Audi A3/S3 8V VCDS / VAG-COM Modification list
502K views 257 replies 103 participants last post by  clumsy me
#1 · (Edited)
Hi everybody! I'm trying to compile a list of VCDS mods for the new A3 platform, similar to what has been done for other models. This is the first iteration, it would be great if this could be put as a sticky and the first page got updated with new codes or validation of the current ones.
I have not tested any of the codes, I'll be doing that in a couple of weeks with a friend's A3 1.2T.
FULL LIST: (UPDATED FEB 01/2014)
Security Access to modules
If certain module is locked, you should go to "Security Access" and enter the proper code:
For [09] Central Electronics the code is 31347 - TESTED AUDI A3 1.2T ‘13
For [03] ABS Brakes the code is 40168?????????? (doesn’t seem to work)
For [10] Parking aid the code is 71679
[09] CENTRAL ELECTRONICS
Acoustic (Alarm Beep) on Lock - TESTED AUDI A3 1.2T ‘13
NOTE: Car makes one chirping sound, does not use the horn.
[09] Central Electronics -> Adaptation ->
Acknowledgement Signals - Akustische Rueckmeldung verriegeln (Lock acoustic feedback)
CHANGE: Set each or one of them to Yes
Acoustic (Alarm Beep) on Unlock - TESTED AUDI A3 1.2T ‘13
NOTE: Car makes two chirping sounds, does not use the horn.
Acknowledgement Signals - Akustische Rueckmeldung entriegen (Un-lock acoustic feedback)
Acoustic Lock Menu (only for lock, enable/disable using DIS) - TESTED AUDI A3 1.2T ‘13
NOTE: From factory there was no option to enable/disable using DIS.
Acknowledgement Signals -Menuesteuerung akustische Rueckmeldung
CHANGE: Set Yes
Visual confirmation of comfort closing - TESTED AUDI A3 1.2T ‘13
Acknowledgement Signals – Comfort closing ack??? (need to check it back)
CHANGE: Set Yes
Adaptation of the turn signal cycle - TESTED AUDI A3 1.2T ‘13
Channel (2) Select Turn signal control convenience turn signal flasher cycles – Set 1-5 (def=3)
Adjustment of the interval of the headlamp cleaning system (SWRA) - NOT TESTED
Channel (1) - Number of operations front windshield wipers wash per SRA activation – Set value
Channel (3) - windscreen wipers SRA washing time – Set value
Disable DRL's in Light Switch 'O' Position - NOT TESTED
(9) Tagfahrlicht-Tagfahrlicht nur in Schalterstellung AUTO
CHANGE: Set Active
Activation of the parking light the rear lights to LED daytime running lights - NOT TESTED
Channel (6) - daytime running lights activated additionally … -> Active
Disabling the daytime running lights with the handbrake applied - NOT TESTED
Select off when handbrake daytime running lights - channel (5) - Active
Cornering lights with Fog Lights - NOT TESTED
Channel Leuchte12NL LB45-light function B12 -> Adjust Value on cornering left
Channel Leuchte13NL RB5-light function B13 -> Adjust Value on cornering right
Adjusting the speed thresholds for activating the fog lamps - NOT TESTED
Channel (3) select static cornering light lower speed threshold -> Set value (def=0)
Channel (4) select static cornering light upper speed threshold -> Set value (def=32km/h)
[52] DOOR ELECTRONICS, PASSENGER
Passenger-side mirror lowering when reversing - TESTED AUDI A3 1.2T ‘13
[52] Door electronics, passenger -> Long coding -> Byte 04
CHANGE: Enable Bits 2 and 3
[17] INSTRUMENT CLUSTER
Enable Pointer Test / Staging / Staging - TESTED AUDI A3 1.2T ‘13
[17] Instruments -> Coding -> Byte 1 ->
CHANGE: Enable Bit 0
Set Oil Temperature on all DIS Menus - TESTED AUDI A3 1.2T ‘13
[17] Instruments -> Long Coding -> Byte 10
CHANGE: Tick Bit 1. Display Oil Temperature
Activation of the lap timer / lap counter in the FIS - TESTED AUDI A3 1.2T ‘13 (DIDN’T WORK)
NOTE: Seems to work only with Color Information System
[17] Instruments -> Long Coding -> Byte 1 ->
CHANGE: Enable Bit 3
Display the oil temperature gauge in the FIS laptimer (same as above)
Activation of the switching recommendation in the FIS - TESTED AUDI A3 1.2T ‘13
CHANGE: Enable Bit 5
Disable seatbelt warning - TESTED AUDI A3 1.2T ‘13
[17] Instruments -> Long Coding -> Byte 0 ->
CHANGE: Set bits 2-4 using combo box
Adjust tire circumference (bigger tires) - NOT TESTED
[17] Instruments -> Long Coding -> Byte 3 ->
CHANGE: Set bits 0-2 using combo box (not documented)
Deactivation of message / tone with ignition on - NOT TESTED
[17] Instruments -> Adaptation ->
Ignition active message - change to "No display" (Default value: driver's door)
Enable display of cylinder deactivation - NOT TESTED
Select channel cylinder deactivation - Change to enabled (Default value: No display)
Change start screen - NOT TESTED
[17] Instruments -> Long Coding -> Byte 9 ->
Display navigation/compass - NOT TESTED (is compass built int, need to test)
[17] Instruments -> Long Coding -> Byte 10 ->
CHANGE: Set bit 6, and also Byte 9 bit 3 to change position to bottom
Indirect TPMS - NOT TESTED (need coding for [03]Brakes and possibly [19]Canbus)
[17] Instruments -> Long Coding -> Byte 4 ->
CHANGE: Set bit 0
[03] Brakes -> Long Coding -> Byte ??? ->
CHANGE: Set bits ???, ???
[03] BRAKES ELECTRONICS
Adaptation of the dynamic start-off - NOT TESTED
[03] Brakes Electronics -> Adaptation ->
Select Dynamic pull -> Change value (Default value: quick)
Adaptation of Hill Start Assistant - NOT TESTED
Select Berganfahrassistent??? -> Change value
Adaptation of the functional state of the Auto Hold setting - NOT TESTED
Select AUTO HOLD function state -> Set value: (Default: last setting)
Last setting: AUTO HOLD uses the last defined setting which was set over the button
never active: AUTOHOLD not automatically activated
always active: AUTO HOLD always enabled
[10] PARK ASSIST
Adjust Switch Off Speed For Parking Plus - NOT TESTED
[10] Park/Steer Assist -> Adaptation ->
Abschaltgeschwindigkeit fur Einparkhilfe or Switch off speed for parking assist
CHANGE: Set to a speed you like (Standard is 10 km/h)
Adaptation of the threshold for display of the distance to the object - NOT TESTED
[10] Parking aid 2 -> Adaptation ->
Select distance to the curb -> Adjust value (Default value: 15 cm)
Deactivation activation tone of the parking aid - NOT TESTED
Select activation tone for parking aid - Adjust value (Default value: on)
Adjustment of the requirement for lowering the audio when in parking aid - NOT TESTED
Select Request Audio lowering -> Adjust value (Default value: yes)
Visual representation of the parking aid (Audi Parking System APS) - NOT TESTED
[10] Parking aid 2 -> Long coding -> Byte 2 ->
CHANGE: Set Bit 0 - visual representation parking sensors
[5F] Information electronics
Enable / disable the Eject Lock CD / DVD drive (rentals and other situations) - NOT TESTED
[5F] Information Electronics -> Adaptation ->
Select channel CD eject button or eject lock -> Activate (Eject Lock active)
Adjusting the microphone sensitivity - NOT TESTED
[5F] Information electronics -> Adaptation ->
Select Mikrofonempfindlichtkeit (Microphone sensitivity) – Change value
[08] CLIMATRONIC/HVAC
Adjustment of the seat heater level lowering time (level 3 to 2) - NOT TESTED
[08] HVAC -> Adaptation ->
Select time until heated seats redemption level 3 to level 2 -> Adjust value (def=10min)
(Value 0 = no automatic lowering)
Adjustment of the seat heater level lowering time (level 2 to 1) - NOT TESTED
Select time until heated seats redemption level 2 to level 1 -> Adjust value (def=0)
Storage of the last set seat heating stage - NOT TESTED
Select channel storage of the seat heater level driver -> active (def=not active)
Select channel storage of the passenger seat heating stage -> active (def=not active)
Adjusting the reheating of the parking heater??? - NOT TESTED
Select Post-heat heater – Change value (Default: 10 minutes)
[19] CAN BUS
Disable Start-stop - NOT TESTED
[19] Can Gateway -> Adaptation ->
Channel (1) Start/Stop -> Change value from -50 to the new value of 50 - click Do It
Channel (2) Start/Stop -> Change value from -50 to the new value of 50 - click Do It.
OTHER PROCEDURES:
Access MMI engineering menu
The engineering menu can be accessed with the following combination: Back button + Navigation button 1 (top left).
MMI Reset / Restart using monkey grip
The MMI system in the Audi A3 8V can be restarted by following: Menu button + Confirmation button + Navigation key 3 (top right). The MMI then shuts down and restarts. Takes about 30 seconds.
#96 ·
thanks
hi thanks for the tip ,
ill try that , now the Nav system is gone,.i have no idea of what s happening.
we seem to to have the same sort of spec , can you send me ur map , I can see if ur coding works on mine ,
cheers mate
#97 ·
cheers mate
My Scan or M-Bloc's?
#100 ·
This is mine but post the following mods:
Acoustic Alarm on Lock/Unlock
Acoustic Alarm Menu
Seatbelt Alarm Disable
Lap Timer in DIS
Oil Temperature Display in All DIS Menus
Parking Display Active
Ignore the DTC / Errors, they were due to a long VCDS fact finding session and my battery running low.
Chassis Type: 8V (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F
VIN: XXXXX Mileage: XXXXX
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (J623-CJSA) Labels: 06K-907-425-V1.clb
Part No SW: 8V0 906 264 B HW: 06K 907 425 A
Component: 1.8l R4 TFSI H09 0003
Revision: --H09---
Coding: 0A2500322404010B2000
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM18TFS0218V0906264B 001003
ROD: EV_ECM18TFS0218V0906264B_AU37.rod
VCID: 3B72BBC1B230EBF97BD-806E
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 045 P HW: 0AM 927 769 G
Component: GSG DQ200-MQB H43 4530
Revision: 00043014 Serial number: CU501309107614
Coding: 0014
Shop #: WSC 17734 418 534600
ASAM Dataset: EV_TCMDQ200021 001001
ROD: EV_TCMDQ200021_AU37.rod
VCID: 4684DA35F9F2A611143-8013
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379.clb
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 62683000000594
Coding: 13F18AA234212A6C0177060741C529C8512C5480608294F4004100080508
ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001
ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
VCID: 7BF27BC1F2B02BF93BD-802E
2 Faults Found:
32833 - Switch for Electric Parking Brake
C100C 01 [008] - Electrical Failure
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 98
Mileage: 0 km
Date: 2013.10.29
Time: 06:41:52
32928 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 33
Reset counter: 81
Mileage: 6197 km
Date: 2014.11.20
Time: 12:37:41
Address 08: Auto HVAC (E87) Labels: 8V0-820-043.clb
Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
Component: AC Automat H13 0052
Revision: 20025000 Serial number: 00000000161197
Coding: 03100014000000011000000000001100
ASAM Dataset: EV_AirCondiFrontVaAU37X 008020
ROD: EV_AirCondiFrontVaAU37X.rod
VCID: 336293E19A6023B9A3D-8066
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AA HW: 5Q0 937 084 AA
Component: BCM MQBAB H H14 0112
Serial number: 00011326901276
Coding: 07101A46C24120DD03804004B11807A80000000000000000000000000000
ASAM Dataset: EV_BCMCONTI 011001
ROD: EV_BCMBOSCH_AU37.rod
VCID: 77FA67F1CE980F995F5-8022
Slave 1:
Subsystem 1 - Part No SW: 8V2 955 119 C HW: 8V2 955 119 A
Component: WWS371 130825 041 0585
Serial number: 130911003409
Coding: 0A47F7
Slave 3:
Subsystem 2 - Part No SW: 8V0 941 531 J HW: 8V0 941 531 J
Component: E1 - LDS MQB H05 0032
Serial number: 20 05 2013 00001587
Subsystem 3 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY1323145BH
Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000027931362
Subsystem 5 - Part No SW: 8V3 959 591 HW: 8V3 959 591
Component: J245 PS73.009 H02 0007
Serial number: WOO23970296
Coding: 901E00
Subsystem 6 - Part No SW: 8U0 955 559 HW: 8U0 955 559
Component: G355_FeuchteS H07 0002
Serial number: 20469041
1 Fault Found:
197904 - Central Locking
B140A 4B [008] - Over temperature
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 95
Mileage: 7969 km
Date: 2015.03.09
Time: 10:43:22
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-283.clb
Part No SW: 5Q0 919 283 B HW: 5Q0 919 283
Component: PARKHILFE 4K H09 0033
Revision: -------- Serial number: 60831326300552
Coding: 0000050011
ASAM Dataset: EV_EPHVA14AU3700000 002018
ROD: EV_EPHVA14AU3700000_AU37.rod
VCID: 3878A4CD8306C0E196F-806D
Address 15: Airbags (J234) Labels: 5Q0-959-655.clb
Part No SW: 5Q0 959 655 AB HW: 5Q0 959 655 AB
Component: AirbagVW20 014 0385
Serial number: 003MMR009MN%
Coding: 98CCC0000C0000005C5400CA00C800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002130
ROD: EV_AirbaVW20SMEVW37X_AU37.rod
VCID: 00080C2D9B5648216EF-8055
Crash sensor for side airbag; driver side:
Subsystem 1 - Part No SW: ----------- HW: 480 000 409 13
Component: SideSensor_Df 001 0887
Serial number: 35767000000BA3FCBD0H
Coding: 2D2D2D
Crash sensor for side airbag; front passenger side:
Subsystem 2 - Part No SW: ----------- HW: 480 000 409 13
Component: SideSensor_Pf 001 0887
Serial number: 358670000004C20DBD0+
Coding: 2D2D2D
Crash sensor for side airbag; rear; driver side:
Subsystem 3 - Part No SW: ----------- HW: 480 401 609 13
Component: SideSensor_Dr 001 6149
Serial number: 3516502A31118A52F25%
Coding: 2D2D2D
Crash sensor for side airbag; rear; passenger side:
Subsystem 4 - Part No SW: ----------- HW: 480 401 609 13
Component: SideSensor_Pr 001 6149
Serial number: 3526502A311FBEB2B24M
Coding: 2D2D2D
Crash sensor for front airbag; driver side:
Subsystem 5 - Part No SW: ----------- HW: 480 401 109 13
Component: FrontSensor_D 001 6149
Serial number: 3556502A91118A526283
Coding: 2D2D2D
Pedestrian protection crash sensor; driver side:
Subsystem 6 - Part No SW: ----------- HW: 480 401 109 13
Component: PedP_Sensor_D 001 6149
Serial number: 2286502B11118A53838%
Coding: 2D2D2D
Pedestrian protection crash sensor; front passenger side:
Subsystem 7 - Part No SW: ----------- HW: 480 401 109 13
Component: PedP_Sensor_P 001 6149
Serial number: 2296502AD1118A546313
Coding: 2D2D2D
Pedestrian Protection Driver 2:
Subsystem 8 - Part No SW: ----------- HW: 480 002 108 13
Component: PedPSensor_D2 001 0887
Serial number: I0M80000000694249D09
Coding: 2D2D2D
Pedestrian Protection Passenger 2:
Subsystem 9 - Part No SW: ----------- HW: 480 002 108 13
Component: PedPSensor_P2 001 0887
Serial number: I0N80000000C44249D0B
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 8V0 953 521 F HW: 5Q0 953 549 A
Component: Lenks. Modul 007 0070
Revision: -------- Serial number: 26091304220118
Coding: 8018
ASAM Dataset: EV_SMLSKLOMQB 009001
ROD: EV_SMLSKLOMQB_AU37.rod
VCID: 3D76B5D9AC24E5C9459-8068
Address 17: Instruments (J285) Labels: 5G0-920-XXX-17.clb
Part No SW: 8V0 920 970 M HW: 8V0 920 970 M
Component: KOMBI H03 2212
Coding: 238D19082A8046000100EA00000000
Shop #: WSC 04698 001 104857
ASAM Dataset: EV_DashBoardVDDMQBAB 008031
ROD: EV_DashBoardVDDMQBAB_AU37.rod
Address 19: CAN Gateway (J533) Labels: Redir Fail!
Part No SW: 5Q0 907 530 M HW: 5Q0 907 530 M
Component: GW MQB High 212 2147
Revision: -------- Serial number: 20091310801689
Coding: 030100042B085A005B0002481C0B00000001000000000000000000000000
ASAM Dataset: EV_GatewConti 009011
ROD: EV_GatewConti_AU37.rod
Alternator:
Multifunction unit control module:
Subsystem 2 - Part No SW: 8U0 951 528 C HW: 8U0 951 528 C
Component: E221 - MFL H02 0014
Serial number: 17 09 2013 C0342910
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 D HW: 5Q0 915 181 D
Component: J367-BDM H08 0192
Serial number: 00000000004051110240
Address 42: Door Elect, Driver (J386) Labels: 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 A HW: 5Q0 959 593
Component: TSG FS 012 0006
Serial number: 07081304081240
Coding: 00108E205C01040000001002
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 3F8ACFD1A628F7D9575-806A
Address 44: Steering Assist (J500) Labels: 5Q0-909-144.clb
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 M
Component: EPS_MQB_ZFLS 127 1021
Coding: 81
ASAM Dataset: EV_SteerAssisMQB 008022
ROD: EV_SteerAssisMQB.rod
Address 52: Door Elect, Pass. (J387) Labels: 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 A HW: 5Q0 959 592
Component: TSG BFS 012 0006
Serial number: 13091303111490
Coding: 001086205E01040000001002
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 3E74B2D5A122FED15C3-806B
Address 55: Headlight Range (J431) Labels: 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Revision: -------- Serial number: --------------
Coding: 019C000001000000
Shop #: WSC 04698 001 1048576
ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
ROD: EV_HeadlRegulVWLWRMQB_AU37.rod
VCID: 75E66DF9D4947D894D9-8020
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 8V0 035 874 B HW: 8V0 035 874 B
Component: MU-S-ND-ER 040 0420
Serial number: A7F01809130964
Coding: 01730101FF00000021111101000A00002F0004460100010006
ASAM Dataset: EV_MUStd6C3PASE 002010
ROD: EV_MUStd6C3PASE_AU37.rod
Engine Control Module 2:
Subsystem 1 - Part No SW: 8V0 919 866 B HW: -----------
Component: ECE 2014 --- 0036
Serial number: --------------------
Seat Adjustment Driver Side:
Subsystem 2 - Part No SW: 8V0 919 603 C HW: 8V0 919 603 C
Component: DU Std H48 0013
Serial number: AUZ8Z9DY3000NS
Sound System:
Subsystem 3 - Part No SW: 8V0 919 614 B HW: 8V0 919 614 B
Component: ControlUnit_B H33 0037
Serial number: C1000027071300020767
End-------------------------(Elapsed Time: 03:56)--------------------------
#102 ·
In my haste of testing things with VCDS, I forgot to note a default setting for one adaptation. Can someone who has VCDS look at [09] Central Electronics -> 10 - Adaptation -> (9) Leuchte27NSL RC6-light function D27 and let me know what the default setting is? I was attempting to get the rear DRL working and forgot to log or write down what it was. It doesn't appear to affect anything, but I'd rather reset it to default just in case.
#103 ·
adaption map
Hello Audi fellas,
I m using a vagcom 12.12 and I have the feeling that some of the adaptions arent labeled correctly.
I was playing around with the hope i d find my nav system, but still nothing.
Can i trouble one of you with a adaption map for 5f ,09 and 17.
I have the feeling that I have a messed the wrong one up .
thanks guys
A3 8v sedan 1.8 quattro sline teck pack mmi
#104 ·
Hello Audi fellas,
thanks guys
Probably because 12.12 is outdated and they're on 14.10. You can download the latest version from them.
Also if you go to the ross-tech directory, ie C:\Ross-Tech\VCDS\Debug, there is a file called CodingLog.txt which has all the changes you made.
Not sure why you wouldn't just ask on the Ross-Tech forums, unless you have a pirated cable+software, in which case you might have screwed up your car with it.
#105 ·
Help still needed no navigation
I was under the impression I had bought a genuine ross tech cable, but when I have emailed ross tech they said it wasn't ! Auch .
i tried to up grade the software but i had to revert to to old one as it wouldn t work with my so called pirated cable.
when I went back to 12.12 all my files on debug and logs were wiped out.
Any way story of my life ..
i would gladly appreciate if any one with a 1.8 Quattro with the std mmi nav plus ( no sim) could send me their adaption maps for 09 ,17,19 and most important 5F so that i could compare and see if i can get my navigation menu back up.
#106 · (Edited)
Did you check the codinglog.txt file for all the changes that you had made? it should have it all recorded so you can revert back to what it was originally? It writes to it all the time. Unless you are using a different computer, it should all still be there. It's in the debug folder in the directory you installed the software.
Should be a bunch of text like this inside. This was me messing with my car since I got it in sept and on my previous GTI, and it recorded all the changes it ever made.
Code:
Address 19:7N0 907 530 C recoded (Installation List) from ED807E0200161200 to ED807E0600161200  Sunday,27,July,2014,17:48:22:06722
Address 09:1K0 937 086 L recoded (Long Coding) from 6D190A3A90272AC400880081700081C444011F88435D8D60648920200040 to 6D190A3A90272AC400880081700081C444010388435D8D60648920200040  (01357/011/00200)  Sunday,27,July,2014,17:49:10:06722
Address 09:1K0 937 086 L recoded (Long Coding) from 6D190A3A90272AC400880081700081C444010388435D8D60648920200040 to 6D190A3A90272AC400880081700081C444010088435D8D60648920200040  (01357/011/00200)  Sunday,27,July,2014,17:53:13:06722
Address 37:3C0 035 684 J recoded (Long Coding) from 0400004004000092000C to 0400044004000082000C  (01324/020/00200)  Saturday,02,August,2014,16:10:59:06722
Address 37:3C0 035 684 J recoded (Long Coding) from 0400044004000082000C to 04000440040000A2000C  (01324/020/00200)  Saturday,02,August,2014,16:11:56:06722
Address 37:3C0 035 684 J recoded (Long Coding) from 04000440040000A2000C to 04000440040000A0000C  (01324/020/00200)  Saturday,02,August,2014,16:14:47:06722
Address 37:3C0 035 684 J recoded (Long Coding) from 04000440040000A0000C to 0400044004000090000C  (01324/020/00200)  Saturday,02,August,2014,16:33:48:06722
Address 09:5K0 937 086 N recoded (Long Coding) from 6F180A3B88232EC4008800C135000DCC4C75AE06576D8DF0E4846020A040 to 6F180A3B88232EC4008800C135000DCC4C75AE06577D8DF0E48C6020A040  (43432/123/104857)  Saturday,02,August,2014,16:37:44:06722
Address 10:5Q0 919 294 J recoded (Long Coding) from 0070150011 to 0070151811  (06385/790/00016)  Saturday,13,September,2014,19:58:46:06722
Address 10:5Q0 919 294 J recoded (Long Coding) from 0070150011 to 0070150811  (06385/790/00016)  Saturday,13,September,2014,19:59:15:06722
Address 17:8V0 920 971 G recoded (Long Coding) from 0BC418196F88D7050280E8001800000000000000 to 0BC518196F88D7050280E8001800000000000000  (06385/790/00016)  Saturday,13,September,2014,20:03:36:06722
Address 44:5Q0 909 144 P recoded (Long Coding) from 1102 to 9102  (06385/790/00016)  Saturday,13,September,2014,20:04:42:06722
Address 13:5Q0 907 572 D recoded (ADP-Multiple assignment of buttons in multi-function steering wheel) from OFF  to On   Monday,15,September,2014,14:46:11:06722
Address 13:5Q0 907 572 D recoded (ADP-Multiple assignment of buttons in multi-function steering wheel) from On  to OFF   Monday,15,September,2014,14:46:59:06722
Address 10:5Q0 919 294 J recoded (ADP-Switch-off speed for parking assist) from 10 km/h to 16 km/h  Monday,15,September,2014,14:48:35:06722
Address 08:8V0 820 043 D recoded (Long Coding) from 03000014010000000000000000001400 to 03000014010000000000004000001400  (06385/790/00016)  Monday,15,September,2014,14:51:08:06722
Address 08:8V0 820 043 D recoded (Long Coding) from 03000014010000000000004000001400 to 03000014010000000000000000001400  (06385/790/00016)  Monday,15,September,2014,14:51:59:06722
Address 05:5Q0 959 435 A recoded (Long Coding) from 030C0C to 030C1C  (00000/000/00000)  Monday,15,September,2014,14:53:51:06722
Address 05:5Q0 959 435 A recoded (Long Coding) from 030C1C to 030C0C  (12345/123/12345)  Monday,15,September,2014,20:05:59:06722
Address 55:7P6 907 357 C recoded (Long Coding) from 012A000123200400 to 012A00013F200400  (06385/790/00016)  Monday,15,September,2014,20:11:32:06722
Address 55:7P6 907 357 C recoded (Long Coding) from 012A00013F200400 to 012A00013B200400  (06385/790/00016)  Tuesday,16,September,2014,10:38:19:06722
Address 55:7P6 907 357 C recoded (Long Coding) from 012A00013B200400 to 012A000123200400  (06385/790/00016)  Tuesday,16,September,2014,10:39:48:06722
Address 55:7P6 907 357 C recoded (Long Coding) from 012A000123200400 to 012A00013B200400  (06385/790/00016)  Tuesday,16,September,2014,10:47:10:06722
Address 55:7P6 907 357 C recoded (Long Coding) from 012A00013B200400 to 012A000123200400  (06385/790/00016)  Tuesday,16,September,2014,10:48:47:06722
Address 09:5Q0 937 085 AB recoded (ADP-(4)-static AFS light-Upper speed threshold) from 32.00 km/h to 48 km/h  Tuesday,16,September,2014,10:58:00:06722
Address 09:5Q0 937 085 AB recoded (ADP-(15)-Access control 2-Regenschliessen_ein_aus) from not active  to active   Tuesday,16,September,2014,22:23:30:06722
Address 09:5Q0 937 085 AB recoded (ADP-(16)-Access control 2-Regenschliessen_art) from once  to Permanent   Tuesday,16,September,2014,22:23:59:06722
Address 09:5Q0 937 085 AB recoded (ADP-(28)-Access control 2-Menuesteuerung Regenschliessen) from not active  to active   Tuesday,16,September,2014,22:24:11:06722
Address 09:5Q0 937 085 AB recoded (ADP-(15)-Access control 2-Regenschliessen_ein_aus) from active  to not active   Tuesday,16,September,2014,22:38:46:06722
Address 09:5Q0 937 085 AB recoded (ADP-(16)-Access control 2-Regenschliessen_art) from Permanent  to once   Tuesday,16,September,2014,22:39:01:06722
Address 09:5Q0 937 085 AB recoded (ADP-(28)-Access control 2-Menuesteuerung Regenschliessen) from active  to not active   Tuesday,16,September,2014,22:40:20:06722
Address 10:5Q0 919 294 J recoded (ADP-Switch-off speed for parking assist) from 16 km/h to 12 km/h  Tuesday,16,September,2014,22:52:25:06722
Address 09:5Q0 937 085 AB recoded (ADP-(10)-Leuchte2SL VLB10-Dimmwert CD 2) from 30  to 100   Thursday,25,September,2014,10:24:32:06722
Address 09:5Q0 937 085 AB recoded (ADP-(10)-Leuchte3SL VRB21-Dimmwert CD 3) from 30  to 100   Thursday,25,September,2014,10:25:32:06722
Address 09:5Q0 937 085 AB recoded (ADP-(10)-Leuchte2SL VLB10-Dimmwert CD 2) from 100  to 30   Thursday,25,September,2014,10:39:24:06722
Address 09:5Q0 937 085 AB recoded (ADP-(10)-Leuchte3SL VRB21-Dimmwert CD 3) from 100  to 30   Thursday,25,September,2014,10:40:45:06722
Address 55:7P6 907 357 C recoded (Long Coding) from 012A000123200400 to 012A00003B200400  (06385/790/00016)  Monday,13,October,2014,20:32:52:06722
Address 09:5Q0 937 085 AB recoded (ADP-(10)-Leuchte2SL VLB10-Dimmwert CD 2) from 30  to 100   Monday,13,October,2014,20:58:12:06722
Address 09:5Q0 937 085 AB recoded (ADP-(6)-Leuchte2SL VLB10-Dimmwert AB 2) from 30  to 100   Monday,13,October,2014,20:59:31:06722
Address 09:5Q0 937 085 AB recoded (ADP-(6)-Leuchte3SL VRB21-Dimmwert AB 3) from 30  to 100   Monday,13,October,2014,21:01:39:06722
Address 09:5Q0 937 085 AB recoded (ADP-(6)-Leuchte3SL VRB21-Dimmwert AB 3) from 30  to 100   Monday,13,October,2014,21:02:35:06722
Address 09:5Q0 937 085 AB recoded (ADP-(10)-Leuchte3SL VRB21-Dimmwert CD 3) from 30  to 100   Monday,13,October,2014,21:02:51:06722
#107 ·
I have that file, but it doesn't go back far enough.
I made some changes then decided to quickly run an update of the software.
My issue is that the navigation system is not showing at all.
I can t find any adaptions for the navigation menu, just a bunch of adaptions about online maps my audi etc ,
#115 ·
Just got my cable in a few days ago and finally started messing around yesterday. Did/confirmed the following, as others have-
- Oil Temp in DIS
- Seat Belt Warning/chime inactive
- Needle staging on startup
I haven't looked yet - but am curious. Has anyone figured out:
1 - If we can display the gear # next to D/S mode like it does when in Manual mode? (D1, D2, D3, etc)
2 - Secondly, Is there a way to default the MMI screen from NOT popping up on startup, but instead when hitting the screen button or radio knob? I find myself lowering the screen a lot at night after startup. While I am not complaining about the effort involved, I would like to preserve the life of the motor/screen if I can.
EDIT: Just saw this post above, so good to know im not the only one curious!
#109 ·
19 can gateway
ok ,I just checked my installation list on 19 and the Navigation is missing the Tick ,
I ticked it and it wont save the code , it tried an other box and nothing happens
Error 24 sequence error
any Idea?
do I need a security code for 19 ?
#110 ·
any Idea?
To be honest, it may just be the software is not compatible with your car, in fact VCDS would not even show the quattro/haldex module on my car at all. I had to contact them and have them fix it over 3 software updates (which I had to beta test) before I could even access the module and it would show up on the installation list. Given the number of changes that have occurred since version 12, to support the mqb platform, you may not be able to do anything.
I think you're going to have to do 1 of 2 things. 1. Go to the dealer and let them fix everything. 2. Actually buy a real VCDS cable and have them walk you though fixing anything that remains broken.
#111 ·
DRL wink VCDS for Xenon Headlamp US Spec
I am trying to code the DRL for the Xenon Headlamp so it doesn't wink, but whenever I try to change the code for any of the "dimmwert" (whether it be AB or GH, 2 or 3), i get an error for "incorrect message length or invalid format.
Does anybody with a US spec S3 have the proper coding or a solution for this?
Screencap of my error below.
#112 ·
Access Code 31347
Adaptation-10
(18)-Leuchte2SL VLB10-Dimmwert GH 2 -- Set to xx% (xx = any number from 0-100)
(18)-Leuchte2SL VLB21-Dimmwert GH 3 -- Set to xx% (xx = any number from 0-100)
#114 ·
Stop /Start GONE!
Hello Guys ,
I can confirm that I disabled my START STOP Function.
Go to [19] Adaption 10
Address 19:5Q0 907 530 Q recoded (ADP-Start/stop start voltage limit) from 7.6 V to 12.1 V
I m not exactly sure how this is even possible but my Start Stop is disabled now.
Winning!
My headlights were on and so was the radio... ill check in the morning to see if it works with the electronic off
#116 ·
Hello Guys ,
Winning!
I wonder if this would work, if the voltage ends up being too finicky:
http://www.vwgolf.net.au/showthread.php?20132-Disable-the-STOP-START-system-on-Mk7-Golf-s
#117 ·
I haven't been on this board for a while. 6 months ago I traded in my 2009 A4 for a 2015 A3. The chassis code for most models I'm seeing on this and other thread is 8V, mine is FF. I haven't been able to do much with my VCDS cable. Is the coding for the FF the same as the 8V? I'm most interested in disabling the seat belt chime (my 50 lb dog does not wear seat belts) and I kind of like the needle sweep. Thanks.
#118 ·
I've been attempting to get the rear turns to alternate from the inside and outside LEDs. The codes I've found from other forums don't seem to work with US models so I started digging around and got the top outside LEDs to blink out of phase. I was attempting to find the lower outside LEDs but gave up since I got tired of having to get up and walk to the back after every change.
Has anyone successfully completed the full mod with a US spec car?
Blink Top Outside Rear Out of Phase
10 - Adaptation
Driver Side
(12)-Leuchte18BLK HLA60-Lichtfunktion E 18
Change from Blinken Links Hellphase to Blinken links Dunkelphase
Passenger Side
(12)-Leuchte19BLK HRC31-Lichtfunktion E 19
Change from Blinken rechts Hellphase to Blinken rechts Dunkelphase
https://flic.kr/p/ryeio3
#120 ·
For the front DRL and turn signal out of phase
Select STG 09 ( Central elec)
Access Security -> 31347 -> Login
Adaptation 10. Change the following values:
(16) Leuchte2SL VLB10 - LichtfunktionG2 to " Blinken links Hellphase "
(18) Leuchte2SL VLB10 - Dimmung GH2 to "0"
(16) Leuchte3SL VRB21 - LichtfunktionG3 to " Blinken rechts Hellphase "
(18) Leuchte3SL VRB21 Dimmwert GH - 3 to "0"
#125 ·
#126 ·
#128 ·
VIM cannot be done via VCDS and RossTech are not gonna support it. At this time only VCP (VagCan Pro) can modify VIM.
#129 ·
didn't see this on here, and can't open the document at work, so I thought I would throw this on here:
Exhaust flaps all open - S3
1 – Engine module
Long Coding Helper
Byte 9
Bit 2 - Exhaust Flaps installed check box default activated – deactivate it and save as usual.
Car seems a bit louder off throttle and at lower RPM when the flaps are normally closed.
#130 ·
Quick question - does this keep them open all the time no matter what the driving mode? Or only in say dynamic? I have a full exhaust, and even in dynamic I hear the valves open & close when I come to say a stop at a light. This would be ideal if they're always open in dynamic or something.
#150 ·
I'm also waiting on this one too.
I have seen in vagcom that you can configure your headlights for geographic area (NA, Europe, Australia, etc)
I wonder if setting this to a specific area in central electric will disable the ambers automatically.
-cW
