in advance.
    3. Member dubbin95's Avatar
      Mar 18th, 2007
      MA
      549
      08-03-2014 10:38 PM #2
      Nobody has a vrt?
    4. Member VEE-DUBBER's Avatar
      Nov 22nd, 2000
      Renton, WA
      4,950
      2009 K04 Gti, 2015 Gti, 2012 Gli, 91 Turbo Miata, 96 Jetta VR6T, 95 GTI VR6
      08-24-2014 03:52 PM #3
      57 trim t04e .81 turbine housing
      UM 42lb file.
      My own mixture of parts
    6. Member dubbin95's Avatar
      Mar 18th, 2007
      MA
      549
      08-24-2014 11:55 PM #4
      ^ that was on 27lbs of boost?
    7. Member VEE-DUBBER's Avatar
      Nov 22nd, 2000
      Renton, WA
      4,950
      08-25-2014 12:02 AM #5
      25,27. My gauge read ~24.
      Put a 3" DP the night before the dyno.
      Turned down to 22 and felt no difference. No dyno @ that pressure, but could still break loose in 4th and 5th with 215/40/17 ecsta LE sports.
    8. Member dubbin95's Avatar
      Mar 18th, 2007
      MA
      549
      08-25-2014 10:56 PM #6
      That's badass. Did you ever run the car without spacer in it? If so what did you have boost at?
    9. Member VEE-DUBBER's Avatar
      Nov 22nd, 2000
      Renton, WA
      4,950
      08-26-2014 10:58 PM #7
      No. Always this big spacer. Im going to do 9.5:1 next time around.
    10. Member dubbin95's Avatar
      Mar 18th, 2007
      MA
      549
      08-30-2014 12:32 AM #8
      Are you not happy with the 8.5:1? That is what I have to put in. I got it for free off my buddy. So I figured why not?
    11. Member VEE-DUBBER's Avatar
      Nov 22nd, 2000
      Renton, WA
      4,950
      08-30-2014 12:34 AM #9
      No, it's fine. I just want to get a small amount of low end out of boost back. This is my every day driver, only vehicle.
    12. Member dubbin95's Avatar
      Mar 18th, 2007
      MA
      549
      08-31-2014 06:16 PM #10
      How gutless is it with the 8.5? Like d15 honda gutless? Haha
    13. Member VEE-DUBBER's Avatar
      Nov 22nd, 2000
      Renton, WA
      4,950
      08-31-2014 06:36 PM #11
      It's not gutless. It's perfectly fine. I drove the car with the spacer and 3" exhaust N/A for 6 months before boosting. It was ok, but just needed more pedal and used quite a bit more fuel as compared to my stock 95 gti.
