Fourtitude.com - Audi A3/S3 8V VCDS / VAG-COM Modification list
    Page 1 of 11 12345 ... LastLast
    Results 1 to 25 of 251
    1. Junior Member
      Jun 3rd, 2011
      Montevideo, Uruguay
      70
      2012 Jetta GLI 2.0T
      01-22-2014 01:54 PM #1
      Hi everybody! I'm trying to compile a list of VCDS mods for the new A3 platform, similar to what has been done for other models. This is the first iteration, it would be great if this could be put as a sticky and the first page got updated with new codes or validation of the current ones.
      I have not tested any of the codes, I'll be doing that in a couple of weeks with a friend's A3 1.2T.
      FULL LIST: (UPDATED FEB 01/2014)
      Security Access to modules
      If certain module is locked, you should go to "Security Access" and enter the proper code:
      For [09] Central Electronics the code is 31347 - TESTED AUDI A3 1.2T ‘13
      For [03] ABS Brakes the code is 40168?????????? (doesn’t seem to work)
      For [10] Parking aid the code is 71679
      [09] CENTRAL ELECTRONICS
      Acoustic (Alarm Beep) on Lock - TESTED AUDI A3 1.2T ‘13
      NOTE: Car makes one chirping sound, does not use the horn.
      [09] Central Electronics -> Adaptation ->
      Acknowledgement Signals - Akustische Rueckmeldung verriegeln (Lock acoustic feedback)
      CHANGE: Set each or one of them to Yes
      Acoustic (Alarm Beep) on Unlock - TESTED AUDI A3 1.2T ‘13
      NOTE: Car makes two chirping sounds, does not use the horn.
      Acknowledgement Signals - Akustische Rueckmeldung entriegen (Un-lock acoustic feedback)
      Acoustic Lock Menu (only for lock, enable/disable using DIS) - TESTED AUDI A3 1.2T ‘13
      NOTE: From factory there was no option to enable/disable using DIS.
      Acknowledgement Signals -Menuesteuerung akustische Rueckmeldung
      CHANGE: Set Yes
      Visual confirmation of comfort closing - TESTED AUDI A3 1.2T ‘13
      Acknowledgement Signals – Comfort closing ack??? (need to check it back)
      CHANGE: Set Yes
      Adaptation of the turn signal cycle - TESTED AUDI A3 1.2T ‘13
      Channel (2) Select Turn signal control convenience turn signal flasher cycles – Set 1-5 (def=3)
      Adjustment of the interval of the headlamp cleaning system (SWRA) - NOT TESTED
      Channel (1) - Number of operations front windshield wipers wash per SRA activation – Set value
      Channel (3) - windscreen wipers SRA washing time – Set value
      Disable DRL's in Light Switch 'O' Position - NOT TESTED
      (9) Tagfahrlicht-Tagfahrlicht nur in Schalterstellung AUTO
      CHANGE: Set Active
      Activation of the parking light the rear lights to LED daytime running lights - NOT TESTED
      Channel (6) - daytime running lights activated additionally … -> Active
      Disabling the daytime running lights with the handbrake applied - NOT TESTED
      Select off when handbrake daytime running lights - channel (5) - Active
      Cornering lights with Fog Lights - NOT TESTED
      Channel Leuchte12NL LB45-light function B12 -> Adjust Value on cornering left
      Channel Leuchte13NL RB5-light function B13 -> Adjust Value on cornering right
      Adjusting the speed thresholds for activating the fog lamps - NOT TESTED
      Channel (3) select static cornering light lower speed threshold -> Set value (def=0)
      Channel (4) select static cornering light upper speed threshold -> Set value (def=32km/h)
      [52] DOOR ELECTRONICS, PASSENGER
      Passenger-side mirror lowering when reversing - TESTED AUDI A3 1.2T ‘13
      [52] Door electronics, passenger -> Long coding -> Byte 04
      CHANGE: Enable Bits 2 and 3
      [17] INSTRUMENT CLUSTER
      Enable Pointer Test / Staging / Staging - TESTED AUDI A3 1.2T ‘13
      [17] Instruments -> Coding -> Byte 1 ->
      CHANGE: Enable Bit 0
      Set Oil Temperature on all DIS Menus - TESTED AUDI A3 1.2T ‘13
      [17] Instruments -> Long Coding -> Byte 10
      CHANGE: Tick Bit 1. Display Oil Temperature
      Activation of the lap timer / lap counter in the FIS - TESTED AUDI A3 1.2T ‘13 (DIDN’T WORK)
      NOTE: Seems to work only with Color Information System
      [17] Instruments -> Long Coding -> Byte 1 ->
      CHANGE: Enable Bit 3
      Display the oil temperature gauge in the FIS laptimer (same as above)
      Activation of the switching recommendation in the FIS - TESTED AUDI A3 1.2T ‘13
      CHANGE: Enable Bit 5
      Disable seatbelt warning - TESTED AUDI A3 1.2T ‘13
      [17] Instruments -> Long Coding -> Byte 0 ->
      CHANGE: Set bits 2-4 using combo box
      Adjust tire circumference (bigger tires) - NOT TESTED
      [17] Instruments -> Long Coding -> Byte 3 ->
      CHANGE: Set bits 0-2 using combo box (not documented)
      Deactivation of message / tone with ignition on - NOT TESTED
      [17] Instruments -> Adaptation ->
      Ignition active message - change to "No display" (Default value: driver's door)
      Enable display of cylinder deactivation - NOT TESTED
      Select channel cylinder deactivation - Change to enabled (Default value: No display)
      Change start screen - NOT TESTED
      [17] Instruments -> Long Coding -> Byte 9 ->
      Display navigation/compass - NOT TESTED (is compass built int, need to test)
      [17] Instruments -> Long Coding -> Byte 10 ->
      CHANGE: Set bit 6, and also Byte 9 bit 3 to change position to bottom
      Indirect TPMS - NOT TESTED (need coding for [03]Brakes and possibly [19]Canbus)
      [17] Instruments -> Long Coding -> Byte 4 ->
      CHANGE: Set bit 0
      [03] Brakes -> Long Coding -> Byte ??? ->
      CHANGE: Set bits ???, ???
      [03] BRAKES ELECTRONICS
      Adaptation of the dynamic start-off - NOT TESTED
      [03] Brakes Electronics -> Adaptation ->
      Select Dynamic pull -> Change value (Default value: quick)
      Adaptation of Hill Start Assistant - NOT TESTED
      Select Berganfahrassistent??? -> Change value
      Adaptation of the functional state of the Auto Hold setting - NOT TESTED
      Select AUTO HOLD function state -> Set value: (Default: last setting)
      Last setting: AUTO HOLD uses the last defined setting which was set over the button
      never active: AUTOHOLD not automatically activated
      always active: AUTO HOLD always enabled
      [10] PARK ASSIST
      Adjust Switch Off Speed For Parking Plus - NOT TESTED
      [10] Park/Steer Assist -> Adaptation ->
      Abschaltgeschwindigkeit fur Einparkhilfe or Switch off speed for parking assist
      CHANGE: Set to a speed you like (Standard is 10 km/h)
      Adaptation of the threshold for display of the distance to the object - NOT TESTED
      [10] Parking aid 2 -> Adaptation ->
      Select distance to the curb -> Adjust value (Default value: 15 cm)
      Deactivation activation tone of the parking aid - NOT TESTED
      Select activation tone for parking aid - Adjust value (Default value: on)
      Adjustment of the requirement for lowering the audio when in parking aid - NOT TESTED
      Select Request Audio lowering -> Adjust value (Default value: yes)
      Visual representation of the parking aid (Audi Parking System APS) - NOT TESTED
      [10] Parking aid 2 -> Long coding -> Byte 2 ->
      CHANGE: Set Bit 0 - visual representation parking sensors
      [5F] Information electronics
      Enable / disable the Eject Lock CD / DVD drive (rentals and other situations) - NOT TESTED
      [5F] Information Electronics -> Adaptation ->
      Select channel CD eject button or eject lock -> Activate (Eject Lock active)
      Adjusting the microphone sensitivity - NOT TESTED
      [5F] Information electronics -> Adaptation ->
      Select Mikrofonempfindlichtkeit (Microphone sensitivity) – Change value
      [08] CLIMATRONIC/HVAC
      Adjustment of the seat heater level lowering time (level 3 to 2) - NOT TESTED
      [08] HVAC -> Adaptation ->
      Select time until heated seats redemption level 3 to level 2 -> Adjust value (def=10min)
      (Value 0 = no automatic lowering)
      Adjustment of the seat heater level lowering time (level 2 to 1) - NOT TESTED
      Select time until heated seats redemption level 2 to level 1 -> Adjust value (def=0)
      Storage of the last set seat heating stage - NOT TESTED
      Select channel storage of the seat heater level driver -> active (def=not active)
      Select channel storage of the passenger seat heating stage -> active (def=not active)
      Adjusting the reheating of the parking heater??? - NOT TESTED
      Select Post-heat heater – Change value (Default: 10 minutes)
      [19] CAN BUS
      Disable Start-stop - NOT TESTED
      [19] Can Gateway -> Adaptation ->
      Channel (1) Start/Stop -> Change value from -50 to the new value of 50 - click Do It
      Channel (2) Start/Stop -> Change value from -50 to the new value of 50 - click Do It.
      OTHER PROCEDURES:
      Access MMI engineering menu
      The engineering menu can be accessed with the following combination: Back button + Navigation button 1 (top left).
      MMI Reset / Restart using monkey grip
      The MMI system in the Audi A3 8V can be restarted by following: Menu button + Confirmation button + Navigation key 3 (top right). The MMI then shuts down and restarts. Takes about 30 seconds.
    3. Geriatric Member Dan Halen's Avatar
      May 16th, 2002
      Dougal County
      42,790
      2008 Cayman S, 2006 GLI, 2008 Rabbit
      01-22-2014 01:56 PM #2
      Daaaaaaaaaaang!
      Once I get the FAQ for the forum set up, this will be the first thread to go into it. I don't imagine we'll have a whole lot of development here until we get the US cars on the ground, but you've already saved us a lot of time. Thanks!
      Ride In: 2008 Signal Green Cayman S Sport 378/700 .:. 2006 Plat Grey GLI .:. 2008 Sage Green Rabbit
      Ride On: 2010 Trek 2.1 .:. 2011 Fisher Cobia
    4. 01-22-2014 04:31 PM #3
      Awesome. I see start/stop deactivation listed... will that allow full defeat of the system even after restarting the car?
    6. Member mike3141's Avatar
      Feb 16th, 1999
      3,719
      2012 A3 2.0TQ
      01-22-2014 04:41 PM #4
      I believe that with start/stop there's a button which disables it--the 2nd from the left:
    7. Junior Member
      Dec 18th, 2000
      73
      2013 Audi S4
      01-22-2014 04:45 PM #5
      Curious, some of those items seem like they should be easily adjusted through the MMI system, eg: alarm beep on lock/unlock and the mirrors dipping on reverse.
      Nice starting list though.
    8. 01-22-2014 06:13 PM #6
      Quote Originally Posted by mike3141 View Post
      Correct but it likely re-enables with each cycle of the ignition and has to be disabled every time the car starts. It's pretty herky in cars I've been in with this feature.
    9. Junior Member
      Jun 3rd, 2011
      Montevideo, Uruguay
      70
      2012 Jetta GLI 2.0T
      01-23-2014 08:39 AM #7
      Quote Originally Posted by v6er View Post
      Thanks!
      From what I've read, to activate the alarm beep on lock option on the MMI you have to use VCDS, at least in some A3s as the option is disabled. Also Beep on unlock does not seem to be configurable via MMI so far (I'm sure the option is there but hasn't been found).
    10. Geriatric Member Dan Halen's Avatar
      May 16th, 2002
      Dougal County
      42,790
      01-23-2014 09:13 AM #8
      If you have access to a non-LED headlamp car, can you poke around a bit and see if there's a way to get the running light diffuser to also serve as the turn signal? I know it's integrated into the diffuser in the LED headlamp, and I know the xenon headlamp has a dedicated filament turn signal, but I'm not willing to completely write off the possibility that Audi puts a dual-color LED setup into the diffuser in all headlamps and just deactivates the turn signal functionality in non-LED cars.
    11. Junior Member
      Jun 3rd, 2011
      Montevideo, Uruguay
      70
      2012 Jetta GLI 2.0T
      01-23-2014 10:13 AM #9
      I'll do that. The 1.2T has been ordered with Xenon Plus Headlights so at least we have the proper hardware.
    12. 01-23-2014 01:09 PM #10
      do you guys know what is the vagcom equivalent for mercedes cars?
    13. Member mike3141's Avatar
      Feb 16th, 1999
      3,719
      2012 A3 2.0TQ
      01-23-2014 01:20 PM #11
    14. 01-23-2014 02:21 PM #12
      thanks! been asking in the CLA forum but people there are not too technical (shhh!), all they seem to care about is the illuminated star. Oh well...
    15. 01-23-2014 11:54 PM #13
      fxtsi, look forward to your test result! especially on the mirror dipping during reverse and start/stop!
    16. Member
      Nov 30th, 2013
      Toronto
      269
      01-24-2014 07:52 AM #14
      Quote Originally Posted by lotusfirst View Post
      interested in mirror dipping as well myself.
      2017 B9 A4 on order
    17. Geriatric Member Dan Halen's Avatar
      May 16th, 2002
      Dougal County
      42,790
      01-24-2014 09:10 AM #15
      Traditionally, mirror dipping has been dependent on power seats. I hope they can buck that trend and hook it up for the S3, which won't have power seats if the super sport seat option is selected.
    18. 01-24-2014 01:22 PM #16
      A model year or two of the 8P had the ability to adjust weighting of the steering via vagcom. Sounds like the weighting of the 8V is borderline even in Dynamic mode. Odds it'll be adjustable? The Drive Select parameters, are they at the high/low of an unseen range already or is it possible there's adjustable wiggle room with the right coding?
    19. Geriatric Member Dan Halen's Avatar
      May 16th, 2002
      Dougal County
      42,790
      01-24-2014 01:57 PM #17
      I can't speak to coding, but I can say that some review I read recently claimed that weighting is at a BMW level in the most aggressive mode with Drive Select.
    20. Junior Member
      Jun 3rd, 2011
      Montevideo, Uruguay
      70
      2012 Jetta GLI 2.0T
      01-31-2014 09:35 PM #18
      Ok, here we go, I had the car today. It was a base 1.2T version, with the only upgrade being Xenon headlights/rear leds and Audi Sound System with subwoofer. Not a great number of modules to play with, and also VCDS 12.12 didn't have most of the labels, specially in [09] Central electronics. Also most of the labels were in german, so it was difficult to understand.
      Here's the autoscan (the car had some errors as they tried an external chip):
      Friday,31,January,2014,19:30:22:13006
      VCDS -- Windows Based VAG/VAS Emulator
      VCDS Version: 12.12.0.0
      Data version: 20130910
      VIN: ??? License Plate: AUDI
      Chassis Type: 8V (5Q0)
      Scan: 01 03 08 09 15 16 17 19 42 44 52 55 5F
      VIN:----------------
      01-Engine -- Status: Malfunction 0010
      03-ABS Brakes -- Status: Malfunction 0010
      08-Auto HVAC -- Status: OK 0000
      09-Cent. Elect. -- Status: OK 0000
      15-Airbags -- Status: OK 0000
      19-CAN Gateway -- Status: OK 0000
      44-Steering Assist -- Status: OK 0000
      55-Xenon Range -- Status: OK 0000
      5F-Information Electr. -- Status: OK 0000
      Address 01: Engine (J623-CJZA) Labels: 04E-907-309-V1.clb
      Part No SW: 04E 906 016 B HW: 04E 907 309 A
      Component: 1.2l R4 TSI H08 6387
      Revision: WAH08---
      Coding: 02110012230400082000
      Shop #: WSC 06314 790 00021
      ASAM Dataset: EV_ECM12TFS01104E906016B 001008
      ROD: EV_ECM12TFS01104E906016B.rod
      VCID: 21422E4530FB2416BBD-8074
      4 Faults Found:
      4124 - Sensor Reference Voltage B
      P0651 00 [032] - Open Circuit
      Intermittent - Not Confirmed - Tested Since Memory Clear
      Freeze Frame:
      Fault Status: 00000001
      Fault Priority: 2
      Fault Frequency: 1
      Mileage: 38 km
      Date: 2014.01.30
      Time: 19:26:54
      20120 - Manifold Pressure / Boost Sensor (G31)
      P0237 00 [096] - Signal too Low
      Freeze Frame:
      Fault Priority: 2
      Fault Frequency: 1
      Mileage: 38 km
      Date: 2014.01.30
      Time: 19:26:57
      4167 - Manifold Pressure / Boost Sensor (G31)
      P0237 00 [032] - Signal too Low
      Freeze Frame:
      Fault Priority: 2
      Fault Frequency: 1
      Mileage: 38 km
      Date: 2000.00.00
      Time: 00:00:00
      20572 - Intake Air Temp. Sensor (G42)
      P0113 00 [032] - Signal too High
      Freeze Frame:
      Fault Priority: 2
      Fault Frequency: 1
      Mileage: 38 km
      Date: 2014.01.30
      Time: 19:27:20
      Readiness: 0000 0000
      Address 03: ABS Brakes (J104) Labels: 5Q0-907-379.clb
      Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
      Component: ESC H31 0457
      Revision: 00000000 Serial number: 63103000000E7B
      Coding: 10F16AA224200A6C017E060741C72508562450806082A4B200 2100080608
      ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001
      ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
      VCID: 7BFE3C2DF2D7AEC6C11-802E
      3 Faults Found:
      8274 - Databus
      U1123 00 [008] - Received Error Message
      Intermittent - Confirmed - Tested Since Memory Clear
      Freeze Frame:
      Fault Priority: 6
      Fault Frequency: 2
      Reset counter: 46
      Mileage: 38 km
      Date: 2014.01.30
      Time: 19:26:56
      8330 - Databus
      U1122 00 [008] - Implausible Message
      Freeze Frame:
      Fault Priority: 6
      Fault Frequency: 1
      Reset counter: 46
      Mileage: 38 km
      Date: 2014.01.30
      Time: 19:26:56
      32872 - Databus
      Freeze Frame:
      Fault Priority: 2
      Fault Frequency: 1
      Reset counter: 46
      Mileage: 38 km
      Date: 2014.01.30
      Time: 19:26:57
      Address 08: Auto HVAC (E87) Labels: 8V0-820-047.clb
      Part No SW: 8V0 820 047 D HW: 8V0 820 047 D
      Component: AC Manuell el H11 0052
      Revision: 20021000 Serial number: 00000000034186
      Coding: 00000004100000000000000000000000
      ASAM Dataset: EV_AirCondiFrontManAU37X 008018
      ROD: EV_AirCondiFrontManAU37X.rod
      VCID: 3776E01D8E7F4AA6659-8062
      No fault code found.
      Address 09: Cent. Elect. (J519) Labels: None
      Part No SW: 5Q0 937 084 AE HW: 5Q0 937 084 AE
      Component: BCM MQBAB H H16 0124
      Serial number: 00011331501039
      Coding: 04040A42C001227503044004B30C0700000000000000000000 0000000000
      ASAM Dataset: EV_BCMCONTI 012001
      ROD: EV_BCMBOSCH_AU37.rod
      Subsystem 1 - Part No SW: 8V1 955 119 A HW: 8V1 955 119
      Component: WWS370 131102 041 0580
      Serial number: 131104080452
      Coding: 0A47F7
      Subsystem 2 - Part No SW: 8U0 955 559 A HW: 8U0 955 559 A
      Component: G397_RLS H06 0002
      Serial number: 20125224
      Coding: 00006C
      Subsystem 3 - Part No SW: 8V0 941 531 K HW: 8V0 941 531 K
      Component: E1 - LDS MQB H05 0032
      Serial number: 29 08 2013 00000331
      Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
      Component: Sensor, DWA 005 0315
      Serial number: 000000000ZY1326721WH
      Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
      Component: Sirene, DWA 004 0311
      Serial number: 00000000000058092602
      Address 15: Airbags (J234) Labels: 5Q0-959-655.clb
      Part No SW: 5Q0 959 655 L HW: 5Q0 959 655 L
      Component: AirbagVW20 009 0349
      Serial number: 003GER01DEY-
      Coding: 98CCC000000000005C540000004800000065
      ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
      ROD: EV_AirbaVW20SMEVW37X.rod
      VCID: 499296E5E88BCC5603D-801C
      Crash sensor for side airbag; driver side:
      Subsystem 1 - Part No SW: ----------- HW: 480 002 310 13
      Component: SideSensor_Df 001 0887
      Serial number: 35767000000750681E0Q
      Coding: 2D2D2D
      Crash sensor for side airbag; passenger side:
      Subsystem 2 - Part No SW: ----------- HW: 480 002 310 13
      Component: SideSensor_Pf 001 0887
      Serial number: 35867000000450681E0O
      Coding: 2D2D2D
      Crash sensor for side airbag; rear driver side:
      Subsystem 3 - Part No SW: ----------- HW: 480 400 811 13
      Component: SideSensor_Dr 001 6149
      Serial number: 3516502A11118A35C2E4
      Coding: 2D2D2D
      Crash sensor for side airbag; rear passenger side:
      Subsystem 4 - Part No SW: ----------- HW: 480 400 811 13
      Component: SideSensor_Pr 001 6149
      Serial number: 3526502A91118A33D1DA
      Coding: 2D2D2D
      Crash sensor for front airbag; driver side:
      Subsystem 5 - Part No SW: ----------- HW: 480 400 410 13
      Component: FrontSensor_D 001 6149
      Serial number: 3556502991171FE1C36J
      Coding: 2D2D2D
      Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
      Part No SW: 8V0 953 521 BM HW: 5Q0 953 549 C
      Component: Lenks. Modul 002 0110
      Revision: -------- Serial number: 11111304400104
      Coding: 8408
      ASAM Dataset: EV_SMLSKLOMQB 017001
      ROD: EV_SMLSKLOMQB.rod
      VCID: 8608DDD93915632E2EF-80D3
      Address 17: Instruments (J285) Labels: 5G0-920-XXX-17.clb
      Part No SW: 8V0 920 860 E HW: 8V0 920 860 E
      Component: KOMBI H02 2220
      Coding: 078402002A8000080500A800100000
      ASAM Dataset: EV_DashBoardVDDMQBAB 008031
      ROD: EV_DashBoardVDDMQBAB_AU37.rod
      VCID: 3C7CFF31B75969FE88B-8069
      Address 19: CAN Gateway (J533) Labels: None
      Part No SW: 5Q0 907 530 Q HW: 5Q0 907 530 F
      Component: GW MQB High 125 1164
      Revision: -------- Serial number: 0001260711
      Coding: 01010008200864005B000208000B0000000100000000000000 0000000000
      ASAM Dataset: EV_GatewLear 010015
      ROD: EV_GatewLear_AU37.rod
      VCID: 3F86883DA64F72E6AD9-806A
      Generator:
      Multifunction unit control module:
      Subsystem 2 - Part No SW: 8U0 951 528 HW: 8U0 951 528
      Component: E221 - MFL H02 0014
      Serial number: 31 10 2013 A1285717
      Address 42: Door Elect, Driver (J386) Labels: None
      Part No SW: 5Q0 959 393 B HW: 5Q0 959 393 B
      Component: TSG FS 020 0025
      Serial number: 29101301100760
      Coding: 00100E204100040100001002
      ASAM Dataset: EV_DCUDriveSideEWMINKLO 006003
      ROD: EV_DCUDriveSideEWMAXCONT.rod
      VCID: 3E78F539A1457BEEA6F-806B
      Address 44: Steering Assist (J500) Labels: 5Q0-909-144.clb
      Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
      Component: EPS_MQB_ZFLS 122 1043
      Coding: 0102
      ASAM Dataset: EV_SteerAssisMQB 010031
      ROD: EV_SteerAssisMQB.rod
      VCID: 41828EC5D0BB0416DBD-8014
      Address 52: Door Elect, Pass. (J387) Labels: None
      Part No SW: 5Q0 959 392 B HW: 5Q0 959 392 B
      Component: TSG BFS 020 0025
      Serial number: 03111303110003
      Coding: 001006204100040100001002
      ASAM Dataset: EV_DCUPasseSideEWMINKLO 006003
      ROD: EV_DCUPasseSideEWMAXCONT.rod
      VCID: 3D7AF235AC4360F6BF5-8068
      Address 55: Xenon Range (J431) Labels: 5Q0-907-357.clb
      Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
      Component: LWR-ECU 005 0080
      Revision: -------- Serial number: --------------
      Coding: 010A000001000000
      ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
      ROD: EV_HeadlRegulVWLWRMQB.rod
      VCID: F5EAAA1554F378B6375-80A0
      Address 5F: Information Electr. (J794) Labels: None
      Part No SW: 8V0 035 840 B HW: 8V0 035 840 B
      Component: MU-S--ER 040 0420
      Serial number: A3E01211133177
      Coding: 01730000FF0A000021220001001A00002F0001440100010002
      ASAM Dataset: EV_MUStd6C3PASE 002020
      ROD: EV_MUStd6C3PASE_AU37.rod
      VCID: 346CD7119F09A1BE40B-8061
      Seat Adjustment Driver Side:
      Subsystem 1 - Part No SW: 8V0 919 603 B HW: 8V0 919 603 B
      Component: DU Std H48 0013
      Serial number: AUZ8Z9DM700HC1
      Sound System:
      Subsystem 2 - Part No SW: 8V0 919 614 B HW: 8V0 919 614 B
      Component: ControlUnit_B H33 0037
      Serial number: C1000024091300020193
      End ---------------------------------------------------------------------
      Some interesting stuff:
      1) There appears to be a direct option to enable torque steer compensation (like I did in my GLI) when you have more power (options still not decoded):
      2) There's an option to change tire diameter, so you can use wheels with some difference in circumference from stock (options still not decoded):
      Not being able to understand module 9, I can't tell if there's an option to enable turn signal in the led strip. Also can't tell from the outside if there's such an option inside.
      Most of the options in my list didn't have the related hardware. I did get the needle sweep working, oil temp in the DIS, seatbelt warning off (don't ask).
      Laptimer didn't work (because of the monochrome dis I assume), mirror dip didn't work, no fog lights, start&stop... not really a good car to do some research.
      I'll be getting to play with a 1.8T in the following weeks so I might get more done on that car.
    21. Geriatric Member Dan Halen's Avatar
      May 16th, 2002
      Dougal County
      42,790
      01-31-2014 09:39 PM #19
      Thanks for reporting back!
      Sent from my Nexus 5 using Tapatalk
    22. Junior Member
      Jun 3rd, 2011
      Montevideo, Uruguay
      70
      2012 Jetta GLI 2.0T
      02-01-2014 02:38 PM #20
      My friend came back today and we tested some other functions (not enabled from factory):
      1) Alarm chirp when locking
      2) Alarm chirps when unlocking
      3) Menu option to enable disable 1) (no option found for 2)
      4) Visual confirmations for comfort closing
      5) Mirror dip on reverse (had to configure it also)
      6) Confort cycles to 5 blinks
      As I told before the car is an 1.2T base A3 with Xenons, so most options are not there. VCDS has no codes for the long coding in [09], and most strings in Adaptation are in German so you need to guess or use google translate.
      I've updated the list on the first post.
    23. 02-01-2014 03:20 PM #21
      Nice how ill miss these things on the cla😢
      Sent from my Nexus 7 using Tapatalk
    24. 04-25-2014 02:39 PM #22
      I've just lowered my car and can't seem to readjust the headlights. It keeps asking me for a security code to change the values on the headlight level sensors if I try and change them back to 0.
      Any ideas how I can try and realign my headlights to not be aimed down all the way?
    25. 04-25-2014 11:58 PM #23
      Pics?
    26. 10-26-2014 02:15 AM #24
      Bump. Is this the only vagcom tweak collection in the 8V forum? If so, can we get this stickied?
      Anyone had success unlocking the [5F] module?
    27. Member m_bolc's Avatar
      Oct 18th, 2008
      San Jose, Costa Rica
      232
      2017 Audi A3 1.2T
      11-02-2014 08:50 PM #25
      My car came from the factory with no start and stop feature. I don't even have a button for it.
      Do you think that if I perform the reverse instructions detailed above I can activate it? I wouldn't be able to turn it off from the dash, but that doesn't bother me.
