Fourtitude.com - 12v Mk3 VR6: Gunning for 12's
    Page 2 of 5 FirstFirst 12345 LastLast
    Results 26 to 50 of 112
      Aug 8th, 2004
      Rockaway,NJ
      7,905
      94 golf
      03-09-2015 06:26 AM #26
      Some have removed shift weight to help. Honestly I would switch to stock 02J stuff.
    3. 03-09-2015 06:57 AM #27
      The o2j's I've driven are as sloppy as the o2a. And i wasn't fond of the dieselgeek at all
    4. 03-09-2015 07:46 AM #28
      IE Cams for The 12v VR6? I have never heard of them. Could you post a link I'd be interested in learning about them.
    6. Junior Member
      Dec 26th, 2014
      SA,TX
      49
      2012 GLI
      03-09-2015 07:47 AM #29
      Have you replaced the side and rear windows with plexiglass? Eliminated passenger wiper?
    7. 03-09-2015 07:54 AM #30
      $850 US Dollars? Jesus that's a ton of money for a chip but I am sure the programming is not the easiest as well. It's very cool of Paul to set up a mega squirt for you. TT288's cams and a really well done P&P head would be a blast to drive I'd imagine. I saw that you have the 3.94 R&P that one mod changes the car day and night, I had one and it was awesome. Much luck to you on your build and getting into the 12's. Will be following it.
    8. 03-09-2015 09:04 AM #31
      Quote Originally Posted by monkihead View Post
      The rear doors have been done. Hatch will be done later on.
    9. Junior Member
      Dec 26th, 2014
      SA,TX
      49
      2012 GLI
      03-09-2015 10:23 AM #32
      Have you converted to maual brakes? I dont know if those had power brakes
    10. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      37,179
      15 Jetta 92 Corrado VR6
      03-09-2015 01:30 PM #33
      I think all vw from late mk1 had power brakes.
      IE's 200hp is from an engine dyno.
      -Paul
    11. Junior Member
      Dec 26th, 2014
      SA,TX
      49
      2012 GLI
      03-09-2015 01:49 PM #34
      I'd pull the booster, run manual brakes with an adjustable proportioning valve for the rear.
    12. 03-09-2015 07:23 PM #35
      Early vr's had oem prop valve? Was thinking I'd just go 2L mc, booster and lines. Don't have any ability or know anyone to make new brake lines for the front.
      Any idea on how much weight booster + abs saves?
    13. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      37,179
      03-09-2015 11:29 PM #36
      The ABS valve assembly that uses the separate booster is light, around 2lbs. Not worth removing alone. The booster is heavier, but I've never weighed it. Manual brakes are kind of, well, tough. I never got that far with the Mk3. That's starting to get into the "not worth its."
      -Paul
    14. Junior Member
      Dec 26th, 2014
      SA,TX
      49
      2012 GLI
      03-09-2015 11:36 PM #37
      Every bit counts. If you feel its not worth it, is getting an mk3 worth getting to go 12s all motor? To make new lines you need a double flaring tool. Some of our guys will remove the emergency brake just to get an edge.
    15. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      37,179
      03-10-2015 12:30 AM #38
      I have no way to respond to this that doesnt sound snippy. Maybe I will think of something better later tonight.
      -Paul
    16. Junior Member
      Dec 26th, 2014
      SA,TX
      49
      2012 GLI
      03-10-2015 09:33 AM #39
      Sorry if I seem rude. I run a performance store(mainly muscle cars) and have people looking to do everything to their car on a budget. Any goal is worth reaching if your willing to make thr expense. Ie- a customer walks in and tells me he wants 11s in a 1/4 from his car. The sloppy way is to build a motor with gobs of power and ignore the suspension. The better way is to make sure they are going to have the proper suspension for launch, which yields best times with low-med hp numbers.
    17. Member Pj1103's Avatar
      Jan 18th, 2010
      NH
      734
      2004 Audi A4 Quattro, 2001 Audi S4 Avant
      03-10-2015 01:18 PM #40
      I think what need is saying is that the hassle involved in taking out a functioning 2lbs aluminium block wouldnt be worth it. Considering he would have to make new brake lines and swap the booster iirc.
      When one could start removing easier to remove, less usefull parts, like the interior. (Been dun did already)
      Though i do agree everything counts.
    18. 03-10-2015 08:39 PM #41
      Funnily enough. The master cylinder is stuffed i think so i can't even make abs engage.
    19. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      37,179
      03-10-2015 11:11 PM #42
      No worries, I was avoiding exactly that myself. I agree that its all a system but some things dont need to be addressed. Like a 2lb chunk of alum that I was pissed to have it weigh so little once it was off.
      Also btdt with 12s in these cars, so hopefully my advice comes with some cred 12.833 at 2450lbs
      -Paul
    20. 03-11-2015 09:16 PM #43
      Does anyone know if the stock trans mount can be taken apart or the rubber cut out and replaced with metal? To get a bfi stage 2 kit here is nearly $400.
    21. Member Pj1103's Avatar
      Jan 18th, 2010
      NH
      734
      03-12-2015 12:43 AM #44
      Ive taken apart one from a 2.0. From what i remember its a huge pita. There is a lot of grease on the inside haha. Im sure it could be done, youd probly have to fab up some metal
    22. 03-12-2015 12:47 AM #45
      I have the 0.5 kit in at the moment so it isn't the liquid filled.
      Was thinking if its similar to front/rear mount could just cut a notch and slip a 'U' shaped piece around the post.
    23. Member Pj1103's Avatar
      Jan 18th, 2010
      NH
      734
      03-12-2015 01:06 AM #46
      That should be a g60 mount then iirc. Im sure it could be done.
    24. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      37,179
      03-12-2015 06:54 AM #47
      The g60 mount is solid rubber. Once you start cutting you'd just be left with two flanges. Probably better off just making those pieces like the delrin mounts are made.
      -Paul
    25. Member Pj1103's Avatar
      Jan 18th, 2010
      NH
      734
      03-12-2015 10:26 PM #48
      Yeah this is true. Why do you need to modify it? Its a pretty solid mount for most applications.
      I feel that mount would flex just the right amount.
      If you wanna go crazy, and possibly lighter than stock, check out a mk4 mount swap in the white gti 20v na build. I feel that would hold up well.
    26. 03-12-2015 10:47 PM #49
      I have a solid metal front mount and the rear 0.5. Engine moves alot when rolling of the clutch with no accelerator. Can't imagine clutch chatter could be so violent like this is.
      Car is not a daily driver and is only purpose is to do a 12. Why not i say
      Price for dss axles
      Think I'll stick to breaking oem ones lol.
    27. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      37,179
      03-13-2015 03:28 PM #50
      That gets old but it is a lot cheaper! Real oe ones hold much better than the rebuilt ones.
      -Paul
