Before I try to find some shop locally, I figured I would check on here.
I have an aluminum intake manifold for my R32 which has a removable plenum cover. I would like to have a few spacers made to go underneath this cover to raise it up.
I am going to dyno it normally, than put on a spacer/gasket/longer bolts and redyno.
If it makes any gain, I am going to add another spacer and repeat.
If more gains, then another spacer and repeat.
I'm not too concerned with what the spacers are made from. Could be aluminum, could be some sort of high temp plastic.
That could work. It would probably be better if you used something that would transfer straight through like paper even. It will be easier taking measurements off a line on paper rather than corrugated cardboard.
Id just order a gasket for whoever is doing the job tbh, it will save you a load of time, and they can map it directly on the mill table, or measure by hand with the reassurance it will be spot on. Id let them drill the holes - they may need to use 6/8 holes for fixing the part down to a base for milling anyway(if you cant get jet cut)
Brian,
a 50mm spacer will be mega bucks if they dont have a use for the cutout bit rightaway.
There is no gasket to be ordered. This is the only manifold of it's type in existence. It was a factory prototype for testing purposes before VW ever produced the plastic manifolds that came on the R32.
Regarding the bits- I'm no machinist, but couldn't the depth be cut in many stages?
Sorry, didnt spot that - thought they were all like that under a cover(or something)
If you take a 50mm spacer from a 50mm thick piece of billet then the bit you take out of the middle will be 'waste' if that shop has no direct use for the inside bit,
What Brian said. That material for the 2in and 3in spacers will be quite expensive and wasteful. Probably the best thing to do would be to cut multiple 0.5in pieces and stack them. It also might be cheaper to just make them out of "plastic" if its just for testing, the material would be cheaper and faster to cut. Just a thought.
Also beware with some polys even the glass filled ones that creep can be a major issue - that is the plastic deforming under the clamping pressure of the bolts over time and the bolts then getting loose. All coolant flanges I am aware of have a steel ferrules pressed in to take the clamp loads from bolts.
I think your best best is water jet from 12mm - Id get them to jet holes too, as boring that many holes in all the right place is not an easy task.
As for a template, get a sheet of paper and tape to intake - go over the edges and holes with a dirty finger(think after changing a wheel) and it will highlight all the points of importance for you.
I did check prices and Flame-Retardant Polypropylene is $100 cheaper for a 2' square at 1/2" than an alum plate (same size) and will hold up to 200deg F. But it was just a suggestion. I have never tried to make intake spacers like this before let alone out of plastic.
I can definitely cut the holes with the waterjet and the paper suggestion is what I was referring to also. Its tough to take measurements off cardboard.
I would just have nice sturdy flanges cut from aluminum, and weld strips of sheet at a width equal to your desired height and then use them to fabricate the walls and top or lid of your spacer, rather than try to machine it from a solid piece of aluminum. As mentioned above, such a piece would be outrageously expensive.
edit :: you could actually then make the "lid" section any shape or dimension desired. The flanges would be relatively cheap, and you could just have 5 or 10 cut. if it only took 3 or 4 to figure out your design, you'd have a few left that you could sell. of course that is assuming that you have the means to weld aluminum, and that there would be a market for them. But it seems like it could be a fairly sought after item if the intake isn't one of a kind. Sorry just skimmed over the thread but wanted to try and give some helpful insight.
I don't think it ever was. I had a friend w/ a machine shop who owed me some $$. I tried to get the work from him, but he ended up just sending me a check for the debt. Since then Powerdubs sold his R w/ the aluminum manifold. I have a spare stock plastic manifold I've considered toying with in this way. I'm not sure how well it would hold up to mods. Even NA you can see the manifold expand and contract under on/off throttle.
